Massius Massius is offline
Car: e92
Default Will dealer know or care about BEF? Going Friday - 05-15-2017, 11:00 AM
Going in for injector warranty. Visible mods will be inlets and dwps. im hoping they dont freak out, but what about the BEF?
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 05-15-2017, 11:15 AM
Dealers can tell when those things are modified.. But, you may be lucky and find a dealer who doesn't care..
MR F30 335i - MSport - Stock AF
Torgus Torgus is offline
Car: 335xi
Default 05-15-2017, 11:24 AM
flash back to stock, if they ask about the parts say the stock one broke and the aftermarket was less expensive and functions the exact same. The part is no different then installing moog tie rods or Koni shocks. Do not go in with a BEF. If I was the dealer I would say nonfactory software put extra strain on the injectors and caused them to fail.
Got Boost?
Car: e92
Default 05-15-2017, 11:28 AM
good point.
dyezak dyezak is offline
Default 05-15-2017, 01:28 PM
I'd agree with this until I found out how dealership warranty work was billed and paid for. From what I understand, if the product is defective (the car) and warranty work deemed necessary then the manufacturer (BMW) supplies the parts to the dealer and the manufacturer pays the dealer for the service tech's time. The time is a predetermined time to perform the work. Injector replacement and coding is 1.5hr.
If I was a service manager, or dealership, I'd replace them no matter what as it is guaranteed income for my service department paid directly by the manufacturer.
But for some reason dealers deny tons of warranty work so I'm missing something.
duracell8 duracell8 is offline
Car: 2008 535i
Default 05-15-2017, 01:43 PM
The issue becomes if warranty claim get denied, then the dealer is out the cost of the parts and labor. Why should they assume the liability on a tuned car? Not enough reward. Believe me, when bmw comes in to audit a dealership, they are out for blood and will find any and all descrepensies that aren't according to the warranty manual. Service managers lose there jobs over it. So again, why would they want to risk it.
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Default 05-15-2017, 01:51 PM
Got it...makes sense. I knew I was missing something.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 05-16-2017, 02:44 PM
Op, if you have a JB4 as well, I'd physically remove it - not just turn it to Map 0.
2009 535i Sport - 548whp
Software :
creepingKrawler creepingKrawler is offline
Car: 2010 335xi
Default 05-18-2017, 10:00 AM
I do believe you can buy the injectors yourself, pay an indy shop to replace them & then submit a claim to bmw to get your $ back. This is the route Im gona go.
Newguy123's Avatar
Car: 12' 135i
Default 05-18-2017, 10:02 AM
take the flash off the car, bmw is cracking down on tuning
18 Glacier white RS3
#PURETURBOS
#FUELIT
Car: 2010 335xi
Default 05-18-2017, 10:11 AM
Yeppers, take it all off if your going in. Ive heard they can blacklist the vin so any futre warranty work will be void. I have too much stuff to yank out so Im going to pay for everything upfront & submit a claim.
Car: e92
Default 05-18-2017, 01:01 PM
I can't take the jb4 out. My dwnps will throw a code in the 2 hour drive it will take to get to the dealer :/
Or is the code less of a big deal than the jb4
Car: e92
Default 05-18-2017, 02:42 PM
hold on, I can just clear the codes with my MHD cant I? Never used it for anything other than the BEF.
Car: 335xi
Default 05-18-2017, 05:17 PM
Yes you can clear the codes with mgs. Do it when you arrive? One look and you can see the aftermarket ******** are installed so give it a shot. 2h to the nearest stealership?
Got Boost?
Car: e92
Default 05-18-2017, 05:45 PM
Yes it's a pita to get to the dealer. I have to take a day off.
Jb4 out and flashed back to stock. Appointment is 9am, Wish me luck!
Car: e92
Default 05-19-2017, 09:27 AM
Dealer had me leave it and gave me a 320i.
On first inspection they can't get any codes to warrant the injector replacement so they are going to see if they leak overnight.
We will see what happens in the morning.
Good news. They didn't care about the relocated inlets, dwnps, charge pipe etc. I cleared the codes but they poped again in their hands. They didn't care.
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 05-19-2017, 09:37 AM
Take care of your SA when you go back to pick up the car, this goes a long way!
Speaks volume "THANK YOU" $50-100 wont hurt you if they're covering your modded car
F80 ZCP DCT Tune Only | BM3 Custom F80Paul E85 100-200 5.9s, 60-130mph 6.7s "World Record Dragy Verified"
-HCP E60 60-130 7.3
-HCP E40 60-130mph 7.6s
-BM3 E30 OTS 60-130mph 7.8s
[ Pending: CTS Turbo D.P/CP/HE/Midpipe
WR X4 M40i CTSTurbo D.P/FMIC BM3 STG2 93 4.19s 0-60 | 12.4@109mph 1/4 m
$ECA $XRP $XLM $TRX $ADA
Newguy123's Avatar
Car: 12' 135i
Default 05-19-2017, 10:37 AM
exactly i always do this. its really up to the tech not the SA. i always give the SA a SBUX card and then tell him to let the tech know the envelope in the center console is for him. usually put a $50 in there
#PURETURBOS
#FUELIT
Car: e92
Default 05-19-2017, 10:52 AM
never knew that, ill take care of him. thanks for the tip.
Car: e92
Default 05-22-2017, 02:02 PM
They still have the car. they called today to say they are not getting any codes and basically need one to be able to replace them.
Car: e92
Default 05-22-2017, 02:58 PM
GOOD NEWS! Dealer called. They are going to go ahead and replace the injectors because they noticed it misfire on coldstart.
sosn54 sosn54 is offline
Car: BMW 335I Xdrive
Default 05-23-2017, 05:31 AM
My SA did not care about mods either. I had my injectors, HPFP, and even plugs replaced at no cost.
He said to come back in a couple months to my turbos looked at....
2010 E92 335iX, JB4 G5 ISO, MHD RACE BEF, N20 TMAP SENSOR, VTT GC Lites, VTT Inlets Outlets, BMS DCI, VRSF c.a.t_less D.P., VRSF 7.5" Race FMIC, VRSF Charge Pipe with tial BOV, BMS Meth Kit, BMS OCC, Boost Concept Stage 2 LPFP., 335iS Clutch, MFactory Single Mass Flywheel, CFS High Performance Aluminum Radiator, N55 exhaust.
Car: e92
Default 05-23-2017, 01:50 PM
Just got the car back from BMW with 6 new index 12s.
dont let anyone tell you the N54 direct injection HAS to be loud. these 12s are barely audible. at least for now
Car: 2008 535i
Default 05-24-2017, 05:42 PM
New injectors have different internal compensating fluid. Different sound.
