blue blue is offline
Rr
Car: 320i
Question Trouble code help - 05-02-2019, 04:45 AM
Hello everyone,I installed FF and EWG lines,A fault code appeared during engine startup.Please give me some help.
Default 05-02-2019, 09:40 AM
Still comes back after clearing codes?
Rr
Car: 320i
Default 05-02-2019, 04:27 PM
123511,123512,120408 didn't appear after I deleted and restarted it, but 21a02d was always there. I checked BMW's code base. It was a problem of idle speed instability, but the car didn't seem to have this situation, just the code.
Default 05-05-2019, 06:52 PM
What codes are coming back up?
ManiN54's Avatar
ManiN54 ManiN54 is offline
Car: 2007 335i FBO stock turbos
Default 05-05-2019, 08:24 PM
Your duty bias settings look a bit odd, I guess Terry can confirm the correct settings for you. Not sure if it’s related to your wastegate code.
1/4mile 11.8@117.96 19psi
07 E92 335i (the Alpträum) | Alpine wht/ Seibon carbon hood/ trunk| M parallel wheels| street tires
FBO| modified oem airbox lid w/K&N drop-in| stock turbos/ stock inlets| Walbro 465lph LPFP| Jb4/mhd backend flash| Map 6 w/E60 No Meth| Built and tuned by me.
Rr
Car: 320i
Default 05-08-2019, 01:24 AM
hi,
I set jb4 to map0, but the code 21a02d still exists.
M340Hussein M340Hussein is offline
Car: F30 340iM
Default 08-30-2019, 05:45 PM
Hey Blue, i have the same fault code as you had “21a02d” so i wanted to take your advise if you were able to find the cause of it.
