(#51)
bloked97one bloked97one is offline
Car: 335i n55 2011
Smile 07-19-2016, 04:22 PM
Hi Steve Are you here.
you want to come to the West Indies?
No problem
Default 07-19-2016, 05:57 PM
Frankly, I'm not even sure what your problem is. The speed limiter at 155?
You posted 2 logs both overboosted because your FF is too high. I'd suggest you get with your tuner and address it or lower your FF on your own.
Car: 335i n55 2011
Default 07-21-2016, 03:36 AM
if you have an idea I'm interested.
thank you for your help
Car: 335i n55 2011
Default 07-24-2016, 10:01 AM
Hi Steve.
do you think the turbo may be damaged and provide results.
Car: 335i n55 2011
Default 07-26-2016, 06:18 AM
Hi Steve
Car: 335i n55 2011
Default 08-08-2016, 08:28 AM
Hi Steve.
a question. bmw technician told me that my model is part of the last generation and it may be that I have an e92 335i but my calculator and the model that came after. f32 and that management is not the same thing why I have problems.
Default 08-09-2016, 06:25 AM
Okay
Car: 335i n55 2011
Default 08-09-2016, 06:41 AM
Ok but.
what should I do?
Default 08-09-2016, 08:34 PM
Honestly, i have no idea what you are talking about. You're going to need to consult your tuner. Sorry
Car: 335i n55 2011
Default 08-15-2016, 07:43 AM
Hi Steve.
I want to spend a stage 3 but not with ethanol which is the right fuel it have to choose and pump 300c .
Merci
Default 08-15-2016, 11:16 AM
If you're not running ethanol or port injection, there is no need for a Stage 3 LPFP.
Car: 335i n55 2011
Default 08-24-2016, 06:42 AM
Hi .
I want buy port injection.
I have ********
Charge pipe.
Aeromotive 340
Hybride turbo 600hp
Akrapovic full exhaust
Afe intake
A test with vp racing fuel.
What's the max boost with the jb4
My target is 600hp.
Merci
Default 08-24-2016, 04:13 PM
More than you'll be able to run.
With the stock TMAP you'll only be able to set your boost safety to 21, with the 3.5 bar you can set it as high as 36, it just doesn't mean you'll be able to hit it.
Car: 335i n55 2011
Default 08-24-2016, 04:22 PM
Ok .
Car: 335i n55 2011
Default 08-25-2016, 02:25 AM
Hi.
how must I do to put theboost safety as 36?
Merci
Default 08-25-2016, 09:02 AM
You shouldn't...
Car: 335i n55 2011
Default 08-25-2016, 01:20 PM
Hi.
ok for safety
but I try to achieve this goal.
http://www.n54tech.com/forums/showthread.php?t=37180
Car: 335i n55 2011
Default 08-25-2016, 05:16 PM
Ricardo talk 25psi
Car: 335i n55 2011
Default 08-27-2016, 02:25 PM
Hi steve .
I have not cut.
the previous owner had a program on the DME I was not stock.
Now I make a log map2 and 5 .
Merci
Car: 335i n55 2011
Default 08-27-2016, 02:36 PM
I'm in competition with a N54.
The tuner is active autowerck.
The man have
Hybride turbo
Full exhaust akrapovic
Afe intake
Lpfp walbro 340L
Intercooler
Charge pipe with dump valve
And maybe fuel it but I don't sure cause .
he said nothing.
And he put mecateck in the tank.
If you have tips Iam ok
Merci
Car: 335i n55 2011
Default map 2 - 08-31-2016, 04:45 AM
Hi STEVE
My log I don't undestand my boost.
Default 08-31-2016, 09:05 AM
PWM is maxed out, I'd check for a boost leak.
Car: 335i n55 2011
Default 08-31-2016, 09:34 AM
Ok.
Merci
Car: 335i n55 2011
Default 09-04-2016, 04:03 PM
Hi steve
there is a problem on the JB4 I found the car accelerates very well but the boost is a 4.3 psi.
do you think that the sensor can give me bad information.
I have a default code : 2c90
2C90 - Blow-Off valve mechanics - Ignore, tuner code
Car: 335i n55 2011
Default 09-05-2016, 04:32 AM
I checked no leaks
