(#201)
MorganBence MorganBence is offline
Car: 2015 maserati ghibli
Default 10-11-2019, 02:16 PM
Can you post the CSV file.
You can learn more about reading logs here:
Logging Parameters and their Meaning - N54Tech.com - International Turbo Racing Discussion
We suggest map 2 at the most for 91 only. Do you have access to e85 around you?
I do. How many gallons is suggested added to 91? What map would I run?
Default 10-11-2019, 02:42 PM
Awesome! Start with 3-4 gallons of e85 and fill the rest with 91.
Get another log on map 2 so we can verify it's all good before moving to the next higher map.
Default 10-13-2019, 06:48 PM
Here is map 2 with 91 and about 2.5 gal E85. let me know if there is no difference due to the low amount of E85. To be honest I was a little scared putting it in so I wanted to be safe and just try a little. Thanks
Mmarmolejo Mmarmolejo is offline
Car: Maserati Ghibli
Default 10-14-2019, 04:56 PM
I replaced the spark plugs and now my vehicle is running great, what would be the next step for someone to help me read a log?
Default 10-14-2019, 05:01 PM
[QUOTE=Payam @ BMS;648080]Can you post the CSV file.
Here is the CSV file.
Default 10-15-2019, 01:39 PM
[QUOTE=Mmarmolejo;648306]
Looks pretty good! What fuel are you using? Go for map 2 next and grab another log. If you have e85 available add 3-4 gallons and fill the rest with pump gas and grab a log.
Default 10-15-2019, 04:19 PM
[QUOTE=Payam @ BMS;648368]
Iím using 91 and added 2 gallons of e85. Iíll add 3 gallons on my next fill up and run a new log. Does it matter in sport or regular mode?
Default 10-16-2019, 09:29 AM
Here is map 2 with 91 and about 3 gal E85. let me know if there is no difference due to the low amount of E85. To be honest I was a little scared putting it in so I wanted to be safe and just try a little. Thanks
Default 10-16-2019, 12:27 PM
Not bad, I would add another gallon of e85 and get another log in map 2 please.
See if you can get a longer run. Looks clean and strong though!
Default 10-17-2019, 01:16 PM
Here is the log with map 2 and 3 gallons of E85.
Default Yesterday, 02:12 PM
[QUOTE=Mmarmolejo;648508]
Looks very strong and healthy from what I can tell in the log.
Hows the car fell?
Default Yesterday, 03:20 PM
Ok, will do on the next fill up. Also, between shifts sometimes it will pop and if I am on hard acceleration and let off after a shift, it will pop loud as well out the rear. I don't mind it, just want to make sure that it is not doing any damage.
DVSGhibli DVSGhibli is offline
Default Yesterday, 05:05 PM
Originally Posted by DVSGhibli
In Australia this is the best on pump noted as 98 Octane. I have researched this however and I think it is still a lower grade than the 93 in the USA.
Hi Guys, little while ago i posted some runs. I have some more for you to have a look at and am now really interested if there is any further MAP updates from BMS. Note, this is running approx. 3.5 gallons of E85. I have also attached a dyno report running one run on Map0 and then 2 runs on Map5. Dyno was on a Dyno Dynamics machine.
