Philipjr Philipjr is offline
Car: 2008 BMW 335i Convertible
Exclamation JB4 Map 5 - *AFR Too High* - 07-09-2019, 03:01 PM
Did a couple pulls last night after updating jb4 firmware. Noticed AFR was very high, then I misfired CYL 4. How do I fix this?
TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 07-09-2019, 04:30 PM
Turn on 6 cylinder ignition logging.
What octane fuel?
Default 07-09-2019, 04:40 PM
Mod and fuel used?
Default 07-09-2019, 05:31 PM
Im using 91 octane. I think I have 6 cylinder log on but its not showing
Mods:
JB4 Tuner
Stage 2 bucketless fuel pump
dual cone intakes
Car: '08 135i MT
Default 07-09-2019, 05:47 PM
Mods:
JB4 Tuner
dual cone intakes
Probably have the wrong bit value. Have you identified if you're IJE0S or INA0S?
Also are you planning E85 or something? Stage2 fuel pump is overkill for a tune on 91
Default 07-09-2019, 06:35 PM
Yes. I do plan on using E85.
Im not sure if I am IJE0S OR INA0S, How do I check that?
Default 07-09-2019, 09:05 PM
It should show up when you flashed the BEF
