(#1201)
boostfeen boostfeen is offline
Car: Q50 RS400
Default 10-08-2017, 02:31 PM
Originally Posted by arsenalfc15
You guys with red sports need to be careful of overboosting.
Terry already confirmed that RS's can handle +5psi on race gas. Also my boost logs haven't had anything on them so far to be concerned.
thatdudesurya thatdudesurya is offline
Car: q50 redsport
Default 10-08-2017, 02:51 PM
I’m debating on trying +6 tonight.
Car: Q50 RS400
Default 10-08-2017, 03:21 PM
Originally Posted by thatdudesurya
Iím debating on trying +6 tonight
I say go for it, and let us know how the car feels
Car: Infiniti Q50 RS400
Default 10-08-2017, 04:27 PM
Anyone running +7 on the red sport or has? Iím at +6 but man...thinking about going to +7 to race my friends bolt on c6 vette.
Met a q60 red sport guy today have been runnning +7 on jb1. He said no issues, he is on e85 mix. I have ran +4 on jb4 on 91. Car pulled really strong, but I toned it down to +3 max tapered.
Default 10-08-2017, 05:09 PM
Originally Posted by Hammer663s
Just did the JB4 upgrade on out 2017 Q50s 3.0T SS AWD. I set up a conservative Map 6, climbing to +4 at 4k and tapering off starting at 6k. WE only run 92 pump gas as there is no ethanol here.
Wife out for a test drive now. She loved the JB1 but felt it was a little harsh.
Mike
Curious to see if she finds the JB4 more civil. I'll post a firmware update tomorrow that enables code read/delete and refines boost by road speed user adjustables.
samuelsm samuelsm is offline
Car: 2017 infiniti q50
Default 10-08-2017, 05:29 PM
hey terry, i dynoed my 2017 3.0t thats currently on map 6 of jb4 with a peak boost of +8 from 4k-6k rpms. just went and got the car dynoed and this is what i got.
https://imgur.com/a/i4X3o
pretty sure it was low due to the heatsoak. all i have is a catback exhaust. the air/fuel at the bottom drops significantly after 4krpm. can someone explain to me why i got so low?
Default 10-08-2017, 05:35 PM
Have the JB4 log to match so we can see the tuning details? If timing is going too rich it might be the DME enriching the air/fuel due to higher calculated EGT readings or could be an indication you have boost turned too high for the octane level.
Hammer663s Hammer663s is offline
Car: 2017 Q50S 3.0t
Default 10-08-2017, 06:53 PM
She likes it a lot more - says it is nice and smooth all the way through 6k rpm unlike the JB1 which she felt was a more abrupt hit. She feels more confident getting on it now.
I haven't driven it yet - been too busy waxing my new F150. Also a twin turbo that will eventually get a tune.
Mike
arsenalfc15 arsenalfc15 is offline
Car: Infiniti Q60 AWD 3.0t Premium
Default 10-08-2017, 06:57 PM
Hey All,
Just ordered the Infiniti Sport Exhaust w/o mufflers and the full. Z1 race p1pes. About to order an intake. For those of you who have the AEM, Stillen, or Powerpro intakes installed, are you able to push all the way to +7psi on the JB1/JB4 and have you had any issues with the intakes?
'17 Infiniti Q60 AWD 3.0t Premium
JB1 +7psi w/ 30% e85
"Form is temporary, class is forever"
Fourg63 Fourg63 is offline
Car: Q50
Default 10-08-2017, 07:13 PM
Hey All,
I had the AEM intakes and while there were no drivability issues, I was getting constant MAF malfunction CELs with them even after the software update. I did get the same CEL code on stock intakes the other day which made me chuckle a bit. My car is super sensitive it seems. My brother had the Stillen intakes on his RS. No CELs but constant drivability problems so he went back to OEM as well.
jrobohm's Avatar
jrobohm jrobohm is offline
Default 10-08-2017, 07:15 PM
Car: Q50
Default 10-08-2017, 07:22 PM
Pretty good numbers, but like Terry said sometimes less is actually more. What fuel were you running? What were the AF ratios and timing? Remember, these turbos are tiny and inefficient at higher boost, overwhelming the cooling system and ultimately producing less power.
Default 10-08-2017, 08:01 PM
VirusbetaX VirusbetaX is offline
Car: Infiniti Q50 SilverSport 3.0T
Default 10-09-2017, 09:45 AM
I noticed that the boost on standard mode is much higher than the boost on sport mode. I was getting peak 12 PSI boost on Sport mode on the silversport under 60MPH. But when i switched to Standard mode i was getting 18.5PSI peak boost under 60MPH.
Q50rs400mc Q50rs400mc is offline
Car: Q50
Default 10-09-2017, 12:26 PM
What do you think, rs awd on 94
psi_curve[0] = 30 '1500
psi_curve[1] = 30 '2000
psi_curve[2] = 40 '2500
psi_curve[3] = 40 '3000
psi_curve[4] = 40 '3500
psi_curve[5] = 40 '4000
psi_curve[6] = 40 '4500
psi_curve[7] = 40 '5000
psi_curve[8] = 30 '5500
psi_curve[9] = 30 '6000
psi_curve[10] = 20 '6500
psi_curve[11] = 10 '7000
Default 10-09-2017, 12:39 PM
You're probably reading boost wrong, then. I dyno tested all the options and all made the same boost/power output.
NeedMoreBoost NeedMoreBoost is offline
Car: Infiniti Q50 3.0t
Default 10-09-2017, 12:55 PM
Hey Terry, Just wondering if the JB4 update will still be released today. If so, will it be posted here or somewhere else?
Default 10-09-2017, 01:14 PM
Yes, still a couple tests to do on it. Will be in 2nd post.
Default 10-09-2017, 02:08 PM
Added new JB4 firmware to the 2nd post.
Enabled boost by speed. Values of 0 disables. Otherwise "1st gear" sets maximum boost added below 31mph, "2nd gear" sets maximum boost added below 55mph, and "3rd gear" sets maximum boost added below 84mph. Generally speaking this feature will be used by RWD vehicles and in most cases only in 1st gear, with a setting of say 2psi in 2nd gear to assist with traction as needed during launches.
And here is a log of that function in action. I've set 1st gear to 1psi, 2nd gear to 2psi, and 3rd gear to 3psi, so you can see in the log how the feature works.
g0t2bmiirii's Avatar
Default 10-09-2017, 02:33 PM
Terry what’s going on with intakes? You were suppose to give us an update...
-D0WNP!PES + Catback[resonated]
-BMS Cold Air Intake
-JB4 (map 6) w/Fuel Wires (93oct)
Default 10-09-2017, 03:56 PM
The first production units are still not on my desk. When I have them expect to see a post in this thread about it.
Default 10-09-2017, 05:32 PM
So, installed the jb4 firmware, limited 1st gear to 1 psi. Definitely gave the car some traction. When I come out from a turn on a stop, I usually hear the tires burn at half throttle. Now it takes a little more to burn tires from a stop, but it just goes, no wasted power from spinning. Again, thank you Terry.
Default 10-09-2017, 07:22 PM
any benefit to AWD vehicles? ill stilll update as there is other functionality enabled with this update, just wondering. Btw you were right about before the Sport mode just draws out the gears longer, i just feel the difference in standard mode more than in sport mode.
Default 10-09-2017, 07:27 PM
No need to limit boost on AWD cars, from what I've seen so far.
Car: Q50
Default 10-10-2017, 01:04 AM
So who is gonna be crazy enough to run 17psi in 1st and 2nd or is there a limit to how high we can raise it via this update?
