(#4651)
vietnameeh vietnameeh is offline
Car: Q50
Default 10-10-2019, 08:54 AM
Thanks guys! should I taper down to say 4 at 6k? or even lower?
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
jrobohm's Avatar
jrobohm jrobohm is offline
Default 10-10-2019, 04:39 PM
The logs with a less aggressive boost add at high RPM will tell the tail. Remember you can use number between whole numbers. Your 91 pump fuel will be an ongoing limiter to more boost unless you add E85, octane booster, or go WMI.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HE w/ Aux Tank
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
Silversport22 Silversport22 is offline
Car: Q50
Default 10-11-2019, 05:04 AM
So I decided to not go the jb1 route and just go 4 as I can pick one up used from a friend. Is it ok to just go with JB4 without any logging (no data cable or bluetooth). I would leave at the default map of +4 until I decided on either the bluetooth or data cable down the road. Its a silversport so I assume that +4 with 93 octane should be safe without logging for now.
Also, i have heard of connection issues with the bluetooth when buying used and having to have the "user" reset through BMS. Is this still the case?
Default 10-11-2019, 01:43 PM
You can use it on map 1, no problem without logs.
Yes, if you purchase the BT used and the previous owner did not unlink. You'll have to screenshot and email to the email requested on the screen when trying to connect.
Sean the Mick Sean the Mick is offline
Car: Q60
Default 10-14-2019, 08:20 AM
Hey peepers... looking for opinions and to get schooled as I am a TOTAL JB4 noob...
Sooo...
2018 Q60 Sport (NOT RED SPORT) AWD w/ BBE catback and Fast Intentions LDP installed with JB4 and 94 Octane...
Is Map 7 not the best idea to constantly select? Too much stress?
I do spirited driving and some highway driving, enjoy the WOT when I get the chance...
Thanks and Cheers!
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-15-2019, 08:11 AM
Sooo...
Thanks and Cheers!
Map 7 is really meant for racing conditions, like a dragway. For daily spirited driving and your mods, Map 5 or a tapered Map 6 would work. Make sure you post some logs to ensure there's no issues with timing
2019 Q50 Luxe RWD *JB4 with Fuel Wires*BMS Intakes*AMS Downers*Frozen Boost 101*
423 whp, 450 tq at 16.8psi with E30 (prior to LDP and FB101)
12.68 @113mph @2700 DA, 38% humidity, terrible tires
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-16-2019, 07:36 AM
Installed my Megan Y pipe on Monday. 1st Dragy run afterwards was a new PR at 4.64. No brake boost, feathered the throttle to avoid spinning and stull cut off .10 from pre-Y pipe. Did not think the Y pipe would make a difference but the car feels significantly stronger, even when I go Map 0 to commute to work it pulls much harder. Also sounds like the OG G35 exhaust note which I absolutely love. Similar t to this video, not as loud though, with turbo spooling as well of course: Infiniti G35 stock exhaust (Must Hear!!!) - YouTube
Slightest bit of rasp now though. Skipping the midpipe upgrade. BOVs next.
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default 10-17-2019, 03:10 PM
Question, in the settings where you can limit boost by gear, do you input the value of the total PSI you want to limit to, or just added jb4 PSI? for example, if I put a 3 in the field for first gear, will it limit boost for first gear only up to 3 PSI above stock? Or will it only allow for 3 PSI max in first gear?
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default Yesterday, 06:53 AM
.... am I the last soldier standing?
Car: Red Sport 400
Default Yesterday, 07:58 AM
Stay alive friend. I have crossed to the dark side, wish me luck
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
12.19 @ 115.87 on 93 (Map 6)
Serstylz2's Avatar
Car: 2019 Q50 Luxe
Default Yesterday, 08:23 AM
Ecutek?
Car: Red Sport 400
Default Yesterday, 09:30 AM
Ecutek?
Yeah, loading initial tune today. Really wanted 11's but it seemed risky pushing it any further with JB4
2019 Q50 RS AWD
BMS JB4 + FW/HEX
MR LDP's
Car: q50
Default Yesterday, 10:02 AM
Still alive....waiting for JB4 VR30DDTT platform updates ...
Q50 Premium RWD
BMS JB4 w/ FW & WMI
Post turbo stuff lol, Y pipe, Mid pipe
BMS HE
jrobohm's Avatar
Default Yesterday, 12:07 PM
Roger that - once the NTX weather smooths out Iíll take the car back to dyno. Short of that - Iím just enjoying the ride.
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS LDP
  • FI Res CBE
buttons252 buttons252 is offline
Car: 18 Q50 Luxe AWD
Default Today, 11:09 AM
Just ran my 2018 q50 awd. 12.9@111.69. Only mod is jb4 map 7. E25. 2.0 60ft
Default Today, 11:25 AM
Not bad! Log of the run? Need to get that 60' down.
Default Today, 11:26 AM
Tuning has been working well. Recently on the Q50 front we've finally redesigned our intake brackets and working on our Q50 OCC solution.
jrobohm's Avatar
Default Today, 11:48 AM
For those of us with BMS CAI w/ inlets, will we have an option for the updated rackets?
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS LDP
  • FI Res CBE
