iarthur's Avatar
iarthur iarthur is offline
Car: Mini Cooper S F56
Exclamation 320i switching to map 4 - 10-05-2020, 05:04 AM
Hello, I have a 320i 2015, I recently purchased a JB4 without the ewg connector and I upgraded to firmware 7, I went to test it on map5, the problem is that when I change gears from third to fourth it changes the map to 4, I did the test on other maps and the problem is repeated, I noticed that the boost is not over 11 psi and the last safety stored 1 below my settings and logs:
DP
DV +
Inbox filter
Gas 102 ron Podium Brazil
Default 10-05-2020, 08:19 AM
Photo of JB4 connections installed in engine bay?
iarthur's Avatar
Default 10-05-2020, 11:32 AM
Ok
Default 10-05-2020, 01:09 PM
Photo looks OK, but PSI2 manifold boost in the log is higher than throttle body boost, which should be impossible.
Map0 log?
iarthur's Avatar
Default 10-05-2020, 01:18 PM
Map 0
Default 10-05-2020, 01:37 PM
Not lining up on map0 also. Photo of both sides of the JB4 board?
iarthur's Avatar
Default 10-05-2020, 03:04 PM
iarthur's Avatar
Default 10-06-2020, 07:10 PM
New logs on map 5 there were wmi configurations set to zero and did not change to map 4 anymore.
iarthur's Avatar
Default 10-08-2020, 04:33 AM
This log was with the firmware in version 6, version 7 still skips to map 4.
Default 10-08-2020, 03:21 PM
If it's working then stick with it. But something is definitely odd, perhaps the JB4 board itself is faulty.
iarthur's Avatar
Default 10-09-2020, 05:24 AM
How could I be sure the card is defective?
Default 10-10-2020, 08:18 AM
You could try swapping JB4 boards with a friend and recording a log to compare. If you were in the USA we'd send you another board but being in BR is more difficult with the shipping.
iarthur's Avatar
Default 10-10-2020, 08:51 AM
I can pay the freight is all costs
