(#2751)
bmwmick's Avatar
bmwmick bmwmick is offline
Car: z4 35i
Default 06-25-2011, 12:27 PM
They work the same way.
I like the stealth as it lets me also view the oil gauge to see when its up to temperature. And check in on it between runs. The current setup with the delay is pretty good. The only thing I'd improve is often I want to see three things at once. boost, methflow, AND timing. Right now I have to alternate between two of those three. If only we could program the stereo to shout out "2psi... 5psi... 10psi... 15psi!!!"
What a GREAT idea, just interface it to my Zumo GPS and let the little Aussie
girl tell me the boost numbers in her lovely accent. ))
Mick
GSXR_MARKY's Avatar
GSXR_MARKY GSXR_MARKY is offline
Member
Default 06-25-2011, 01:53 PM
Hi Terry, can you not hyjack the digital readout where the MPG etc goes?
2009 135i - JB4 - DCI - Contemplating Meth - Cold Scotish Weather
Default 06-25-2011, 02:29 PM
Not without side effects.
elsabor67's Avatar
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 06-26-2011, 01:18 AM
Terry,
Are the other future use spots being used? Would there be a way to move future use D=10 (Idrive off) to one of the other spots? I was trying to keep Future Use D at #2 for the external AFR. Thanks.
Nick
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 06-26-2011, 12:33 PM
LOL.... that would help cover up your wife saying slow down..... slow down... slow down!!!!
Throttle's Avatar
Throttle Throttle is offline
Car: 08' 335xi
Default 06-26-2011, 04:03 PM
Originally Posted by xbox_fan
I have the same issue lately, but only when I use an extra usb cable, since the jb4 one isnt really long enough once routed into the glowe box.
If youre using a extra usb cable try without it, might help...
Same problem here with XP. I installed the USB drivers and still get "unknown device". I uninstalled and reinstalled the JB4 software USB drivers, restarted etc. and still nothing.
Is there anything else I can try?
Default 06-26-2011, 04:10 PM
My wife won't drive in any of our sports cars, lol.
Bash Bash is offline
Car: E92- 335i
Default 06-27-2011, 06:04 AM
With new firmware car has become more sluggish down low, i dont know if this has to do with throttle oscillation, it didnt do well with my car autotuned at 11 psi.
Running map 1 now, feels way smoother and more powerfull low to midrange.
GSXR_MARKY's Avatar
Member
Default 06-27-2011, 10:16 AM
Try a windows update!
ynoty3k ynoty3k is offline
Car: e92 335i 6MT
Default 06-27-2011, 11:22 AM
p3 cars v2 vent display is another option for more read outs
2008e90 2008e90 is offline
Car: 08 e90 sedan
Default 06-27-2011, 02:23 PM
Is there anyway to hijack that BIG red alarm light under the rearview mirror to light up when the vc2 system X detects that it is running low on fuel? Without the cmgs controller, it's hard to tell seeing as how the VC2 is mounted in the trunk. Can the JB4 work that?
Byoung8's Avatar
Byoung8 Byoung8 is offline
Car: E90 335i 07
Default 06-27-2011, 03:26 PM
I love the way stealth works now. It's my new preferred in dash gauge setup.
I like it too now, but I have noticed when it's engaged, it just sits at 0 boost on fuel, but I know it's working because it worked on a previous run. Anyone else getting this glitch?
Car: 08 e90 sedan
Default alarm light - 06-27-2011, 04:29 PM
Terry, Is there anyway to hijack that BIG red alarm light under the rearview mirror to light up when the vc2 system X detects that it is running low on fuel? Without the cmgs controller, it's hard to tell seeing as how the VC2 is mounted in the trunk. Can the JB4 work that?
i2istudios's Avatar
i2istudios i2istudios is offline
Photog
Car: 335 Coupe 6MT
Default 06-27-2011, 08:47 PM
Terry, can you hack the red alarm to work like a shift light? :D
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 Hardwired / Center Armrest Pouch / JB4/ BT
carlmike carlmike is offline
Car: 135i Conv JB3
Default Stealth Mode - 06-28-2011, 01:38 AM
Hi Terry,
I agree that 50% throttle for stealth mode is to sensitive. I trigger it on every rev-matched downshift, so I eventually turned it off. Is there a way to make this threshold one of the user defines using the labtop interface?
Thanks,
Michael
Originally Posted by pinoy
hey Terry, that gauge hijacking with delay is working pretty well except I find myself prematurely engaging it on my regular spirited driving, maybe you can bump the trigger back up to 70%, I found that worked better on the last builds.
drfrink24 drfrink24 is offline
Car: FBO 335xi w/FSB 50/50 meth
Default 06-28-2011, 05:42 AM
How about hijacking the adaptive cruise bars to do our bidding? I don't even have adaptive cruise, so not sure if it's even possible to illuminate those lights.
BMWpurist's Avatar
BMWpurist BMWpurist is offline
E90post reject
Car: Overpriced Econo Box
Default 06-28-2011, 07:09 AM
Hey! Terry
Regarding max cooling when ON is there a way to make it kick in only when the car starts moving that way the car doesn't sound like a jet aircraft that's about to take-off when you're waiting in the car with the engine idling?
GSXR_MARKY's Avatar
Member
Default 06-28-2011, 07:12 AM
Originally Posted by BMWpurist
Hey! Terry
I would say in some instances you would want it on when the car is stationary!
BMWpurist's Avatar
E90post reject
Default 06-28-2011, 07:19 AM
The stock cooling can figure that out..just an idea,maybe another cooling mode between stock and max cooling.
GtiGyver GtiGyver is offline
Default 06-28-2011, 09:36 AM
Any way to force engine into limp-mode without triggering a code?
This could be alternative way of engaging fuel-saver mode.
The idea is that in limp-mode the wastegates are fully open, and thus probably allow the engine to cruise more efficiently. The downside being that you have little to no power.
WDBi's Avatar
WDBi WDBi is offline
Car: any
Default 06-28-2011, 09:46 AM
just uploaded new firmware car feels so much smoother and i love max cool its great for those hot florida summer days
prelude2perfect's Avatar
Car: '07 335i
Default 06-28-2011, 10:01 AM
Hey Terry, just wanted you to know that I completely agree with you about the new stealth gauges. Much better than before, thanks!
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Default 06-28-2011, 10:43 AM
Typically you'd expect better gas mileage with wastegates fully closed as it allows some of the lost heat energy to be recycled. In practice, I doubt it matters much either way. But we'll look in to it. Most of the MPG gains we've found come from leveraging the DI system with leaner than normal air/fuel ratios during low throttle cruising.
Default 06-28-2011, 12:23 PM
Agreed. Ideally, leaning out the AF would be best, it would be interesting to view the instantaneous MPG using various techniques.
Lean-out AF, open wastegates, alter valve timing... of course there is only so much one can do with a piggyback, and considering the price of the JB4, it does far more than any flash I know of.
Car: 08 e90 sedan
Default 06-28-2011, 03:23 PM
so no on the red alarm light being able to be hijacked?
