(#151)
Car: q50
Default 06-16-2019, 04:51 AM
-20wwf is ~30-35% meth, the rest is water.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 06-16-2019, 08:33 AM
On your JB4 WMI settings - what are you running with?
Boost Additive = ?
Signal Scaling = ?
Min Flow Boost = ?
External Trigger = ?
Min RPM = ?
Max RPM = ?
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HE w/ Aux Tank
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
  • EcuTek Flash (In Work) Seb @ Specialty Z
Car: q50
Default 06-16-2019, 02:17 PM
Boost Additive = ?
Signal Scaling = ?
Min Flow Boost = ?
Min RPM = ?
Max RPM = ?
It amazes me that I can't even upload a screen shot from my phone due to size limitations. Anyways:
Boost Additive = 50
Signal Scaling = 60
Min Flow Boost = 0
External Trigger = 1
Min RPM = 2000
Max RPM = 6800
jrobohm's Avatar
Default 06-16-2019, 03:29 PM
Thanks - do we know what impact Boost Additive has ?
My guess it relates to Map8 somehow - perhaps it means amount of boost added over stock (e.g. 50 = +5.0 psi ?)
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Car: q50
Default 06-16-2019, 04:32 PM
Boost additive is how aggressive the boost target is under full meth flow. I asked about signal scaling awhile back but didn't get an answer.
Default 06-16-2019, 09:04 PM
Signal scaling is normally 60 for an FSB running a BMS WMI pump. If you're using another pump it may need to be higher or lower. It's the min flow for the JB4 to consider the pump at full flow.
Boost additive is how much boost you make on map8 under full meth flow. the higher the number the higher the boost target. The system scales between a map similar to map1 with a 0 additive and similar to map7 with a 75 additive. The additive can be set up to 100 but normally 75-80 is the practical maximum.
jrobohm's Avatar
Default 06-17-2019, 11:15 AM
Terry - Many thanks for the clarification and for the review of the attached log via email. For my fellow WMI mates - the log looks promising for moving the Boost Additive number from 75 incrementally up.
BMS WMI
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Car: q50
Default 06-18-2019, 07:39 AM
BMS WMI
Looks good to me! You're running some decent boost, not sure I'd turn it up much more. What fluid are you using? Timing looks good. AFR trims are about maxxed.
jrobohm's Avatar
Default 06-18-2019, 08:06 AM
@ E30 fuel blend - explains the Trims topping out I would assume.
Using Boost Juice
I have moved up to a Boost Additive number of 78 - logs to follow.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Default 06-18-2019, 09:22 AM
The WMI kit for these cars is a must IMO. Being able to use this to lower IAT as well as more fuel volume and octane is just a no brainer.
jrobohm's Avatar
Default 06-19-2019, 09:58 AM
Latest log / run - pulling like crazy - starting to loose traction on my summer tires (good problem to have )
BMS WMI
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Car: q50
Default 06-19-2019, 11:03 AM
BMS WMI
You're AFR is really leaning out in lower gears. Trims are maxxed and you're running meth. I wouldn't expect the AFR to lean out unless you're past the limits of the fuel system with meth. I'd back down boost, but its your motor.
jrobohm's Avatar
Default 06-19-2019, 11:07 AM
Iím running a E30 blend - Iíve always had Trim issues as a result. I will try a tank of straight 93 and see how that impacts the logs with everything else the same.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Car: q50
Default 06-19-2019, 11:20 AM
Yeah I understand you're running E30, but with full time closed loop wideband correction you should still be hitting your target AFR (low to mid 12's) ESPECIALLY with the added fuel of meth. But youre STILL leaning out which tells me your fuel system can't keep up with the demand even though you're spraying meth.
jrobohm's Avatar
Default 06-19-2019, 11:32 AM
Understood - question then; would running 93 vs E30 potentially help the AFR #ís? My understanding would be maybe. The next option beyond WMI would be what - HPFP/LPFP upgrade(s)? Do we know if the stock ECU would be able to take advantage of either of them?
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Car: q50
Default 06-19-2019, 12:38 PM
Yes running 93 should help your AFR. E85 requires about 30% more fuel to reach the same AFR so I imagine that it'll help your trims and be able to richen it up to hit the target. Will be curious to see.
As far as fuel pump upgrades, you definitely can't upgrade the HPFP without a tune, not sure on the LPFP.
jrobohm's Avatar
Default 06-20-2019, 07:00 PM
So - when can beta testers get some details on the BMS VR30 LPFP upgrade?
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Default 06-20-2019, 07:02 PM
We have a few almost ready to go, just waiting for our new pump controller to run them. We may just release a little early.
jrobohm's Avatar
Default 06-20-2019, 07:08 PM
Very cool - placing my chair and umbrella at the front of the line.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Car: Infiniti Q50 RS400
Default 06-20-2019, 08:22 PM
Woah I got blind sided here lol. BMS will have an lpfp solution? Is it a total basket replacement? Or billet pump housing? What pump are you guys going with?
More details please.
Default 06-21-2019, 09:10 AM
We'll post the details when ready! It's a Fuel-IT product.
jrobohm's Avatar
Default 07-02-2019, 06:42 PM
I am running my E30 blend tank down and will move to straight pump 93. Before that I plan to add 1/2 gal of M1 to my 2 gal Boost Juice tank (currently at about 3/4 full.) Iíll do a run at 78 BA and see how the remaining E30 + the added M1 (maybe a net 60 / 40 ratio of Meth / Water?) helps my AFR numbers get closer to 12.5 vs the mid/high 13ís I am seeing.) Iíve read that 100% Meth is not worth the trade off in safety and cooling - hence I do not plan to go past a 70/30 mix. Depending on how this test logs out I will see if I need to maintain my fuel E85/93 fuel blending or just drop the corn and keep the 93 + a potentially meth richer (50-70/50-30) ratio juice blend.
These are exciting times and the BMS WMI kit is proving to be a great investment. Once I have dialed in the best BA number / fuel / WM mix ratio; I will take the car to Jotech for another dyno run!
BMS WMI
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
Default 07-02-2019, 09:42 PM
jrobohm's Avatar
Default E30 blend - 50/50 boost juice - BA = 79 - 07-03-2019, 09:25 AM
Quick run before adding M1 to existing 50/50 boost juice.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
jrobohm's Avatar
Default 93 Pump Fuel - 40/60 H20/Meth juice - BA=79 - 07-06-2019, 08:27 AM
Up hill 1-3 gear run. Seems I am making some progress on the AFR numbers. Still maxing our the trims however... Timing appear ok - Do you all have any thoughts / suggestions ?
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HPFP & LPFP
  • AMS Flex Fuel Kit
  • AMS LDP
  • FI Res CBE
