(#776)
map3215.9 map3215.9 is offline
Car: 2020 bmw m5comp
Default Log for 2020 m5 comp - 09-14-2020, 10:15 AM
Itís on the above post from 1 week ago
BigChiefM5comp BigChiefM5comp is offline
Car: 2020 M5 competition
Default new to the platform and the tuning. - 09-14-2020, 05:20 PM
finally got my jb4 connected to my phone and am running map2. I updated to v9 firmware I see is there newer versions then these as well? now what is needed to adjust in the app to make sure all my settings are right for my setup. just have a ********* and the jb4 currently and primarily run 93 only. did a code check and one popped up for intake manifold with plausibility of pressure too high? just need insight on what I am doing as I am not sure. new platform
Default 09-14-2020, 07:54 PM
Load up v10 firmware and evaluate map2. If you have any issues/codes just email me a log and I'll help you sort it out. terry@burgertuning.com
Down4it's Avatar
Down4it Down4it is offline
Default 09-24-2020, 02:03 PM
Hey Terry, I'm going to try out V.11 later. I'm on V.10 map2 4gals of E85 16gals of 91 and running strong! I changed the DB to 50 from top to bottom and was just wondering what affect that has? Quicker to boost in the lower RPMs?
Default 09-24-2020, 02:13 PM
It's just the default for how WGDC is applied, 50 is the same as 0. But some people have random numbers or lower numbers which would reduce boost targeting.
Morebs4me Morebs4me is offline
Car: 2013 550i m-sport
Default 09-25-2020, 06:09 PM
You don't run lean on that much ethanol? Are ppl running 4-5 gallons of e85 now I thought it couldn't add enough fuel to keep up.
Down4it's Avatar
Default 09-25-2020, 06:46 PM
Everyone that has been running it has been happy and people are running up to 6 gallons but it's not recommended. At 4gal with another 16gal of 91oct its like running E20, 6 gallons would be E30 and then you're starting to push the fueling limits from what i understand.
Default 09-25-2020, 06:55 PM
Did terry say he doesn't like dp for the car? How come?
Default 09-26-2020, 01:15 PM
20% E85 has been working pretty well for most customers. Some are able to get up to E30 before the JB4 triggers a lean safety.
Default 09-28-2020, 02:33 PM
Had a couple reports of the BC menu for changing maps between 0, 1, and 2 not working in the most recent firmware. Anyone here have a similar issue with it?
