(#51)
Clight43 Clight43 is offline
Car: Awd stinger canadq
Default 07-08-2019, 01:28 PM
I hope im an isolated case but after doing this i seem to have an issue with the car .. (maybe tranny, driveshaft or differential) when i go from N -> D i get a a jerk from the back tires.. D-> N i feel it but nothing big.
Adamdan Adamdan is offline
Car: Stinger
Default 07-08-2019, 02:05 PM
Was this after cutting the wire or after launching it a couple times?
Default 07-08-2019, 02:14 PM
After 2 attempts of stock launch and 2 with switch off.. i dont know if it occured before or after the launches but i didnt have this issue this morning..
*note i only activated LC but did not actually launch it was just testing in driveway.
** i am the only one with this issue but decide to put it up incase some1 else develops the issue, might have nothing to do with the actual wire cut but a derrived issue was maybe at cause before.
Car: Stinger
Default 07-08-2019, 02:39 PM
Have you tried twisting the wire together and see if it goes away? I know the stingers have two different shifters ones drive by wire. I wonder if that has anything to do with it.
khmer07 khmer07 is offline
Car: 2019 Kia Stinger GT2
Default 07-09-2019, 02:13 PM
Could we use positaps and wire into a switch instead of cutting the wires?
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 07-09-2019, 02:28 PM
^ no...you have to break the connection
Default 07-09-2019, 03:11 PM
Could be nothing, could be a worn ujoint somewhere, or maybe a broken trans mount? You'll have to better diagnose where the noise is coming from.
Jrod10 Jrod10 is offline
Car: Kia stinger GT
Default 07-09-2019, 05:29 PM
So I did the switch and followed the instructions and it doesnít work. Launch control will not kick on and itíll build a small amount of boost before it loses it all
robz's Avatar
robz robz is offline
Car: Stinger
Default 07-09-2019, 05:43 PM
Launch control is not supposed to engage with this mod.
Default 07-09-2019, 05:45 PM
+1
Car: Kia stinger GT
Default 07-09-2019, 06:20 PM
+1
No when the switch is off the last control will not come on but the car will not build boost. Itíll build for a second then wastegates or BOVs kick in and it launches with no boost
Default 07-10-2019, 03:39 PM
I believe my LC did activate with switch mod.. dealership said hes hearing sounds from transfer casr as if drive shaft is settling on something
Default 07-10-2019, 06:53 PM
Maybe you cut the wrong wire then?
MurlinatoR's Avatar
MurlinatoR MurlinatoR is offline
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 07-11-2019, 07:19 AM
Bet. Here's my $100. LOL
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
2018 Stinger GT AWD Sunset Yellow
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Factory NGK plugs gapped @ .024
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
-Firestone Indy Firehawk 500's
bbrillon998 bbrillon998 is offline
Car: Stinger GT AWD
Default 07-11-2019, 08:33 AM
Managed to Do 3 runs at the track last night. It preformed amazing but, for me anything above 2300 RPM and the rear tires start to spin with the fronts holding firm. Will just avoid launches above that RPM to be on the safe side of minimizing loads on the transmission transfercase. Still got my fastest times at the track last night with 8,600 and 8,400 DAs, Im blown away how well it works, i did a launch with the normal LC first before i hit the switch and it did 13.49@ 102 with 2.2 60' which was typical for a hot day at 5800ft above sea level.
Best $ to performance mod out there.
MurlinatoR's Avatar
Kia Efficinato
Default 07-11-2019, 11:15 AM
You're RWD, right?
I wanna hear how the AWD handles the load? LOL
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
Car: Stinger GT AWD
Default 07-11-2019, 01:31 PM
Originally Posted by MurlinatoR
You're RWD, right?
Mine is AWD ! Ive only ever seen one RWD stinger In Colorado because I almost bought it. Dealers dont really order any RWD cars here because well... its Colorado.
Beefer's Avatar
Default 07-11-2019, 01:37 PM
I really want to do this...but absolutely hate having to cut that wire
MurlinatoR's Avatar
Kia Efficinato
Default 07-11-2019, 05:16 PM
Ohhhhhh, so you're spinning the rears because you've got it in sport. I'll bet if you launch it in comfort the back tires hold longer before breaking loose.
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
MurlinatoR's Avatar
Kia Efficinato
Default 07-16-2019, 08:11 AM
Wow it got really quiet in here. LOL
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
robz's Avatar
Car: Stinger
Default 07-16-2019, 08:14 AM
You've been MIA @MurlinatoR.
Have not seen you in the forums for a while.
Car: Stinger
Default 07-16-2019, 08:41 AM
I would be nervous if the front drivetrain can take that torque.
Default 07-16-2019, 08:47 AM
Time will tell on the durability side but gut feeling is things are holding up well at our current power levels.
MurlinatoR's Avatar
Kia Efficinato
Default 07-18-2019, 06:09 AM
LOL
Hey, what's up @robz! Yeah, I've been running out of time on a daily basis. Haha
We have construction going on at our dealership pretty heavily. Plus, the Telluride has been trashing my daily to do list. LOL This thing is so popular that I have 5 customers a day coming in to see one. I can't get them fast enough!
-MurlinatoR
30k miles
-JB4 w/bluetooth
-Tork shorty intake
monkey monkey is offline
Car: stinger
Default 07-21-2019, 08:46 AM
Originally Posted by Jrod10
So I did the switch and followed the instructions and it doesn’t work. Launch control will not kick on and it’ll build a small amount of boost before it loses it all
Jrod10 - what type of Stinger? GT2 AWD?
I did the mod and it worked on day 1, and day 2 it was tame. Still 2700 rpm, some boost 5 ish but throttle only at 30 and opens slowly. Day 1 throttle was 80 and opened instantly. Difference was smoky AWD burn out vs almost normal LC launch (but LC doesn't engage of course). Day 1 the auto stop light on the dash was flashing and day 2 it was not.
