Ripley's Avatar
Ripley Ripley is offline
Car: 335i N54
Default Map 3 as tuning map on N20 without meth installed - 09-14-2018, 06:05 AM
Hello, I'm trying to use map 3 with meth disabled via "User Adjustment -> Meth trigger mode=3".
I would to use map 3 as tuning map. It is possible?
I tried, but nothing happens when I change the additive. The car is blocked to 21 psi peak.
Black Sapphire E92 335i AT: VTT GC 2.0 - VTT inlets/outlet - VRSF 7'' FMIC - VRSF 3'' d p s - JB4 G5 w/ FSB - AEM meth - Fuel-It stage 2 LPFP - BMS DCI - Phoenix Racing CP - TIAL BOV - NGK 5992 - KW V3 - Dinan camber plates - Brembo 8 pot - Pagid RST3 - Mishimoto 25 row oil cooler - Quaife LSD - M3 rear bar - xHP stage 3
Default 09-17-2018, 05:42 AM
Any reason why you're not using map 6?
Ripley's Avatar
Car: 335i N54
Default 09-17-2018, 07:23 AM
Just for safety. It is possible?
Default 09-17-2018, 03:32 PM
I'd have to check the firmware to see what options we have in there with your firmware version. Post a JB4 log so I can see what the setup is.
Ripley's Avatar
Car: 335i N54
Default 09-19-2018, 07:31 AM
Z4 20i N20
