iversoncreative's Avatar
iversoncreative iversoncreative is offline
Car: 2008 535xi
Default First Log Review - 10-01-2020, 10:10 AM
Time to pop my cherry. This is my first log review. Only have the JB4 with a connect kit, 7.5 FMIC, stage 2 colder plugs. Not sure what to look for here. Any insight is greatly appreciated.
2008 535xi
JB4 w/Connect Kit BMS BEF 7.5 Stepped Competition HD FMIC Dual Cone Intake NGK 2 Step Colder Spark Plugs New OEM Turbos
dmckmc dmckmc is offline
Car: E60 535i
Default 10-02-2020, 03:12 AM
Do this for most helpful log info:
Tracton control disabled
3rd gear
Wide Open Throttle - smash pedal without hitting kickdown button
2000 rpm to redline
you can set JB4 to auto log at wide open throttle to make it easier
a few things to note on the logs as is...fp_h or hpfp is not keeping up at full throttle, could be failing/poor high pressure fuel pump. ecu psi, target and boost are pretty messy, you are not making boost
N54
FBO
E40
JB4
MHD
XHP
Default 10-03-2020, 06:15 AM
Hey,
First - welcome
Proper logs are usually done as follows:
3rd gear
WOT (pedal 100% to floor)
2k rpm - redline
shift into 4th
slow down, and end log
Car: 2008 535xi
Default 10-04-2020, 01:56 PM
This any better? I guess I kept gunning it into 4th before stopping the log.
Also, what are the most useful metrics for the graphical view?
2008 535xi
Car: 2008 535xi
Default 10-04-2020, 03:15 PM
Thanks! Added another log closer to what you mentioned. Should I include the log for 3rd gear ONLY?
2008 535xi
Default 10-05-2020, 07:01 AM
What fuel is this?
Any flash?
Bump your FOL up to 90 & relog
Car: 2008 535xi
Default 10-05-2020, 07:35 AM
What fuel is this?
91, though likely with e10 - e15. We don't have the best gas where I live. I've been told that they tend to use old leftovers from other states of lesser grade gasoline and add ethanol to bring the average octane up.
Any flash?
No flash, yet. Planning on MHD PUMP USA. Waiting for wifi adapter to ship.
FOL = Fuel Open Loop? It's currently at 73. Will bump up to 90 and relog. What am I looking for and what is ideal?
Thanks for your time!
2008 535xi
Last edited by iversoncreative; 10-05-2020 at 04:02 PM.. Reason: Updated actual FOL setting.
Car: 2008 535xi
Default 10-05-2020, 06:57 PM
FOL bumped up to 90 and relogged. Thanks again! Seriously.
2008 535xi
Car: 2008 535xi
Default 10-06-2020, 05:19 PM
A couple of questions:
  • Should I be concerned that the cylinders/ignition/timing isn't consistent or tracking closely? Am I reading that correctly?
  • How are my Low and high pressure fuel logs looking? I'd like to run ~30% e85 on top of our available 91 octane (that also has up to ~10% ethanol). Should I consider a LPFP upgrade now, or later?
Again, many thanks for your time and expertise. Much appreciated for a newcomer to the world of moding/tuning/logging.
2008 535xi
Car: 2008 535xi
Default 10-10-2020, 06:08 PM
Did a dyno tonight and threw the 29F2 open loop set too high. Also got a 29E2, which seems to point to the pump.
Ran it on map 4 and then map 5.
2008 535xi
