keyap keyap is offline
Car: N55 135i
Default 135i - Best Rears For Traction? - 02-28-2016, 03:43 AM
Quite a few mods have gone on over the last month and I'm now finding that, even in the dry, I have traction control on in 4th so I think it's time for a new set of rears a possibly a diff.
The car currently has a set of PSS which are about 1/2 worn. For 'all weather' these have been great but, the car will now only be used in the dry so I'm basically after a set of rears that will give most traction under WOT but are street legal. They can almost be 'slicks' and can wear quickly but do need to be legal.
I'm also happy to change the size as long as they'll go on the stock rims.
Thanks.
[B]
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 02-28-2016, 10:45 PM
Depends on what kind of power you're making. If under 600whp, 555Rs should be plenty.
If you want the best grip I've found that will work with a 135i (without cutting up the fenders)...
http://www.n54tech.com/forums/showthread.php?t=37065
These ET Street Radials held 25psi from my 6466 in 2nd gear.
baja2700 baja2700 is offline
Default 03-10-2016, 02:17 PM
what do you guys think is the best tire for traction on an 18 inch wheel? 600-700whp range
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 03-10-2016, 02:51 PM
NT05 is the best dry tire I've ever used. One of the worst in the rain though LOL. If you're sure it's only going to be a dry condition car, look into NT01, NT05 or R888. Three awesome tires. If you want something slightly better in the rain or a little better tread wear, BFG Sport Comp 2 is the best street tire I've used. Almost as much grip as the Nittos and much better in the rain.
2011 335is DCT, FBO
bigdnno98's Avatar
Car: e92 335i
Default 03-10-2016, 02:52 PM
depends on what you're trying to do with them......
2011 335is DCT, FBO
bigdnno98's Avatar
Car: e92 335i
I'm putting some ET Streets on the spare set of style 264s I have laying around, next weekend. I'll report back after my first trip to the track.
2011 335is DCT, FBO
Default 03-10-2016, 03:07 PM
mostly want the traction for rolling races (mexico) since i will be getting a set of 17s just for the 1/4. i like the nt01s but wasnt ssure which is better for traction, nt01 or nt05
bigdnno98's Avatar
Car: e92 335i
Default 03-10-2016, 05:28 PM
01 is better than 05 if my memory is correct.
2011 335is DCT, FBO
bigdnno98's Avatar
Car: e92 335i
Default 03-10-2016, 05:30 PM
I bet an R888 would be awesome for high speed roll racing.
2011 335is DCT, FBO
Default 03-10-2016, 06:40 PM
Not a fan of the r888s
bigdnno98's Avatar
Car: e92 335i
Default 03-10-2016, 06:45 PM
Why not?
2011 335is DCT, FBO
DB90 DB90 is offline
Car: M135i
Default 03-11-2016, 02:30 PM
Keyap I'm in the uk to in a similar-ish situation albeit not as much power as you. I was looking at the federal 595 rsr semi slicks, they will offer more grip over the MPSS' and still get you from a to b in the wet weather.
Car: N55 135i
Default 03-12-2016, 04:56 AM
Hey guys, thanks for the all responses. It looks like here in the UK options for traction plus road legal are limited . Apparently dot rated are frowned on by some of the rozzers which limits options so it looks like I'm going to need E rated since my goal is traction whilst DD'ing, not track.
R888Rs seem one to go for although MPSS seem to be rated similar so I'm not sure what improvements I'd see.
I actually think it maybe time to slip something like a Quaife or MFactory LSD in and see what happens since the existing diff really doesn't cut it with increased power levels.
DB90 - thanks for the federal recommendation , I'll have a look
Baja2700 - why not the R888Rs?
[B]
Anytyme's Avatar
Anytyme Anytyme is offline
Car: 2011 335I
Default 03-18-2016, 07:22 AM
I just installed r888 on some 17's
N55 World Record 650whp 571tq
2011 N55 335I, VM Top Mount Kit, PTE 6266 Gen 2, JB4 AMS Fmic, ER CP with BOV, FuelIt Stg3 LPFP, , PI Platinum Kit.
bigdnno98's Avatar
Car: e92 335i
Default 03-18-2016, 02:11 PM
do you like them?
2011 335is DCT, FBO
lightning lightning is offline
Car: BMW 1M Coupe
Default 11-24-2017, 10:05 PM
hi guys! any updates? :D
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 07-19-2018, 11:01 AM
slicks
2008 BMW 135i MT: Stock turbo FBO
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
suspenceful's Avatar
Car: 2008 BSM 135i
Default 07-19-2018, 11:54 AM
Since this old thread got bumped, I'll chime in. Cheap wheel that fits well, even though it's only 8.5" wide. If you're lowered, you'll have to roll you're fenders.
My rear E46 style 68 wheels with 275/40/17 MT ET Street R's have been great up to 700+whp.
Car: N55 135i
Default 02-17-2019, 06:01 AM
So, thanks to all those who posted above.
A quick update - the BMW is now just used for fun so will only be used in the dry and I'm after the best tyre for straight line traction from a ~20mph rolling start. Cornering, ride and durability do not matter however, they need to be street legal and either 18 or 19 inch.
I was looking at either the r888, r888r, 595rs-r or FZ201s. I have however also been recommended some Nankang AR1s which I have zero experience of?
Given the above, anyone got any thoughts?
[B]
