(#226)
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 10-09-2018, 10:37 AM
Garage views! E39 will be up for sale soon since the E61 is almost done. E39 will receive all the critical chain guide and vanos maintenance as well as a manual trans swap prior to sale. It will probably go up on Bring a Trailer.
Since the wagon had sat for so long I checked the fuel which looked good, sometimes ethanol can deteriorate and become milky, my tank had an E40 blend.
[IMG]https://lh3.googleusercontent.com/1CT60Vsq3VXbPAcbscIAgybjIOK2QbEP7ii07TID_sU91iUynI FHKJyAQKIhnM-57EiDWrYZR2i069YDg49BojBd8jDQUP49i2nehoyf-AxEJ_SwZlt2gcXryIoiHuk***j2rgXsciAbF92De9cXBLIg1n0 jaWXxD2uWfNxPrHOAEZUdrYuYHSkP6BcC-ulSZYanx9dWwGSDfnK9pgExM1fpvERibHuFKh13BofQzxg1gxQ kdbQRq3sILZM6qpXlYC0Ubcguywy6lu-uQI2eK-73C6sbIeBIHycr30QCW9YOWVD-ODuntdko9riln878PFzxdBvlp9ra8VWbVV8DD10QKXgcRaHc37 7atY2c801RVbJJOdt3ivXDZM3hHWs67eaUcazNoD_PHQ7-SCADJd1ZuVoP-KQwD4Ebf0s4xzwJujeJEIUTK0VfIE6-GlZAGGQszLDShN2MGtkFBohxGcVNiKsUVo_JmdvVpvyqZaQdgK mWcavg_KlpMsdqEETas_YXzj764tv-XZF58OZtgzzd98oe2g3UqDFJ-TxFG1xpj8QfMu103CyCG_BECDFLK3HJnY6HUgSDE9j393gm-YwlcudswD6_so2fnoux0rikD0MF1znwSX640FwPUCBK=w1309-h983-no[/IMG]
I also flashed my tune back to pump gas from E85 and lowered the boost.
[IMG]https://lh3.googleusercontent.com/TGUCP06Ruq3lCM1HyNAZJ0YoDACffoGLvZVk0ViNFcEMP2OZq7 dnb5hqXUo8vPG_scgDPqziHzHVobev112sji5BBAO3FQQcDqRw BL8LWCcO2wPghsChQquWHuMa5Uw0S3DaXY0A_x6o5qjxsBQ4Pu pO9HGVrudwth8QPUks8XDY1R21roqMFiNoR8Y46xD7ouGGUQo9 rNKd7T0L0KmzGLM6EZo6vl0cqAwj5mMYWr82lJ-kwYo_eujfWeYY8uMX5F6lTMVBaXmSt6F5F83PLU0oECUPu_7ot 6c5L_sNZHF0LmtQtrBlMVCQwgCgLN2ozOvg***az5mUHMMXh6p ByhDlBnoryAGqc2HXJAJZ1HI9y3clzQ13iVzY4HXUy1EdgjE08 _plID9dSFOoRpghjPccG9oIXHHbcZ3hMRNhy_diDfkQ9mRiPXQ iqNogBnPYQdUKCCJw17z7_5Vysr91ZzvvcqoUbJcfXSxmhIC9F dTg_5sBJKpH0guPrGnH9dAll5mYHip-bdD44j0gy3sHeETid9HosUTJ0wFHqAzKpVNGYie6QwKh8S75WW GjI192Abk_SjjxpGf3djSZFRn73kHY5rbQE2dhhxkfUVqqDe-zZXxB4LVfhaeWRrRS0xPF=w1309-h983-no[/IMG]
After adding a bottle of Seafoam to the 1/8 tank I had left I went and filled up with some fresh 91.
Collision Factory in San Diego did a fantastic job on the apron repair. It looks factory (minus it isn't as oil/grime "tainted" like the other engine bay paint) and fitment is excellent.
Replaced headlight bracket carrier, it was only mildly bent but it was giving me some fitment issues and after attempting to rebend myself I threw in the towel and got a new one.
Originally I sourced a blue hood to repair and repaint but I came across an Alpine White one. It is in great shape and after some PDR and a proper paint correction it will be better than my original hood.
With the headlight carrier replaced that means I can install the horn, wheel liner, and most importantly the headlights which means I am road legal.
Road legal wagon = back to work! Shipping some wheels for my friend.
I took a moment to explore my xi spec KW V3s fitting into my RWD/M5 spindles.
Looks like I will have to explore some shims, if I can't find a solution then at least I know KW sells coilovers individually which is great, as a bonus I would be able to get the V1s which are great for my intended use, V3s are overkill.
N54 Powered M5 Wagon:
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 10-09-2018, 11:23 AM
You need the sleeves that KW uses to fit non M coilovers to M hubs. Take a look at the coilovers fro the e-series http://www.vivaperformance.com/kw-v3...mw-e90-e92-m3/
ucsbwsr's Avatar
Car: 535xi Wagon
Default 10-09-2018, 12:00 PM
Another forum was in a similar position but had ISC coilovers which were too small for the spindles. He got some shims from KW (p# 65010239) which take up ~10mm of space in the spindle, not sure if they are the same ones but they look similar, he will be sending them to me to test fit. He ended up getting custom shims made as his ISCs only needed about 5mm of space taken up.
My concern is the small lips in the bottom of the spindles that the struts bottom out on how that will play out with my struts being intended for the xi. Time will tell.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 10-11-2018, 09:32 PM
I had a rough idle and some misfires popping up and after chasing my tail for a bit swapping coils and plugs I decided to just refresh all plugs to eliminate them collectively as a variable.
Went with Bosch plugs but will go back to gapped NGKs once I start running more ethanol and boost.
Old NGKs
New Boschs
Checked injectors via INPA
Due to a leaking radiator to oil filter housing hose there was a considerable amount of oil which had been dripping and blown onto the front of the engine by the radiator fan (so much for the spotless engine), the leak has been resolved but the belt still squeaked and wasn't sitting 100% correct on an idler pulley. With a fresh belt already on hand for this anticipated repair I removed the current one to check the pulleys, sure enough the upper idler was shot.
LIFE HACk: Your local O'reilly Auto parts (at least mine in San Diego) can order parts from local German part suppliers such as SSF and usually get both "Genuine BMW" and OEM brands like Febi, Lemforder, Uro, Ina, etc. Similar to what is available on ECS Tuning but the kicker is a delivery can happen quickly. From placing my order at the local store to them calling saying the part has arrived was less than 1 hour and the pulley I ordered was the same brand as what I was replacing, in this case Ina (OEM producer). Amazon Prime and Amazon Now can't compete!!
My plate turned out to be more controversial than I thought it would which is fine, to each their own. The intent was for the plate to describe the composition of the wagon; functionally it's an M5 with an N54 motor. All the chassis, suspension, brakes, and drivetrain upgrades that make an M5 an M5 are on my wagon so consider it an M5 with a motor swap. Sure the VIN reads 535xi so it's "not technically an M5" but if you value VIN numbers over the driving experience and function then you are missing out! For the record I tried to get "NOT AN M5" but it was taken in CA.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 12-14-2018, 11:57 AM
Progress has been a little bit slow on the E61 as the E39 has been receiving a lot of attention, getting a custom tan on black interior, aftermarket M5/M-Sport bumpers, M5 steering wheel, M5 sway bars, revised exhaust, and more parts collected for the manual trans swap.
About a month ago I picked up a M5 fender, although the wagon is still bumper(cover)less the fender made it look a bit more appropriate for driving around even though it is 100% road legal with the real bumper aka crash bar.
Annie inspecting fender fitment. It isn't perfect since the small bracket which connects the front fender bracket to the headlight bracket was bent and I did my best to straighten it with no success so I have a new bracket ordered.
The wagon has been running around like this for a while now....
Wagon is running great, ethanol has been introduced and I am targeting 22psi, a little lower than before but "enough" for cruising around. 22psi should be putting out ~520whp
Bought the necessary power steering lines for the M5 subframe conversion, lines are actually from a 535i which are the only ones which will connect the M5 steering rack to my 535xi pump.
Last piece of the puzzle. My patience paid off, I was able to find a brand new OEM M5 bumper for $400, roughly half off what they go for online.
Here are a couple pics of the E39 which has been in the spotlight.
5nowh1te's Avatar
5nowh1te 5nowh1te is offline
Car: 2008 535i
Default 12-14-2018, 10:11 PM
my favorite wagon
2008 535i SAT W/paddle shifters
Pure Stage 2 DD on the way!
VTT Inlets and Outlets
Spool Performance stage 3 LPFP
Fuel-It Ethanol Sensor + Lines
Motiv Flex Fuel Box
AD-Engineering 650 HP Intercooler
JB4 G5 ISO W/MHD BEF
XHP Flash Stage 3
Synapse CP with BOV
BMS OCC & PCV
Accuair Elevel
Hpdrivetech air bags
AG Wheels
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 01-06-2019, 12:12 PM
Evan, a quick question. So I'm in the middle of putting my n54 together, the engine is out of a 535xi. I bought a complete 335 engine some time ago and have the oilpan and ps pump. I can see the difference in ps pumps from the 335 and the 535. If I was to keep the 335 pan and ps pump, would there be a big difference in steering? I'd like to make it a drop in, as this is going into an e60 with a n52. I could wait to use the n52 pan and pump if I have to. I do have sport mode and like the steering in this feature. Thanks for any imput on this.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 01-07-2019, 11:49 AM
I am a little confused about your situation, you have a 535xi engine but you want to install a 335i PS pump and pan you already had and install it in a 535i? I would just get the correct pan and pump for the vehicle you are installing it in. IIRC the 535xi and 535i has a different oil pick up to go along with the xi pan. 535xi pan is also ~10lbs heavier than the 535i pan since it isn't reinforced. Not very familiar with 335i stuff.
Default 01-07-2019, 03:51 PM
I guess is sounded confusing when trying to write it. I'll leave the 535xi part out. So, I'm building a n54 for my e60 car with a n52. The n54 dosent have a pan because it's out of an xi. I have a 335 oilpan with ps pump, I'm aware these pans are series specific. I wanted to use the 335 pan that I have, I don't want to leave it open without a pan if possible. If not, then I'll have to wait till I pull the n52 out for that pan. I'm just wondering if you know about the 3series pumps, being smaller and such. I don't want to have to buy another oil pan when I have one, I'm trying to make this complete before drop in.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 01-07-2019, 04:16 PM
I am not familiar with the 335i vs 535i PS pumps but I would be default assume a 535i pump would be the way to go. Although car manufacturers can do some weird stuff I would assume that BMW engineers went with the larger pump for a reason on the bigger car so the safe is to run a pump appropriate for the chassis. If you really want more info then you can try looking up the make and model of each pump to see if you can track down manufacturer specs to compare power, flow, and any other applicable data that could confirm your question.
Default 01-10-2019, 02:46 AM
Ya, I'm looking into it, I saw that pans and pumps differ, the 3 is a smaller pump, not sure what the outcome would be if running it. Appreciate the fast response!
Default 01-10-2019, 03:53 AM
I may have found what I was looking for, I notice that you have the larger ps fluid resivior. I pulled the same one and he larger pump out of the 535xi donor car. I can't rember if it was active or dynamic, but I'm thinking this is why the difference. I wish I new how to upload pics for reference.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-14-2019, 09:13 AM
The white wagon keeps getting undercut by these other "project wagons" I spend all my time wrenching on, to make matters worse (first world problems) I had an opportunity to pick up another E61 for a excellent price which will be a short term project for me and hope to have up for sale in a few months.
The grey E61 is an 08' with 127k, tons of maintenance, and some nice mods.
OEM M5 front end, Grigio Telesto paint w/ black roof and black engine bay, Cobb AP, Dinan muffler, and 20" Vossen CV3s. I will be going through it making some necessary repairs, preventative maintenance, and executing some choice mods to further enhance the wagon. If you like my white wagon then there is a lot you will like about "DAS GRAU."
More here: Another Project Wagon - N54Tech.com - International Turbo Racing Discussion
Updates on the white one are minimal but progress is being made. After replacing some damaged brackets I was able to test fit the OEM front bumper and fitment is excellent. I also test fit the OEM M5 engine bay splash shield which is RWD subframe specific and will wait for the subframe swap to go on.
I ordered a used 535i DSC module/pump. Previously I used my 535xi pump with a 528i module (same BMW # as 535i) and haven't been able to resolve my ABS/DSC warning lights even with the tremendous help of Levan who is an advanced BMW coder. Hopefully the pump is the culprit.
The last piece of the puzzle for installing my RWD/M5 subframe is resolving the strut incompatibility. Perhaps KW just released them or US distributors are now offering them for sale in the US even though there are literally <5 E61s in the US that could use them but KW now offers a RWD E61 specific coilover setup and thankfully it uses factory-tuned non adjustable V1 variants. I never use the adjustments on V3s and hate paying twice the price for essentially the same performance (IMO). Once the coilovers arrive I can complete the RWD subframe swap and enjoy the M5 steering rack.
New bracket
Bumper test fit
M5 splash shield will be a nice finishing touch once the subframe is swapped
535i DSC unit
My bumper is unpainted, my fender is the wrong color, and I need to modify a headlight.....
better go recondition that side marker.....
Current pics
ucsbwsr's Avatar
Car: 535xi Wagon
Default 10-18-2019, 09:08 AM
Not too much to report on the white wagon. She is still an ugly duckling from the outside which was compounded by me cracking my own windshield while trying to remove the top weather stripping. Insurance should cover it even though I am a dumb dumb.
I am still running a single 450 LPFP so my power is fuel limited, eventually that will be upgraded to dual 450s but as an interim solution I turned down the boost to a level where I can run full ethanol. I don't care to blend all the time and with CA gas prices being stupid high E85> 91 (duh).
I did have some misfires popping up and some of them were terminal, meaning clearing the codes didn't resolve the misfire. It turns out my (upgraded) Delphi coils were dying and some completely ate the bed. Thankfully I have a box of used OEM injectors and coils on hand. A few weeks ago one Delphi coil died, I replaced it with a used OEM coil and all good! This week I have another misfire, again replaced cyl 6 with a used OEM coil, then the next day two more Delphi coils died, at least their lifespan is consistent! lol. Planning for the inevitable I replaced the removed the last 2 Delphis and intorduced them to the trash can. I am now back on all used OEM coils. There are either the coils I originally had on my wagon before "upgrading" to the Delphis OR they are used coils from my buddies RB Turbo E90 that were removed prior to a single turbo conversion. I plan to run these until they die because, why not!?
Aside from the coils dropping like flys the wagon has been a sweetheart in terms of function and reliability so I will give myself a big pat on the back knowing I did something right! lol
I have some other projects which are stealing the spot light from the white wagon but I am looking forward to getting the white wagon's aesthetics back up to par with it's mechanical performance. Until then I will continue to live by my function>form motto.
Evan
ucsbwsr's Avatar
Car: 535xi Wagon
Default 03-18-2020, 03:49 PM
We have ourselves a nice little update right here....
Although the E61 has been mechanically flawless for the past year, it has been running around San Diego as a bit of an ugly duckling with a blue M5 fender and an primed OEM front bumper. I am happy to report the wagon has received some much needed aesthetic love.
.....but wait there's more!
In this installment:
- OEM M5 Front bumper had PDC holes and washers deleted + paint
- OEM M5 fender had vent deleted + paint
- Cracked windshield replaced with new OEM glass
- New OEM cowl
- New OEM windshield surround
- New pano roof surround
- EHC sensor replaced
- Dinan rear sway bar installed
- Cluster received M5 bezels and pre-LCI needles
- OEM Brushed Aluminum Door Trim (dash and console OTW)
"Clean" is always the goal and I am a big believer in less is more. Continuing the there of deleting the (non-functional) M% fender vents I decided the have the PDC sensors and headlight washers shaved. The washer system is super annoying and functionally the system has been deleted for quite some time so it was a no brainer to delete the tilting covers. As for PDC, I know how to park and have good depth perception.
Here is a photoshop I did earlier which convinced to be do the deleting, it's subtle but .....clean!
With the bumper and fender off at paint I decided to also get my cracked windshield replaced.
I also replaced the weather stripping for the pano roof
Broken load leveling sensor replaced
Bumper and fender installed!
Bought a used M5 cluster to steal some parts from, the circular gauge bezels which are part of the front plastic and main bezel. It was a little scratched up so I polished the plastic a bit.
Before/After with M5 bezels, subtle
I also pulled some pre-LCI needles from the junkyard. The pre-LCI needles have the same design as the M5 but are white instead of red. I prefer the design of these needles to the LCI ones my wagon came with, in comparison the LCI needles look a bit bloated and not as sharp.
IMO the red M5 needles look "cool" (I run them on my X5D cluster) but are much harder to see during the day and therefore inferior to the white.
Here are the final pics:
New OEM windshield going in,
Fresh
Since I converted to RWD the RD Sport sways I had would no longer fit, since they are NLA and arguably the most desireable sway bars for the E61 I sold them as a set. My front sway bar is from a convertible M6 which is the largest OEM bar available for the E6X, for the rear I went with a Dinan unit which surprisingly, carries a reasonable price tag considering it has also the usually-overpriced Dinan badge.
Finally found some OEM brushed aluminum trim at a reasonable price, center console and dash trim is on the way as well.
The old trim was OEM wood wrapped in 3M "brushed aluminum" I much prefer the real deal!
Before
After
Looking good!
ucsbwsr's Avatar
Car: 535xi Wagon
Default 09-02-2020, 09:55 AM
Update time! * *Hopefully the pics work if they don't on this forum then Google "Evan's E61" and you can find other forums I post the same content on.
In chronological order....
My buddy imported an 12' E63 AMG P30 (550hp 590tq) so naturally we got together to go for a drive, snap some pics, and do some pulls. *This is the first time I have lined up to do some pulls against one of the modern power wagons. *
We had a couple fun runs but our starting RPMs were all over, I was starting in 3rd everytime which put me below 3,000rpms @40mph which wasn't ideal but this gave me the jump the first couple pulls since Andrew was in even lower gears, he then started in higher gears and got the jump. In hindsight I should have been in 2nd or, ideally in 3rd with some anti-lag. Andrew was letting out a bit earlier than I was expecting but my takeaway from these pulls is:
- we both suck at roll racing, lol
- the E63 has a TQ advantage and my E61 has a stronger top end
His E63 was completely stock and my E61 is detuned to 500whp down from 550whp. Overall it was neck and neck which I was great to finally see how my E61 stacks up against one of the big boys. Once my LPFP is upgraded (again), 550-600whp + anti-lag would yield different results. I will hold my head high until Andrew gets a tune and makes 700+whp tune only. lol
Here is a link to the very poorly made video I uploaded.
Wagon Weekend: Modified BMW E61 and Mercedes E63 AMG - YouTube
Washy washy
I got an OEM cover to help protect the E61 from UV while the E39 was hogging the garage getting a manual swap and tons of other upgrades.
The slumber of the E61 didn't last long since our X5 got a flat on a road trip to AZ and of course me being me I run a rare sized tire that no-one stocks so after being towed home I uncovered the E61, racked it up, and we left the next morning for Havasu.
For a highly modified, ethanol burning, lowered, straight piped, ethanol burning, 500+whp performance wagon with very short gearing the E61 was a peach just humming along. My fiance and our 2 Australian Shepards arrived safely ...and quickly! lol
Nom Nom Nom
Parking lot pic next to a nice looking Toyota!
I would have a hard time dealing with the ride quality of 20s but for fun I mocked up the 20" Camaro ZL1 wheels I run on the X5.
Used not abused! E61 drying rack!
[IMG]https://lh3.googleusercontent.com/d2ZWKRsXNoMo1Jxu1R38EyhbvJLvIBtHHafLVcgjC7RbcGbaQg p5gBQp7NZJwSRwckFsbNuVDXKQpFlxhRFtyTa06SaT9A-VG_lPtankujQd2hhBUQnEE_vX360W31crB-XHEBWvvYbWe24B9***DQ98--ZMxuQ1t82hxNHWH37pDmmxErosNMGvDJnjcICSb08jS8PejTXk wskJ7TYt2kNRSfnXrwlfrjC8VOc7G-nCtB8BUCcMSJXMK9pzYx7E8AUiRxLVd6YtZSOLt8sE3k33_iiK G_Qzs7NP5QVAM_hgtPi8zFX3h68GihEXL99n7GjY51sDtII0H3 dwbFs6uU0S0hwLjth0y5NX6czDAQ5RU3jSSAX8fD9ExqHibU1A-AT0Ol9zb_6ZPfy6M-_YfVXFVQhtkeL65VzDWgPbHLCULM9Qo8DH_MYr36PChByirfHW BD4hX3KI46LnQ1Z_ZI3bJGMheBK6a2M8nhryLxyjnLaIpMzAcR dth_wI2Mjn6TWu-0KzDkU7NZ-VlAuabyHQzgp_cdSWxEMN-oGEdJcaAvGLMylrNvAQ1z78BIqbzXD2nk2bIv0rMRHiV0XVBFo-DNpB9_Eb9qnvmfsexUuW2IEYwu3jPIDneknoHicQJN243-Ai9HTJFZsjiSc5lEYL9plJbeINVwjWrhA_8M4btNXRv1MOw-rW3qdU238=w1300-h977-no?authuser=0[/IMG]
We bought a house and I am remodeling the garage before I move my stuff in, not much car activity at the moment but I have a nice large driveway that can fit 7-8 vehicles! Room for another project wagon?
My father in law was visiting and this was his first time in the white E61. I took him on a drive through some nice local driving roads but unfortunately my shifter snapped while downshifting into second. It was a bit of a fumble getting this thing home since I couldn't get into reverse and to get the shifter over into the 1-2 gate I needed to use the OEM lug-nut tire iron from the emergency kit white my father in-law held the steering wheel. Unfortunately he didn't get the full experience as my wagon had just reached operating temp prior to the incident but fortunately we got home safely and the shifter will be an easy fix. It made for a great story!
I am helping a guy beta test his monoball bushings for the E6X thrust arms. These are very similar to the monoballs Turner sells. He has excellent pricing and I will be sharing more info once I have them installed. Here are some pics from the builder. Custom monoballs in new Meyle HD arms. I got a set for my diesel X5 too!
Car: 2003 Forester
Default 09-02-2020, 10:52 AM
669 Youtube subs. Nice.
I wish the pictures came up. The only one coming through at my work is the one of the X5 with the flat.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 09-02-2020, 04:18 PM
You can look up this build thread on other forums, pics may be working elsewhere.
Car: 2003 Forester
Default 09-03-2020, 05:04 AM
No luck on 5series.net either. But my work is super strict with ITAR and Secret clearance so the firewall is pretty robust.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 09-03-2020, 09:51 AM
It's also on Bimmerfest, M5Board, SpoolStreet, and E90Post
ucsbwsr's Avatar
Car: 535xi Wagon
Default 10-05-2020, 10:48 AM
It's the 8 year anniversary of owning my white E61 and it has come a long way, most of the changes are small mechanical/functional details which are not easily seen in photos but here are some Before/After photos showing the transformation.
Moving Forward....
Got my shifter repaired by a local machine shop that tig welded it back together.
Monoball control arms arrived which included: front lower thrust arms, front lower control arms, and rear upper control arm, my rear upper guide arms are already M5 units which are OEM monoballs. So this means all the control arms front and rear are now monoballs.
Here are the front thrust arms:
Pics of the front lower and rear upper arms
My front lower bushings were beyond shot
The wagon also got new M5 front wheel bearings, they are essentially the same as RWD 535i bearings but they have 3 nubs to help locate the M5 rotors.
After the suspension upgrades I had an alignment done and boy, what a difference. Steering is sharp and the suspension feels solid and controlled. Yes, there is slightly more NVH but that is the trade off of monoballs and the upside significantly outweighs the minor downside.
One of my close friends just picked up a new-to-him F10 M5 and came to visit this last weekend. We attended a local Cars & Coffee in San Diego.
Wagons!
Up next is:
- New tie rods, new rear ball joints (steering knuckle/integral link connection), raise the front suspension a bit, and another alignment.
- M5 LSD (3.62) to M3 DCT LSD (3.15) swap. 3.62 makes for "fun" acceleration but gears a bit too short for normal driving so a 3.15 will be a welcomed change. The 3.62 M5 LSD will be fitted with a 2.65 210mm ring/pinion from a manual V12 E31 and this LSD will be used in an upcoming 535D E61 build. 2.65 will be great for the diesel engine and the 210mm diff will be strong enough to handle the 600+wtq
Speaking of the diesel E61 project, I also snagged a set of OEM 437M wheels. Here is a peek.
