(#6076)
Default 09-02-2021, 12:46 PM
Originally Posted by Sheddy
I recently picked up a 2021 Q50 Luxe. Was able to get my hands on a JB4 with fuel wires. Can you please let me know if this log looks good?
Looks normal to me
Default 09-02-2021, 12:47 PM
Originally Posted by Alpha50
pls find my map 2 run as well, slight S corner tho and on 91 with octane booster. Have just installed the fuel wires this morning. Thanks, you guys are the best!!!
Looks good to me, but no fuel control wires in this log. Relog now that they are enabled.
dingo6610 dingo6610 is offline
Car: 2017 Infiniti Q50 RS400
Default 09-03-2021, 05:53 AM
Apologies if this is in the wrong thread.
2017 Q50 Red Sport, JB4 map6, NO fuel wires nor EWG connectors
In user adjustment should I turn ON Bit 6? If YES, what does it do?
Default 09-03-2021, 09:59 AM
For the RS fuel wires are useful, I'd attach and enable those if more power is the goal. Otherwise, log itself looks fine!
Bit6 on doesn't really do anything unless EWG are also attached. But can't hurt to enable it.
cevans cevans is offline
Car: 2017 Q50 Premium AWD
Default 09-05-2021, 11:16 AM
Just installed my JB4 last night on my 2017 Q50 Premium. This log is on Map 3. I certainly am no professional but from what I can gather from the table, everything seems fine. I plan to switch to Map 6 but wanted to get an idea of the limit I can push the boost to before getting super technical with the whole rpm range. Let me know if anything stands out to you guys. Thanks in advance.
Default 09-07-2021, 10:33 AM
Looks normal but you didn't go WOT until 4k rpms.
Default 09-07-2021, 10:43 AM
Ah, shoot. Maybe I mixed up the logs. Is 2500rpm low enough for WOT? Or should I try for closer to 2000-2200? Thanks!
Beardofpeace Beardofpeace is offline
Car: Q50S
Default 09-07-2021, 05:17 PM
Hello again. I'm testing out some new map 6 settings and wanted some feedback. Thank you!
I can do more logging if necessary
Alpha50 Alpha50 is offline
Car: 2017 AWD Q50
Default 09-07-2021, 05:31 PM
Quick question, Can you run E30 mix on the stock LP HP fuel pumps and filter?
renesis83 renesis83 is offline
Car: Q50 3.0T
Default 09-07-2021, 05:42 PM
Hello, I just switched to Map 2 on have been running map 1 for a little while. I recorded the following log in third gear from 2k rpm to all the way to 7k and then shifted to 4th gear and slowed down.
Not sure if its the temperature out side of 82F or the car was running hot, the map didn't feel much different than map 1.
Car is bone stock and Mobil 93 gas is always used.
Please see the attached logs and any input would be greatly appreciated
Don
Default 09-08-2021, 06:15 AM
Recorded another log, Mpa 3 with fuel wires. WOT closer to 2500rpm this time. Thanks!
Default 09-08-2021, 10:03 AM
That looks better and all looks good!
Default 09-08-2021, 10:09 AM
Update your firmware and make sure all your user adjustment settings are set to the default values...Most things are zero'd out and I can't see your map 6 settings.
Infiniti Q50 3.0t VR30DDTT Red Sport and Silver Sport BMS Stage1 JB4 - N54Tech.com - International Turbo Racing Discussion
Default 09-08-2021, 10:11 AM
Don
The picture you posted is not the same as the log you posted. Please do a proper log on map 1 and map 2. The log you posted is not at WOT and starts at 3500 and goes to 5600 rpms.
For proper review and the JB4 to adapt, please do logs in 3rd or 4th gear from 2K rpms to redline at wide open throttle.
Silversport22 Silversport22 is offline
Car: Q50
Default 09-08-2021, 12:50 PM
It's an optional setting. Some people prefer it, some people prefer the default, try both and see what you prefer.
Can you let me know how the jb4 operates between this setting (linear pedal mapping) being on vs off so I can fine tune this better?
I appreciate the info.
Q50RS207 Q50RS207 is offline
Car: 21 Q50 RS
Default 09-08-2021, 04:09 PM
Hey there - got some pulls today on map 1, can you please review the logs? JB4 w/fuel + EWG.
Thank you!
Car: Q50S
Default 09-08-2021, 08:46 PM
Just got back from doing some logging as you suggested with the updated firmware.
I have three logs each with one pull from 2k RPM. Two are 3rd gear pulls and one is a 2nd gear.
Default 09-09-2021, 10:22 AM
You forgot to update all your user adjustment settings that are zero'd out.
Default 09-09-2021, 10:25 AM
Thank you!
Looks pretty good. Try map 2 next.
Car: Q50S
Default 09-09-2021, 01:28 PM
Okay...I'm sorry. Are the default values on the first page where it says "Q50 Default Settings as of v9 firmware:" or is there an updated default setting?
SilentQ SilentQ is offline
Car: 2018 Q50S
Default 09-12-2021, 07:32 PM
Yeah I second Whats said above. All my values after the boost by rpm options say 0 and idk if the safe when I’m on map 6 testing stuff. I’m on the latest firmware so are those values you have listed on the first page accurate? Thanks
Car: Q50
Default 09-12-2021, 07:43 PM
So if we use the linear pedal option will it remove the difference in pedal response between standard and sport modes? Or will sport still have a “touchier” steeper linear curve then normal mode?
crescentfallen's Avatar
crescentfallen crescentfallen is offline
Car: 2020 Q50 Luxe AWD
Talking 09-13-2021, 05:01 PM
Got my JB4 with fuel wires today for a 2020 Q50 Luxe AWD.
Will install it before this weekend. Can't wait to try it out.
Default New to JB4 - 09-14-2021, 04:06 PM
Just connected the JB4 today on my 2020 Q50 Luxe AWD, all stock. Set it to map 2 on 93 octane.
Was just driving around normally and an occasion hard acceleration. I have an unplanned log, can someone tell me if it looks OK.
thanks
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 09-14-2021, 04:08 PM
Congrats! Bring us back some logs. I would suggest - Map 1, 2 and 3 then post them here. Use manual mode and ride 3rd gear full throttle all the way up from 2500-6500 if you can. Don't just start playing with map 6 unless you already know what you are doing. Someone will give you some feedback on your logs to see if you should continue to map 4 and 5.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Dave @ BMS/Fuel-It!
