kyle_rg85 kyle_rg85 is offline
Car: bmw 335i
Angry MHD BEF causing 4.5k rev limit - 10-15-2018, 05:15 PM
Hi guys, first post here. I have installed the MHD back end flash on my 07 335i and for some reason it causes the car to rev limit at 4.5k rpm. It's driving me nuts. No codes. I've installed it before and sometimes it doesn't do this. I've tried different DCAN cables, same thing. Used both race and pump flash, same thing. Installed stock map first and then completely reinstalled the BEF, no change. Fully charged battery with charger hooked up during install. Let the car go to sleep after the install. WTF!!! Any ideas guys?
Default 10-15-2018, 06:19 PM
Log?
2step installed?
Car: bmw 335i
Default 10-15-2018, 06:28 PM
Sorry don't have a log right now but i'll get one soon, not sure what use it would be? No 2 step installed. If I revert back to stock map (4/3) it does not rev limit, turn the BEF back on (4/2) and it limits again
Default 10-15-2018, 07:02 PM
Doesn't add up so post a log!
duracell8 duracell8 is offline
Car: 2008 535i
Default 10-16-2018, 04:25 PM
Just guessing here but seems like u have misfires not rev limiter. Common symptom after installing a bef or JB4 is chronic misfires. Mileage? Mods? Logs?? Without u posting the basic info necessary I’m just assuming ur relatively new to the platform/tuner and should start with the basics before assuming more complicated that the obvious. Is auto delete on? Did u get the tuner brand new or second hand?
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Car: bmw 335i
Default 10-16-2018, 05:48 PM
Originally Posted by duracell8
Just guessing here but seems like u have misfires not rev limiter. Common symptom after installing a bef or JB4 is chronic misfires. Mileage? Mods? Logs?? Without u posting the basic info necessary Iím just assuming ur relatively new to the platform/tuner and should start with the basics before assuming more complicated that the obvious. Is auto delete on? Did u get the tuner brand new or second hand?
Nope not misfires, it's a clear rev limit caused by the back end flash. Like I said above if I turn the back end flash off the issue goes away, back to normal rev limit. It's very annoying, no one knows why it's doing this. I have XHP transmission flash as well which could be interfering with the BEF for some reason as well. I've reinstalled it several times as well as the BEF. Still working on this annoying issue
Haynpunch's Avatar
Car: 07 E90 335i
Default 10-16-2018, 06:34 PM
Are you using the right BEF?
07 E90 AT 335I 130k
JB4 G5 - Race BEF
DCI
VRSF CP - TS RP BOV-Orange Spring
VRSF V2 D-P's
7" FMIC
Stage 2 Bucket
Car: bmw 335i
Default 10-16-2018, 06:51 PM
As far as I know yes, I have the I8A0S hardware so I used the BEF marked as "JB4_BB2_I8A0S_PUMP" and I used the race flash as well. It's frustrating because I've gotten it to work before, it's just sometimes if I have to re flash it it will do this rev limit thing
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 10-16-2018, 07:28 PM
It's not your BEF. You can't turn off the BEF because it's in the DME. When you go into map 4-3, you're telling the JB4 you have a stock DME. (as per Payem reply to one of my questions)
Take a good look at your JB4 settings. Me thinks you may be in valet mode.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, E85 BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
Car: bmw 335i
Default 10-16-2018, 07:46 PM
Interesting, any idea why it would go away when I go to 4/3? And only comes back when I turn the BEF on? (4/2). I didn't know jb4 had valet mode, I'll try to find that, or maybe the BEF has some kind of valet mode
Car: bmw 335i
Default 10-16-2018, 07:56 PM
ya tried to toggle valet mode of and off (4/7), not working. The car is basically stuck in valet mode whenever the BEF is enabled
Car: bmw 335i
Default 10-16-2018, 08:23 PM
I'm reading that some people are saying 4/2 and 4/3 are to toggle transport mode on and off? Was this on some old jb4 models? If so, which one turns the BEF on and off on my car if I have this old jb4?
Car: bmw 335i
Default 10-16-2018, 08:48 PM
ok looks like I had old firmware where 4/3 and 4/2 were to toggle transport mode on/off, I thought it was for turning the BEF on and off like the latest firmware. Updating it now.
Default 10-16-2018, 08:53 PM
Don't leave TRA on it will cut out regardless of flash.
Rickster1269 Rickster1269 is offline
Default 11-03-2018, 09:09 AM
Did updating work for you Im still having the same issue
Car: bmw 335i
Default 11-03-2018, 09:14 AM
Yes, solved the issue. The menu is different in the old jb4 firmware so 4/2 and 4/3 turn valet mode on and off
Default 11-03-2018, 09:39 AM
If TRA shows in dash you need to turn it off!
Default 11-03-2018, 12:17 PM
Tra Mode is not displayed
Default 11-03-2018, 01:31 PM
Then you must have a other issue. 2step installed?
Default 11-03-2018, 01:35 PM
No sir no 2 step
Default 11-04-2018, 12:54 PM
Then log issue coming up.
