Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default Difference between N14 and N18? - 06-10-2018, 05:37 PM
Terry, Do you have any idea whats different? I went to look at an 08 Cooper S today and the VIN decoder says it has an N14 turbo 1.6 I-4. From what I've found the 07-10 came with the N14, then they switched to the N18. Will the JB4 work on that? Not sure if its like the B46/48 where its basically the same or if its a different engine.
Mike Levy
2021 M550i - July build, waiting for dealer allocation
2017 X3 xDrive35i
2018 Equinox LT 2.0T
Default 06-12-2018, 11:07 AM
For that year we only have a Jb+ I don't think it is compatible with the N14.
Only Jb4 for the Mini is the B46/48 as you stated.
Mike_L's Avatar
Anti-Social
Default 06-13-2018, 03:46 PM
Thanks. Won't be buying a Mini then. Still looking for something N63 powered, but trying to keep the budget real low, so its nearly impossible.
Mike Levy
2017 X3 xDrive35i
Default 06-15-2018, 09:06 AM
The N14 is the previous motor, 2007-2010 IIRC. We don't make anything for that one. Started with the N18. Which is a solid little motor.
Car: F06 N55 640i Gran Coupe
Default 05-21-2019, 08:10 AM
Terry, is the 2012 N18 engine R58 Coupe able to use the JB4?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Car: B46 F56S
Default 05-22-2019, 01:44 AM
JB+ not JB4
