(#926)
Dtang81 Dtang81 is offline
Car: Mercedes C43
Default 09-25-2020, 06:54 PM
Hello
I have 18 C43 and the default setting are not the same as those listed on the first page. Should I change mine to match those settings? I’m currently running map 3.
Default 09-26-2020, 01:14 PM
Can't hurt to update to match the first page but the differences in your settings may not matter, not all settings are active.
Car: Mercedes C43
Default 09-26-2020, 02:57 PM
All put back to default. Previous settings were:Fuel bias was all set at 100. Load bias was all set at 0. Boost safety was 3. Wastegate POS, PID Gain, Auto Shift boost redux, FF/Wastegate adaptation all set at 0.
Here is a log running Map 3.
Dtorres75 Dtorres75 is offline
Car: 2015 Mercedes C400
Default 09-29-2020, 10:20 AM
https://ibb.co/xDwwZs4
Hey Terry @ BMS , can you take a look at my logs? I’m running map 3, 93 fuel, paired with the BMS intakes. It’s a 2015 Mercedes C400, the log is from a stop, brake boosting.
Just want to make sure everything looks good before I go E30 on a higher map
[IMG]https://ibb.co/xDwwZs4[/IMG
Bzammitt Bzammitt is offline
Default 09-29-2020, 01:13 PM
Terry,
Would appreciate if you could look at some logs for me. C400 with BMS intakes, JB4, on map 6 E30 fuel (green plug). Been running this setup for over a year and 25k miles no problem. Recently, the car feels like half throttle when launching in first gear. You can see my throttle isn't at 100 even though pedal is? What's weird is only in first my trims are maxed, FP drops, it runs quite lean, but timing is not being pulled. Any ideas? I tried some older settings I had as well and got the same condition.
Default 09-29-2020, 02:06 PM
It looks like you just over-revved a gear there triggering throttle to slow down the engine but log itself seems fine to me.
Car: Mercedes C43
Default Please review - 10-05-2020, 02:24 PM
Hey Terry
Can you please check out my log above. I put everything back to default like you told me to but just worried something might be off.
F6382-A09-556-E-4718-84-B1-97204-FDBFE63 — ImgBB
Link to graph
Thanks in advance.
Default 10-06-2020, 11:02 AM
Hey Terry
Link to graph
Thanks in advance.
Seems fine to me!
Togaf16 Togaf16 is offline
Car: 2017 C43 W205
Default 10-09-2020, 05:55 AM
Hey Terry,
Sorry if this has been answered already. I have a 2017 C43 and want to know if the JB4 removes the top speed governor on the car? Also I have the option to open the exhaust flaps on my car but the default is set to closed. Anyway JB4 allows us to override the system so that they default to open when starting the car? Same goes for the ECO option which shuts down your car at a stoplight. The option defaults to ON, but it would be great if JB4 could also default it to OFF.
Last question, what MAP would I run if I bought the standard ECO Boost mix off the shelf at Autozone or another car parts store? They don’t sell 93 Octane where I live.
Many thanks!
TOGA
Safari911 Safari911 is offline
Car: 2019 C300
Default 10-09-2020, 09:21 AM
Im looking for instructions for the brown wire hook up on my 2019 C300 and dont feel like looking reading through 30 pages to find it, if its even in here. Can someone send them to me or point me to a page number?
Default 10-09-2020, 01:00 PM
Originally Posted by Togaf16
Hey Terry,
Last question, what MAP would I run if I bought the standard ECO Boost mix off the shelf at Autozone or another car parts store? They dont sell 93 Octane where I live.
Many thanks!
TOGA
Unable to change the speed limiter on this platform. Currently do not have CANflap active but maybe in the future on that.
Usually map2 is the go-to map for most fuels and situations.
meer31 meer31 is offline
Car: Mercedes Benz C450
Default 10-18-2020, 09:29 AM
Hello Terry new to the site I just logged 60-130 Map 0, needed ur opinion on the settings I should have just bought the jb4 for 2016 C450 AMR flash tune stage 2
Default 10-18-2020, 08:43 PM
So far looks good. What fuel are you using?
Set map6 to 1.5 across the board and log map6 next!
Savvy Savvy is offline
Car: C300
Default Yesterday, 12:42 PM
https://imgur.com/a/qucSOV2
Might need to contort your hand to get in, but its doable
zedw205 zedw205 is offline
Car: 2019 c300
Default Today, 03:38 PM
yep its not that bad i had to take it out a couple of times for dealer trips. The hoses surrounding it are flexible, just make sure the engine is cool.
