Car: 08 535i
Default Remove dynamic drive sways? They are leaking. - 05-21-2017, 10:31 PM
I plan to repair my leaking dynamic drive sways. But have thoughts of completely removing this system. I feel like having solid sways will eliminate one more thing that can go wrong as it currently did.
I plan to remove them, clean them, reapply new sealant to the boots and re-install. Not sure if this will work, but it beats paying $1800 for a new sway bar. For that price tag it has to be less expensive to remove the system.
Pump
Ryan
Default 05-22-2017, 07:03 AM
How is this thing mounted to the subframe?
N54 | Build Thread
dyezak dyezak is offline
Default 05-22-2017, 08:25 AM
If you were to remove them the easy part will be the physical replacement to a normal swaybar. You'll also need to code out that option on your car. Most dealers can probably do it, but I doubt any shadetree coder has figured out that obscure option yet.
Tuppidsay Tuppidsay is offline
Car: 2008 535i
Default 05-23-2017, 09:39 PM
They all leak, 5s, 6s, 7s, x5s etc. mine were leaking with 40k on them. Just top off with an ounce or 2 every oil change.
2008 BMW 535i SPORT - FBO - VTT GC V2 - JB4 - Duane Pugh BEF - Bms PI Meth
christoepurrr christoepurrr is offline
Car: E60
Default 05-23-2017, 10:05 PM
Replace it with another dynamic/active sway bar? Plenty of guys parting E6x's nowadays, I usually see a few on Craigslist that are local.
Car: 08 535i
Default 05-23-2017, 10:49 PM
I'll snap some pics tomorrow.
Car: 08 535i
Default 05-23-2017, 10:50 PM
Im actually th8 nkingnof learnimg how to code and maybe try myself if it gets to this point. I'm optimistic.
Car: 08 535i
Default 05-23-2017, 10:53 PM
Thats the plan for now. I'd like an inexpensive fix or removal of them. I hate leaks, donut will get resolved.
Car: 08 535i
Default 05-23-2017, 10:56 PM
Id like to find a more permanent solution than to put another unit that will leak. Even new ones will eventually leak and are not guaranteed to last.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 05-23-2017, 11:53 PM
Removing the system is a bad idea. Headache plus you lose the positive effects of dynamic Drive . Replace with a new or used unit, or fix the current one.
2009 535i Sport - 548whp
Software :
Car: 08 535i
Default 05-24-2017, 06:44 AM
My first fix will be to try to find a way to reseal the boots to the pump and shaft. For the best seal I would need something that dries a little flexible bit will bond to the materials of the pump, bar, and boot. Oh yea, and it has to be resistant to oil.
Maybe I could spray my sway bar with that spray sealer in a can you see on tv that will seal anything. Totally joking.....can anyone recommend a product that fits my description above.
Car: 2008 535i
Default 05-24-2017, 06:52 AM
Rtv gasket makers/sealant will fit that bill. I'd stick with the black. You dont want Grey as it dries rigid. And other colors are for specific purposes that don't apply to what you are doing.
duracell8 duracell8 is offline
Car: 2008 535i
Default 05-24-2017, 05:33 PM
After removed, how will u plug the lines going to it?
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Car: 08 535i
Default 05-24-2017, 06:21 PM
A threaded bung with thread locker, I'd imagine.
I would crossreference parts from a non dynamic drive 535i and replace parts accordingly.
But i doubt the system will be removed.
Car: 08 535i
Default 10-31-2017, 09:08 AM
It doesn't look like removing this system is all that bad. I removed the front dynamic drive and repaired the leaking boots. After being in there, I am convinced this system will be much easier to remove and install than I had originally thought. First thing first. Here is a thread I started detailing how I fixed the leak.
http://www.n54tech.com/forums/showthread.php?t=50028
Now here is a list of all the parts I will be removing if I move forward.
Front:
Rear:
I may create a separate post about selling this system if anyone is interested in these parts. If you know anyone that has an E60 and wants to convert to dynamic drive, please let me know!
Ryan
Car: 08 535i
Default 10-31-2017, 09:19 AM
Forgot to compare pump and steering lines. more research needed. Which is good because I noticed my active steering is leaking on the steering column. I will be posting about that later.
Car: 08 535i
Default 11-08-2017, 04:51 PM
Just landed a parts car that does not have active steering or dynamic drive. So this Removal will be happening soon. If anyone knows anyone that may be interested in retrofitting these options in their e60 please let me know, I will have a complete e60 DynamicDrive/ActiveSteering Retrofit soon. I would prefer to leave my car wired for these features, but if I get a good price I may separate the wire harness from the computers to fuse box to end devices, but the price would have to be really good for that. But then there should be no soldering and have all oem wiring in the car.
Contents will include:
-Active Steering rack
-Active Steering computers
-Dynamic Drive front and rear sway bars and mounts
-Dynamic Drive computers
-Dynamic drive hydro box
-Dynamic Drive / Active Steering power steering pump
-All oil lines associated with Dynamic drive and Active Steering
Some items may not be included as I have kept as many bolts hoses and items that are interchangeable. These items should be found on the car it will be fitted to. Another item that will have to be sourced is wiring., but I will pull all wire harnesses from the car and label for a true oem install. But this will take forever and will cost much extra. You will have to find a source to code in the options.
If you are just passing through, post your thoughts on what I should charge. I have totaled well over $7000 worth of parts and counting; This should include everything needed to install dynamic drive and active steering into a e60.
Remeber....You will be able to sell the items you pull off your car for some reimbursement to cut the cost.
Car: 08 535i
Default 12-02-2018, 11:38 PM
Alright guys,
Dynamic driven is off the car, but I am running into coding issues. Changed the VO and default coded the car. I had an ARS error that Levan was able to clear from the DME, but now I cannot turn off my DTC via the button.
Hopefully i will have a solution tomorrow!
If anyone has a non dynamic drive 535i(rwd) I would love to know your DSC zb# so I can reflash that module.
Car: 08 535i
Default 12-06-2018, 09:05 PM
And time.....
Everything swapped over and properly coded. Now time for m5 sway bars and pull rods then a lsd.
Coding was a nightmare, but after much help from Levan & Brice and an unknown option in tool32 all is well.
I'll post up pics later of what was all removed
