katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 12-02-2015, 06:41 AM
Maybe bmw started working with Pure and did not tell us?;-)
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
DB90 DB90 is offline
Car: M135i
Default 12-02-2015, 06:54 AM
Originally Posted by Weehe
14whp difference from FBO with E50 in a DCT vs AT on pump and tune only. We also dont even know how much boost the DCT was on. In this case the B58 peaked 18psi and made that much. As for map 2, tune only on 93, that is right where (maybe 5-10whp more) this B58 is stock.
However, I do have to say this has a lot less torque than the N55.
I think the f-series n55 would stack up better to the b58 tbh.
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 12-02-2015, 07:37 AM
Would you say its faster stock than a jb4 map 2 on 93 oct ?? Isnt the b58 similar power like ppk bmw 335i ?
Weehe Weehe is offline
Default 12-02-2015, 08:11 AM
I have no clue. The car just came out. Just basing what I said off the dyno numbers
Dhillon92 Dhillon92 is offline
Car: '11 335i MT
Default 12-02-2015, 08:26 AM
I would say its better than the n55 in the sense that it holds its HP till redline. The numbers are close but the power band is much bigger, looking forward to the development of this new engine!
Newguy123's Avatar
Car: 12' 135i
Default 12-02-2015, 09:10 AM
im not saying it isnt better then the n55, just pointing out the n55 makes great power fbo on 18psi as well. map 5 without the n20 sensor is capped at 18.5 psi if i remeber correctly. will be interesting to see what this car FBO with some e85 and more boost puts down.
18 Glacier white RS3
#PURETURBOS
#FUELIT
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 12-02-2015, 10:52 AM
To get 380 wheel with just a tune and pump gas is impressive this early after release! Did you see any obvious restrictions on the exhaust or charge side where an upgrade might help (**, CP, etc)? How did IATs look with the W/A IC?
Keeping my fingers crossed for M240i
Default 12-02-2015, 10:57 AM
IAT seemed OK in runs where we ran stock timing. When we use the timing control we're altering the IAT signal back to the DME so can't accurately log it currently.
Abear Abear is offline
Default 12-02-2015, 12:02 PM
This is really impressive, great job Terry! Has there been any advance on the timing control for the N55. I know you said you were working on not too long ago.
Default 12-02-2015, 12:05 PM
For the N55 it hasn't been overly relevant as they are timed well for factory turbos. More advance doesn't add power and less drops power. In most cases.
For larger turbos without a back end flash we prefer to see them around 2 degrees less and we have the resistor trick which is basically a quick and dirty way of implementing what the JB4_B58 is doing. The difference being the JB4 control relies on CANbus to more precisely and dynamically alter the signal for the desired result.
ShlemN55's Avatar
ShlemN55 ShlemN55 is offline
Car: F30 335i msport
Default 12-02-2015, 10:37 PM
Can't wait for E85 testing I'll say it will hit around 415whp on e30 and jb4 ..
1993 Dodge Caravan ( Bone Stock )
2016 Tanzanite Blue F80 M3 jb4 , awe non res, bmc filters.
multydrew multydrew is offline
Car: bmw
Default 12-02-2015, 11:02 PM
Wow so lean afr.
Traf Traf is offline
Car: 2009 135i Coupe
Default 12-04-2015, 05:40 AM
Won't the higher compression ratio and the fact that the engine is even more undersquared than the N54/55 hold us back in the future?
84 mm x 89.6 mm 10.2:1 for the N54/N55/S55
82 mm x 94.6 mm 11.1:1 for the B58
f*** v-bands clamp
diesel3443's Avatar
diesel3443 diesel3443 is offline
Default 12-04-2015, 08:30 AM
fml and my n55
2011 E90 335i 388 whp/475wtq on E50
Default 12-04-2015, 10:44 AM
It's hard to say. It certainly seems to rev better, probably due to (what to me) seems like a better flowing turbo. The higher CR will probably become an issue at some point. We don't know how strong the pistons are either.
Default 12-04-2015, 02:26 PM
Seems like internals are forged and it is a closed deck. Should be helluva tough engine, or at least tougher than the N54/N55 right ?
f*** v-bands clamp
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 12-05-2015, 08:40 PM
Well, Im impressed.
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 12-06-2015, 07:50 PM
Getting excited now that this link is live:
http://burgertuning.com/B58_JB4_bmw_...nce_tuner.html
Default 12-06-2015, 09:05 PM
We'll be adding more photos and info there as we go!
LoveTwenty LoveTwenty is offline
Car: F30 320i
Default 12-06-2015, 11:26 PM
Really wanna see log and dyno numbers of MAP2 !!!
Direct ign control?..
wow amazing..
No need to consider about flash tune..finally..
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 12-07-2015, 03:31 AM
Have a friend visiting LA end of month..... lol would be nice if he could swing by to pick this up
ridgepug ridgepug is offline
Car: 435xi
Default 12-08-2015, 01:27 PM
Really excited to see what this car can do FBO + E85 on stock turbos
Daily Driver: F32 435xi N55: JB4, MPE, Resonator Delete
ShlemN55's Avatar
Default 12-08-2015, 04:21 PM
+1 ^^ Terry We need to see whats up with this Car and E85 ...
Nniftyfour's Avatar
Default 12-24-2015, 09:24 AM
Terry this wa obviously done on 91 pump how would you feel about the B58 being able to run stock timing on that map 1 with 93.
Knowing how advanced the modelling of the N54 is, I wouldn't feel fantastic about scaling IAT readings.
Nniftyfour's Avatar
Default 12-24-2015, 12:34 PM
I reread that was on 93. to myself
