eboosted eboosted is offline
Car: M235i
Default FBO M235i, what's next? - 07-18-2016, 10:47 PM
I have a M235i EWG with JB4 runing map 5, *****ted **, BMS intake, ER FMIC, OCC and chargepipe.
What would be the next step? Would you guys suggest to try a custom map setting?, turbo upgrade or a fuel it kit? We don't get E85 around, just 93 pump gas
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 07-18-2016, 11:08 PM
You need higher octane so if you do not have E in your location I would invest in a methanol kit. After that I would be looking at a bigger turbo.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 07-18-2016, 11:45 PM
+1
Get more octane as you'll be octane limited very soon and methanol injection is a solution if you don't have race gas or ethanol. Meth injection also helps with fueling which you'll need if you plan to push further as the F series n55 have really weak hpfp's. After that go for a pure stage 2 turbo as stage 1 isn't worth it plus you save on labour if you change your mind in the future.
Mods: Stock for now
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 07-19-2016, 05:42 AM
/thread
You got the correct answer above.
--2009 BMW 135i--2016 Nissan Titan XD (Turbo Cummins ISV)--2016 VW Tiguan 2.0Tsi --1988 Beechcraft Bonanza--Suzuki GSX-R 1000--Honda CBR-600RR--
JB4 G5 ISO | MHD | E85 | Fuel-It S3 LPFP / PI | MFactory S3+ Clutch / SMFW / LSD / Mounts | Diff Lock | UUC Tranny Mounts | DwnPipes / Exhaust / FMIC | Chargepipe / Tial | KW V3s | HR Sways | HPA full M3 Suspension | BMS DCI / Oil Cooler Valve / Cowl Filters / 4bar / 2Step / OCC | RB PCV | Stri Gauges | Pole Position 225/265 | Installing: DR 6466ST
