mbarrett43 mbarrett43 is offline
Car: BMW 335i
Exclamation Offset wheels - 04-24-2018, 06:49 PM
I have a 2012 335i and Iíve looked everywhere for any information on offset wheels for sale. Iíd appreciate if anyone could point me in the right direction with either a website or company. Iím looking to do a 0 to slight offset in the front and a larger complimenting offset in the back. Thanks in advance ✌️
Pretendporsche Pretendporsche is offline
Car: E46 M3, E92 335i
Default 11-30-2018, 01:39 AM
Do you mean you want to keep the offset the same as standard wheels? You wouldn’t be able to run an actual 0 offset wheel on your car.
The e9x standard wheels front and back are between 30-40 offset, for example, if you want your front wheels to ‘stick out’ more than they do now, you would need a lower offset, for example.
Current wheels 8j wide offset et 31
New wheels 8j wide offset et 21
This would make the wheel ‘stick out’ by 10mm more than the standard wheel.
Of course when you take wheel widths into consideration you will also need to recalculate the offset to suit the additional width. Here’s a link to a good site to help with the calculations.
http://www.willtheyfit.com
