(#176)
natlbar's Avatar
natlbar natlbar is offline
Car: 2011 E92 335i X Drive
Default 12-24-2018, 10:04 AM
Originally Posted by dRDiesel
Probably better off emailing support
For general technical support contact:
support@burgertuning.com
I did they didn't help either.
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 12-24-2018, 10:08 AM
Really? Lol
Did they respond back at all? Might be because of Christmas..
natlbar's Avatar
Default 12-24-2018, 10:10 AM
Really? Lol
They did just didnt provide any solutions that worked. I really dont know where to go from here besides just replacing each part one at a time until I figure it out.
dRDiesel's Avatar
Car: BMW
Default 12-24-2018, 10:13 AM
Well if your pump is priming then check the JB4 pins make sure itís installed in the correct location. If that doesnít solve anything maybe you have a faulty FSB? There really isnít anything else to the kit.
natlbar's Avatar
Default 12-24-2018, 10:24 AM
Pins are fine triple checked them. Idk why the fsb would be bad it is literally brand new and I don't think it would prime if it was bad would it?
Default 12-24-2018, 10:49 AM
Another log with full throttle still no meth. Is it possible I may just need a new control board?
Photo of WMI page settings?
natlbar's Avatar
Default 12-24-2018, 10:57 AM
The only odd thing I have noticed is that when I set a value for min flow boost, just say I put 9 in there the next time I open it up it auto goes to 8.9 which is weird but i dont think an issue.
Car: 2017 BMW 340i Xdrive
Default 12-24-2018, 11:24 AM
You can put 9.1 but 8.9 is ok i say min rpm a bit low. I have it at 3500
dRDiesel's Avatar
Car: BMW
Default 12-24-2018, 06:56 PM
I have mine set on 8.1 psi starting and 3000-7000 rpm.
jrdoming jrdoming is offline
Default 12-26-2018, 05:55 AM
Does meth only increase your power under wot then? Power and responsiveness at other pedal positions remain unchanged?
2017 340i M Sport. JB4
Default 12-26-2018, 07:04 AM
Meth doesnít kick in unless you in higher boost, and then you feel the kick like a mule.
dRDiesel's Avatar
Car: BMW
Default 12-26-2018, 08:53 AM
Can you share a log?
Default 12-26-2018, 09:08 AM
Log from lat run i had
dRDiesel's Avatar
Car: BMW
Default 12-26-2018, 09:19 AM
Nice log. I can't hit target if the life of my car depended on it. I have burned through so much meth, excessive car mileage, fuel, and simply beating on the car so much, logging, and making adjustments and it will never hit target. 17-18 psi is the max it will hit even with additive set on 70, duty bias adjusted, and FF relearned.
Default 12-26-2018, 09:55 AM
Those settings look OK, so it should be kicking on with map7. Email us and we can send along another FSB to see if that is the issue.
Default 12-26-2018, 09:57 AM
Under heavier throttle, yes. I think we set the minimum around 70% input in the firmware. And then there are other factors like engine speed, boost level, etc, that contribute.
Normally means your DME BT is lower then. Current best log?
dRDiesel's Avatar
Car: BMW
Default 12-26-2018, 10:23 AM
I can get one today. I deleted all the logs off my phone last night as i sorta gave up until BEF is released (not sure if it would even fix this or not)
dRDiesel's Avatar
Car: BMW
Default 12-26-2018, 11:25 AM
Here is a log from today.
Default 12-26-2018, 12:25 PM
BEF will make things much easier. But I think it's fined fine, you could raise WGDC to get boost higher but then likely will be met with throttle closure as DME BT drops due to the internal fuel limiters.
You could try setting 6cyl timing = 1, FUD.2 on, to see if a higher spoofed IAT gets boost up for you.
dRDiesel's Avatar
Car: BMW
Default 12-26-2018, 12:29 PM
Thanks Terry ill try the higher spoofed IAT and see if it helps, but I donít want closures itís not a nice feeling.
dRDiesel's Avatar
Car: BMW
Default 12-26-2018, 01:15 PM
Here are 2 logs with IAT spoof on FUD set and 6-CYL timing on 1.
natlbar's Avatar
Default 12-29-2018, 09:06 AM
Who should I email?
Default 12-29-2018, 10:18 AM
payam@burgertuning.com
natlbar's Avatar
Default 12-29-2018, 11:01 AM
Thanks.
