DetroitN54 DetroitN54 is offline
Car: 2009 135i
Default Finally going to the dyno! What do you think? - 10-05-2016, 04:23 PM
Alright guys, almost dyno time for the first time on the BMW! Will be going Saturday morning, just want to get some thoughts on what numbers you think I'll post up!
2009 135i M-Sport
Auto w/paddle shifters
MHD Stage 2+ 93 oct version 6 (think V7 is more power?)
Dual cone intake
BMS chargepipe
VRSF 5 inch stepped FMIC w/ pipe upgrade
VRSF ********* down *****
Berk midpipes
Stock muffler
I did see a similar setup on youtube producing 425hp/465tq to the wheels, I am happy to reach 400hp.
Car: 335i, 2009
Default 10-05-2016, 04:32 PM
With what fuel? No chance you are going to put down 400 WHP with those mods with only 93 octane. Put in 100 and run the race map and then we will be talking I ran similar mods with 91 oct, without MHD, and had 80% methanol. I put down around 390 WHP adjusted. If you are running 93 Octane I would guess 380 HP tops.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
N54QC N54QC is offline
Car: 07 BMW 335i
Default 10-05-2016, 04:50 PM
I would be surprised to see over 400hp also.
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 10-05-2016, 06:28 PM
380ish whp
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
LQQKOUT's Avatar
LQQKOUT LQQKOUT is offline
Car: 335XI
Default 10-07-2016, 05:06 PM
415's my guess
Irishace's Avatar
Irishace Irishace is offline
ElevenPointFive
Car: 2009 135i
Default 10-07-2016, 06:34 PM
Report back as to your results. I have pretty much the same setup except I am 335xi so should be more parasitic loss at the wheels than your RWD car.
2007 Porsche 997 Turbo - 6MT - Midnight Blue
Cobb Stage 1
2008 E90 335xi - AT - TSM
MHD Stage 2+ ~ BMS Intake ~ AMS FMIC ~ CPE
duracell8 duracell8 is offline
Car: 2008 535i
Default 10-07-2016, 09:33 PM
Don't forget the paddles shifters add 10 hp.
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Car: 07 BMW 335i
Default 10-09-2016, 08:21 AM
So OP, what were the results?
Car: 2009 135i
Default 10-09-2016, 09:15 AM
Dont hate me but I had to reschedule for the 22nd! I had a family emergency come up, sorry guys, but I will for sure be going the 22nd
Car: 2009 135i
Default 10-23-2016, 09:40 AM
Well not what I expected, realistically I was expecting closer to 380-385hp.
Hit 369hp and 415tq. Our cars must be light with that power to weight ratio because the car is quick lol. Maybe cleaning the intake valves with the walnut blast well help the motor breathe easier and free up a couple numbers?
https://youtu.be/BUINS-8g1nw
J.J4ck0wsk1 J.J4ck0wsk1 is offline
Car: N54 335i FBO Meth
Default 10-23-2016, 09:59 AM
I made 426/484 on a mustang dyno with everything besides inlets and outlets with meth. Now I'm running more e85, a better tune and hope to be at 440-450/490-500 on the same dyno. If I could do that without inlets/outlets on a custom tune at 22psi I'd be very happy, the 426 run was also at 18.5psi or so.. Just to give you a perspective.
Default 10-23-2016, 11:14 AM
Get a JB4 on there and we can help you dial in a stronger setup using MHD for a backend flash map.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 03-01-2017, 04:24 PM
You could make a lot more with tuning and fuel changes, Agree on adding JB4. Also try out E85 with the right MHD BEF - pretty sure that alone would put you over 400 whp.
I'd say your next hardware mod should be Stage 2 LPFP.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 03-07-2017, 03:04 AM
Wasn't there a tread about Terry making 400hp on a test vehicle with minimal bolt ons?
LessIsMore's Avatar
Inner Circle Member
Default 03-07-2017, 09:26 AM
I recall a thread (that was not Terry) about a JB4 + DCI + inline pump N54, with no other mods, making 400 whp ... I don't recall what fuel, but in any case I don't think that's representative of what one can expect with so few mods.
However, comparably to the OP -
FYI, I made 369whp / 497 tq on a Mustang dyno recently, with stock turbos, FBO withOUT inlets or outlets, and E60 mix (mods in sig) ... and with 150* IAT's that killed power and timing. I think even on a Mustang dyno the car would have made much better numbers if there had been adequate cooling.
2017 AMG C63 -JB4
beastmw beastmw is offline
Default 03-15-2017, 05:14 PM
I put down 350 rwhp with 93 oct, bms dci, and jb4 map 1. 08 335i
