Zmon1300 Zmon1300 is offline
Car: 2010 335Xi coupe
Default 04-19-2019, 10:57 PM
Plz pm me. I would like to purchase one.
Default 04-21-2019, 10:20 AM
We don't use PM but can always email us, to get one paypal to address in first post is best way for now since they are not on our site yet.
rsh_n54 rsh_n54 is offline
Car: Bmw N54 335
Default 04-25-2019, 06:34 AM
Hi Terry/Payam
I wanted to ask, is it possible to convert my existing bms occ to a vacuum side kit? I'm guessing its just the pcv/check valve that is different and the need for your bov adaptor?
Do the fittings on this OCC make any difference, other then compensate for the smaller hoses?
ryan.ferguson1993 ryan.ferguson1993 is offline
Car: 2013 335is DCT
Default 04-25-2019, 01:35 PM
This may be a stupid question but could I run a Hobbs switch off the BOV adapter or move my BOV line to the BOV adapter and run a hobbs switch off my Vader Solutions TMAP adapter? I have a dual nozzle meth kit so just looking to see if I could get around having to plug the Hobbs into the charge pipe and stick with the dual nozzle setup I have.
Side note, I got my kit today and it looks fantastic! Can't wait to get it on.
Default 04-25-2019, 04:02 PM
Yup! You can do any of that! I would probably put the hobbs on the vader solutions valve.
Car: 2013 335is DCT
Default 04-25-2019, 04:28 PM
Awesome, thanks so much Payam!
slanteyez slanteyez is offline
Car: Eclipse GSX, Infiniti G35
Default 04-25-2019, 05:57 PM
Hey Terry,
So the check valve disables the ports on the head? Does this also reduce carbon build up or do we still have to block the ports?
Logan's Avatar
Logan Logan is offline
Car: E90' 335i
Default 05-02-2019, 07:53 PM
is the stock check valve for high side still needed?Or can i get rid of it?its the checkvalve thats not full closed.
Default 05-02-2019, 08:08 PM
This replaces the RB/BMS PCV.
Logan's Avatar
Car: E90' 335i
Default 05-02-2019, 08:30 PM
Heres a diagram of my setup at the moment with your setup.but with highside im vta with mini airfilter.but the checkvalve on highside seems its opens under load but under vac it closes but lets some air through,are you guys running the high side checkvalve in place with your setup also?if i took it out of the loop would it be a issue?also want to point out im also using a vtt valve cover air filter breather cap.
LCI_Jay LCI_Jay is offline
Car: 09 BSM 335i
Default ST Setup - 05-04-2019, 09:01 AM
So how would a single turbo setup be accomplished with the dual BMS setup?
Default 05-04-2019, 09:08 AM
Same as the factory turbo. Only the boost side OCC outlet should tie in to the single turbo filter so it can suck up and reburn all that noxious fuel vapor like the factory setup does.
ToolMaker335xi ToolMaker335xi is offline
Car: E92 335xi manual
Default 05-04-2019, 09:34 AM
When will they be available on your site? I need to order ASAP along with a few other things and want to get it all on one order in stead of paying for shipping on multiple orders.
Default 05-06-2019, 09:22 AM
About 2 weeks, they're being machined as we speak
mrmax1984's Avatar
mrmax1984 mrmax1984 is offline
Default 05-16-2019, 11:52 AM
A couple questions:
1) I'm currently running an untuned, stock N54 with the original (low side?) BMS OCC. The one that mounts in the back and sits between the PCV valve in the back of the valve cover and the rear inlet (I think, can't remember).
What I've found is with this alone, I was still getting carbon build up and hardly anything in the catch can. I just checked it the other day after 2 years, and it had nothing in it. Is this because most of the blow-by is still occurring through the ports in the head?
2) You mentioned that with this new OCC offering, the ports in the head (that drip down to the intake valves) don't necessarily need to be plugged. How are you achieving this?
3) Will this product be worth it for stock tunes? How about MHD Stage 1?
4) Will it work with stock diverter valves, or only after-market BOVs and/or charge pipe?
Thanks, appreciate any feedback you may have.
1///M's Avatar
1///M 1///M is offline
Car: BMW 1M
Default 05-17-2019, 01:49 PM
Originally Posted by mrmax1984
A couple questions:
I am no expert on this matter but even on a stock motor this will definately assist.. The difference between the 2 catch cans is one collects at high rpm and the other at low rpm from my understanding... One possible reason you not collecting as much oil in the catch can could be that your driving style could be mere commuting in and around town so therefore the can is not catching at high rpm there the external pcv will catch more
Iro plugging the heads that's a very good question and I ma keen to know the answer
My question to the bms team is will this setup work on the Billet valve cover options out there
RHD Top Mount ST
Car: Bmw N54 335
Default 05-21-2019, 05:54 AM
Any timeframe of when this will be available to purchase and a ballpark on pricing? Christine wasnt able to assist when I sent her an email.
mrmax1984's Avatar
Default 05-21-2019, 06:54 AM
A couple questions:
@Terry or @Payam, can either of you clarify the above?
Default 05-21-2019, 09:43 AM
1- Make sure the system is a closed loop, after 2 years you should get something.
unless you drive less than 5k miles in that time.
2- Doesn't need to be plugged, our adapter fitting blocks that.
3- Yes, tuned or untuned no matter. It will benefit in keeping oil and gunk out of places it shouldn't be.
4- Yes for stock DV or BOV, no difference.
mrmax1984's Avatar
Default 05-21-2019, 10:15 AM
Thanks for the reply! What's the cost for this low-side system? Are installation instructions available so I could see what I'm getting into before purchasing?
BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 05-21-2019, 12:26 PM
You say your kit is second to none, and that's why everyone copies it. But RB offered this quite some time before and it is nearly identical. Not trying to sound like a fanboy or instigating. If you could clarify what sets your kit apart from RB's kit.
Default 05-24-2019, 11:08 AM
Few key points are different, but they do the same thing. Choice on the end user what they want. However, ours will be significantly different.
Second revision will be up soon, you guys will really like that one!
Car: 2009 335i AT
Default 05-24-2019, 11:18 AM
What is changing with it? You've peaked my interest
2009 E92 335i AT
Engine
Rev9 Hybrid 16t twins, Injen cyborg intake, CP-e charge pipe with HKS SSqv BOV, RB external PCV catch can, BMS catch can, Cobb intercooler, HKS Legamax exhaust, RB inlets, VTT single barrel hpfp, fuel-it! stage 2 lpfp, MOTiV Flex fuel flash only w/ trans tune by Cedar Performance
558rwhp and 523rwtq on e60 110* ambient air
Default 05-24-2019, 01:12 PM
Everything will be in next week and I'll post some detailed photos and pricing for more Beta kits
Default 06-03-2019, 04:30 AM
Any update on when it will be available on the site? Have not seen it on the website yet.
