harkes harkes is offline
Registered Users
Car: M135i
Question Log review: PWG, Pure Stg2 - trim spike and boost drop? - 11-20-2016, 05:16 AM
Hi
Got the Stg2 dailed in pretty good but I have one question:
This jump in trims @ 5700rpm together with a spike in AFR and drop in boost - what can I make of that?
- Niels
Registered Users
Car: M135i
Default 11-20-2016, 07:21 PM
Ideas how to pressure test with 25psi? I am pretty sure the Pure high flow inlet will shoot out or the plastic inlet pipe will burst at those pressure?
Default 11-20-2016, 08:02 PM
Trims spike because DME BT drops there. On boost dropping since PWM is high its either leaking somewhere or just unable to keep up the required massflow.
Registered Users
Car: M135i
Default 11-20-2016, 08:57 PM
Terry
What is causing this drop in DME boost target? Boosting too close to target? From my experience DME boost drop is usually associated with throttle closure but not here.
Newguy123's Avatar
Car: 12' 135i
Default 11-20-2016, 10:00 PM
Originally Posted by harkes
Terry
Were you ever able to hold more boost then that up top? Stage 1 turbos don't flow much up top
18 Glacier white RS3
#PURETURBOS
#FUELIT
Registered Users
Car: M135i
Default 11-20-2016, 10:07 PM
Running Pure Stg2 now........signature updated Those boost values would be impossible on stg1.
