Pat Benatar Pat Benatar is offline
Car: '08 335xi e90
Default AWD, DSC, ABS, and EMERG EBV lights come on at once - 10-08-2016, 07:18 AM
Hey Guys,
As the title states I had the AWD, DSC, ABS, and EMERG EBV lights come on at once last night while driving. The car also makes a loud grinding/disengaging noise when I shut the car off. I restarted it and the lights went away but the grinding noise is definitely still there when I shut it down. Any ideas? It's a 2008 335xi with fbo, spec stage 3+ clutch running e85 on a custom MHD map. Never launch it but I fear it's the transfer case motor. I have around 99k miles on it.
Thanks in advance.
Car: '08 335xi e90
Default 10-10-2016, 03:16 PM
Bump, any ideas?
Car: '08 335xi e90
Default 10-11-2016, 02:04 PM
Transfer case motor $425 part. Not bad, teeth were stripped.
duracell8 duracell8 is offline
Car: 2008 535i
Default 10-11-2016, 03:43 PM
Google replacement gears for the actuator. $25. However this thread is useless without codes !! Help us help u.
2008 535i RB Turbos, ER Charge pipe, Tial BOV, 2.3 gal BMS Meth 75/25, Dual nozzle CM10 and CM7, BMS Race Flash, 3" Down Pipe, JB4 ISO G5, N20 Map Sensor, BMS OCC, BMS PCV Valve, JB4 Mobile App, 12.3 @ 116 mph
Car: '08 335xi e90
Default 10-11-2016, 04:45 PM
A simple please would've sufficed. My tablet died and I figured someone would've had the exact same symptoms. And it isn't useless because it was solved no thanks to you mister.
Car: 2008 535i
Default 10-11-2016, 05:25 PM
If u had posted codes I could of told u about the 25$ gear replacement for the actuator. Ur loss due to not posting codes and I see no one else even attempted to answer. Trying to help u but u refuse. Bye Felicia.
rcpro88 rcpro88 is offline
Car: 535i
Default 10-11-2016, 05:49 PM
I agree with duracell8.
I have learned very fast that without logs or codes its hard to diagnose anything online.
Also you don't have to be a 8==D to forum members. You were posting for help, you should be thankful anyone spent time trying to help you.
Glad your fix is only $500, on these cars any part that breaks tents to cost a MIN of $400-$500.
