Default N54 Port Injection - 01-19-2015, 03:08 PM
Making this thread for updates, details, and general discussion of port injection.
We offer several Port Injection kits now:
Fuel-IT Basic: https://www.burgertuning.com/product...-injection-kit
Phoenix Replacement PI Manifold: https://www.burgertuning.com/product...ntake-manifold
Fuel-IT Deluxe: https://www.burgertuning.com/product...l-line-adapter
In addition we offer various add ons like:
JB4 Port Injection Controller for Easy Integrated Control: https://www.burgertuning.com/product...la-cart-299-00
Fuel-IT Matched Injector Packages: https://www.burgertuning.com/product...ev14-injectors
And of course replacement gaskets: https://www.burgertuning.com/product...-set-6-gaskets
Frequently asked questions:
What is the low pressure requirement for port injection?
For up to 600whp the Fuel-It Stage1 low pressure kit is required. For higher power levels the Fuel-It Stage3 low pressure kit is required. The Fuel-It Stage2 falls somewhere in between in terms of power support.
Can I use port injection along with my water/methanol injection kit?
If equipped with WMI we suggest either removing it or going down to a single CM3 or CM5 nozzle primarily for cooling. When using the BMS PI controller the FSB orange wire will remain in place for the WMI trigger but the FSB blue wire will stay disconnected as its replaced by the PI controller signal.
What is the difference between the SplitSecond AIC6 as a stand alone and the JB4 PI controller?
The AIC6 is a simple stand alone system that allows mapping of port injection as a function of boost pressure and engine speed.
The JB4 port injection controller is fully integrated solution allowing enhanced port injection mapping and safety.
For example the JB4 port injection controller:
1) Uses low fuel pressure in conjunction with boost pressure to evaluate injection pressure and adjust PI IPW dynamically as required to maintain consistent flow volume. This becomes particularly important in applications that are the edge of their low fuel pressure supply. As low pressure drops or oscillates port injection IPW must be dynamically adjusted to avoid run lean conditions.
2) Monitors pedal input, clutch input, gear, throttle position, etc, allowing more advanced mapping and instant cut of PI when letting off the gas or when traction control kicks in to avoid backfires.
3) Monitors AFR in both banks and can cut PI flow in the event a misfire event is detected preventing a potentially lean condition.
4) Monitors current through the injectors and sends a signal back to the JB4 altering it of various problems including a clogged or disconnected injector, blown electrical fuse, loose ground, etc.
5) Monitors fuel trims in each bank and failsafes in the event of a mismatch of more than 15% indicating a potential boost single cylinder boost leak or injector flow issue.
6) Allows easy user adjustment of overall fuel volume using linear "Fuel Bias 0-100" values by RPM, greatly reducing the typical mapping complications when making manual tuning changes.
7) Integrates in to the JB4 multi-map system which produces on the fly PI mapping changes when you change maps, when boost is reduced in lower gears, or during anti-lag engagement.
8) When equipped with a JB4 integrated flex fuel sensor or JB4 virtual flex fuel sensor can automatically adjust port injection volume based on E85 mixture allowing for easy mixture changes.
9) Enhanced mapping logic such as tip in supplement to boost port injection during sudden transitions like spool up or gear changes where the high pressure pump tends to have problems keeping up.
10) Does not require a separate interface and cable for mapping and tuning port injection. It's all done right through the JB4 interface and logs greatly simplifying the process.
11) Includes an extra output to run your second fuel pump OR WMI PUMP (for port injection meth), eliminating the need for an extra Hobbs switch.
Default 01-19-2015, 11:03 PM
I don't want to derail this thread...so this will be my last comment here.
No, I wouldn't run meth with "it" either.
Just to be clear and not take anything away from what is a well crafted and tested solution with this port injection setup. What we will be offering is not intended for the big horsepower guys. It's for the guys on stock frame turbos making 450-550 whp that need a decent bump in fueling capacity.
Also, when running high concentrations of ethanol, IAT's become even less important as ethanol is very detonation resistant. And yes...their will be cooling properties as well, just as there is with this and high concentrations of ethanol.
trebila's Avatar
trebila trebila is offline
Default 01-20-2015, 09:12 AM
can't wait for this
Default 01-20-2015, 01:24 AM
Damn, that was much quicker than I thought...
Steve 335i Steve 335i is offline
Car: 2009 BMW 335i
Default 01-20-2015, 08:06 AM
This looks awesome. Not something I need at the current time, but you never know for the future
Would you need to walnut blast before installing this to make sure everything is nice and clean? I'm assuming this would also prevent build up going forward?
2009 E90 335i
Default 01-20-2015, 09:20 AM
I don't know about fuel rail fitment for the N55 but I am curious. If it fits the N55 it may also fit the S55. Which desperately needs more fuel.
BostonShant's Avatar
BostonShant BostonShant is offline
Default 01-20-2015, 09:27 AM
I was talking about the injector right to the throttle body but if the PI works for N55 thats even better lol
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
Default 01-20-2015, 09:30 AM
I'm sure Steve will make a thread to discuss that solution when he's ready.
Default 01-20-2015, 09:34 AM
good point...sorry didn't mean to hi-jack your thread lol.
looking forward to your results with this kit!
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
1///M's Avatar
1///M 1///M is offline
Car: BMW 1M
Default 01-20-2015, 09:44 AM
What benefit will this make on stock frame turbos either stock or RB?
Will this increase our power or just mean no more meth usage
RHD Top Mount ST
1///M's Avatar
Car: BMW 1M
RHD Top Mount ST
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 01-20-2015, 12:07 PM
Excellent question !
Any idea please
The car has the following steps, jb4 , full bolt ons, Rb, forged internals and vac cylinder head stage 1 and my trouble avg ign retard (9.1)
. Thanks in advance.
Car: BMW E90 335XI
Default 01-20-2015, 01:45 PM
Any idea please
Any idea please ?
Do more with less !
The Leopard's Avatar
The Leopard The Leopard is offline
Car: E92
Default 01-20-2015, 01:48 PM
Any idea please
The benefit is not having to mix fuel, not running meth, cooler combustion, and perhaps more knock resistance. The built motor part won't matter here.
TS N54
Car: BMW E90 335XI
Sorry Id say "specs"
Default 01-20-2015, 12:49 PM
Looks like the injectors will be in Thursday. Now I just need to make a few harnesses!
Car: E92
Default 01-20-2015, 01:06 PM
Awesome, please update your site so I can click add to cart
TS N54
BostonBeemah's Avatar
Car: AW 135i
Default 01-20-2015, 01:19 PM
+1
RIP 2008 AW/BL 135i
gunda gunda is offline
Car: BMW 335i E92
Default 01-20-2015, 01:01 PM
Hey Terry,
What if we used this as direct port injection for water/meth instead of for fueling? Something like this:
http://www.e90post.com/forums/showthread.php?t=947629
Would it be a good idea/upgrade from the chargepipe/meth bung setup? It should ensure that all cylinders are recieving an equal amount of the water/meth.
Default 01-20-2015, 01:28 PM
Originally Posted by gunda
Hey Terry,
At this time if using the PI we suggest removing any meth kit & capping the bungs.
JETmn JETmn is offline
Car: 2011 335xi
Default 01-20-2015, 01:25 PM
How long until this is ready for N55 (E90) use?
Default 01-20-2015, 01:27 PM
It's not been tested on the N55 and I have no idea IF it will work at all or when we'll be able to test it.
Car: BMW E90 335XI
Default 01-20-2015, 02:00 PM
Are you sure you understood the question ? I can't see any insisting phrase for my built engine ? Just wanted to learn if it is a good way for better fueling!
Do more with less !
Car: E92
Default 01-20-2015, 02:03 PM
I'm sorry, your English is broken and not in complete sentences (with no direct question posed), so we have to guess at what you're asking.
TS N54
Car: BMW E90 335XI
Default 01-20-2015, 02:22 PM
my English is better than your Turkish ,if you look in a good intention , saying get out of here instead, you'll see language doesn't make a sense that much. Thanks for your respect!
Do more with less !
