(#101)
Default 07-27-2019, 09:20 AM
We're definitely at the limit of AWD traction at this point, likely better rear tires will be the next step to move things forward at the track.
CK-19-GT2 CK-19-GT2 is offline
Car: Kia Stinger GT2
Default 07-27-2019, 10:19 AM
Ok I have a 2019 Stinger GT2 RWD. What would be the proper method of operation using this mod? Is it sport mode TC off or comfort TC off or...? what is the best suggested way people are having success with? Thanks.
Default 07-27-2019, 03:02 PM
Without tires not sure it's really going to be that useful to RWD cars. Launch mode is disabled with the switch active and you brake boost off the line.
gooteeiii gooteeiii is offline
Car: Stinger GT2 AWD
Default 07-28-2019, 03:57 PM
Originally Posted by monkey
Also the rear tires can spin silently when brake boosting making the car attempt to transfer more power forward. I did this after the snip and thought i had the switch in stock mode, waiting for the LC to come on and realized my rears where quietly spinning. Holding 4+ seconds they had to be spinning.
My one launch at the track with full throttle and 10+ PSI resulted in a bit of spin followed by a 2 second throttle cut. ECU didn't like something. My car always cuts throttle after 1 second of spinning but this was different. Less spin and longer cut.
Would it benefit AWD users to disable the AWD when using this mod? Would this eliminate the risk of damaging the transfer case? It's as simple as pulling the fuse right?
Default 07-28-2019, 08:51 PM
Would defeat the purpose... RWD = spin city.
monkey monkey is offline
Car: stinger
Default 07-29-2019, 06:08 AM
Turns out it wasn't the transfer case. RWD guys not off the hook yet. Stay tuned.
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 07-30-2019, 07:45 PM
Yes, that simple. Just pull the fuse.
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
2018 Stinger GT AWD Sunset Yellow
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Factory NGK plugs gapped @ .024
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
-Firestone Indy Firehawk 500's
Adamdan Adamdan is offline
Car: Stinger
Default 07-30-2019, 08:03 PM
Why do that though? If you make the car launch harder then disable awd your just going to loose all your traction.
Car: stinger
Default 07-31-2019, 06:55 AM
Plus the damage ended up not being the transfer case.
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 07-31-2019, 06:56 AM
Do we know what the damage was?
MurlinatoR's Avatar
Kia Efficinato
Default 08-09-2019, 05:51 PM
Quiet in here. LOL
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
Default 08-09-2019, 08:22 PM
Sounds his dealer sent him home with the car and said nothing was actually wrong... Probably a broken trans or diff mount IMHO.
bbrillon998 bbrillon998 is offline
Car: Stinger GT AWD
Default 08-14-2019, 09:56 PM
Need some help here Terry, Ive done about 25+ launches with the BMS switch on and off the track and ive noticed something peculiar, Switch On to disable the break signal, AWD, car set to sport mode, traction control & stability control off: set to launch and anything over 2500 RPM launches the car with wheel spin out for the rear tires and some front: then the computer cuts in immediately disables throttle, maybe boost aswell to stop the wheel spin for about a second or two then its all good again pulling 106, 107MPH traps @ 13.8 to 14 seconds in the 1/4. (with some pretty horrid 60' times like 2.6, 2.8). Im stumped why the ECU is kicking in more frequent ive been able to repeat this launch behavior 4 times now.
robz's Avatar
robz robz is offline
Car: Stinger
Default 08-15-2019, 07:54 AM
That will not be your ECU. That is the TCU intervening.
Car: stinger
Default 08-16-2019, 08:14 PM
Mine cuts throttle if i spin for 1 second in rwd mode just punching it, even at 30 mph.
Break snip it will cut on a hard launch as well with little to no spin.
MNStinger MNStinger is offline
Car: 2019 Kia Stinger GT2
Default 08-23-2019, 11:20 AM
Has anyone traced the wire that needs to be cut? I'm just looking for a different/more inconspicuous spot to make the cut rather than right next to ecu...
2019 GT2 AWD - Panthera Metal
JB4 - Fuel Wires - EWG Wires - Ultimate Performance Intercooler - BMS Intakes - ARK Secondaires - MBRP Exhaust
Car: stinger
Default 08-23-2019, 11:30 AM
Good to see another GT2 AWD is getting similar results to me. If I launch when the "A" light is flashing on the dash, my full boost mode, the throttle will cut on the track even with little to no wheel spin. (aggressive launch lots of grip that you couldn't replicate on the street)
Right when you flip the switch, do you ever get a less aggressive launch when the "A" light is not flashing? That mode is actually quite useful 1.74 60s and wont spin the tires.
I thought about trying an E0 aggressive mode launch to see if its a fueling issue but do suspect the TCU is likely the cause.
Default 08-23-2019, 03:55 PM
Couldn't tell you. But the switch does what it does. If it's not working for your car then there isn't any other way to achieve the same effect that I'm aware of.
EdsNotHere EdsNotHere is offline
Car: 2019 G70 3.3T
Default 09-28-2019, 05:56 PM
So no broken parts? Worth doing the mod?
Default 09-28-2019, 07:00 PM
Not heard of much negative. A couple rumors of guys breaking parts brake boosting too long or launching too hard but nothing confirmed.
Car: 2019 G70 3.3T
Default 09-28-2019, 07:15 PM
Worth a try. Wonder I could pull the pin from the connector (have the pin extractors) then just tap in and use the same type connector to go back in the connector.
MurlinatoR's Avatar
Kia Efficinato
Default 10-29-2019, 02:31 PM
No one has shown any updates lately...? Everyone still running tight with their switch.
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
BHR Stinger BHR Stinger is offline
Car: Stinger 3.3T
Default 11-01-2019, 01:10 AM
Two years in, still no ECU or TCU tune for this platform. Kinda frustrating.
JB4 - Denso 5346 - AEM Intake - VT Snorkels - Snow WMI - NGT Primaries - JUN BL Mid-pipe w/200cell HFCs & EVC c@t-back - Radium OCC x2
Default 11-01-2019, 09:07 AM
It's a boutique platform so you have to just take what you can get on it. We've got mildly modified cars on stock turbos running 11.5s in the 1/4...I think that is well beyond any of our expectations a year ago.
Car: stinger
Default 11-05-2019, 06:52 PM
Looks like the brake snip can also make your collision detection malfunction. I flipped mine on at a stop light and when trying to take off the collision detection went off and tha car jammed the breaks on for half second. I was only going 3 mph luckily.
Mine takes a few mins to kick in so have to turn it on early.
