str8shot str8shot is offline
Car: N54 135i
Default e85 bluetooth content analyzers and installation kits! - 07-24-2015, 11:34 AM
What you see here is my ethanol content analyzer (ECA) solution. This is 100% compatible with the Fuel-it brand sensor installation kits at a fraction of the cost.
This will allow you to read the data stream from a standard continental flex fuel sensor and view the data in several different ways.
All ECA's feature interlocking connectors, a new 5 volt power supply, are prewired for upgradeability (Bluetooth and the digital display can be added after purchase) and feature upgradeable firmware via USB.
Packages are:
Package A - Standard ECA; $80.00 shipped - my analyzer with a 0-5 volt output lead for use with JB4 (or any other display / ECU that uses a 0-5v input). This will display your ethanol content over pin 15 of the JB4 harness (typically used for meth flow). You can then view your ethanol content via gauge high jacking, over the JB4 mobile app, and it will be logged as well. Includes a full 8 foot 3-wire harness, using OEM style GT150 female connector for the continental sensor (completely weather sealed), loomed in factory style protection, with a interlocking connector on the ECA end. Also includes 5 zip ties to secure the harness.
Package B - Bluetooth enabled ECA; $105.00 shipped - the same analyzer and harness as above, plus the addition of a Bluetooth radio (Android compatible only). This will allow you to view your fuel ethanol content and fuel temperature on your Android smartphone or tablet via free smartphone / tablet app I've written (available at the Google Play store), or any of the above methods. V2 of the app should be available in early 2016, which will include blend calculators and a revised interface. Perfect for MDH, Cobb or JB4 users using meth.
Add on A - digital LED display add on; $30.00 - Add a fully digital red stand alone LED readout. Can be added after the fact, and does not require JB4 or an Android device. This LED display is compatible with either of the above ECAs by simply plugging in the harness and placing it where you'd like. Shipping is free when ordered with package A or B, or $6.90 if ordered separately to the continental US. Perfect for MDH, Cobb or JB4 users using meth.
Add on B - Bluetooth module; $35.00 - For non-bluetooth analyzers shipped 12-10-15 and on. Add a bluetooth module to your non-bluetooth ECA, to upgrade to the bluetooth capability and functionality of Package B. Includes a clear heat shrink tubing and a zip tie to bundle to the ECA. Shipping is $6.90 to the continental US. Perfect for MDH, Cobb or JB4 users using meth.
PM me if you'd like to order or for international shipping rates, and I'll provide paypal info for payment.
Here is the standard ECA:
Modular connectors:
Bluetooth enabled ECA:
New 5 volt power supply:
8 foot harness with GT150 sensor connector and removable JB4 0-5v output lead with serial pin:
Add on B - Bluetooth module:
Add on A - Digital LED display:
Three simultaneous outputs (0-5v JB4, Bluetooth and digital LED) driven at once:
Here is a screenshot of JB4 mobile displaying ethanol content using JB4 pin 15:
Here's a picture of JB4 mobile next to ethanol content on the fuel gauge (gauge hijacking in JB4):
Here is a screenshot of the Bluetooth app displaying ethanol content and fuel temperature:
Harness connected to the continental sensor:
Harness run across the engine using the empty channel in the cowl wire carrier:
ECA installed and running in the DME box:
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
Car: N54 135i
Default 07-24-2015, 11:35 AM
reserved.
dawhiz's Avatar
dawhiz dawhiz is offline
Car: 09 335xi
Default 07-24-2015, 02:21 PM
Awesome
Grip Grip's Avatar
Grip Grip Grip Grip is offline
Default 07-24-2015, 03:06 PM
Very nice! Subscribed
2009 335i XDrive (wife's)
Sold - '11 335is - N54 - DCT
Sold - '07 335i - 11.8 @ 120
Sold - '08 128i (wife's)
Car: N54 135i
Default 07-24-2015, 03:42 PM
Edit - pricing updated in top post.
TN54's Avatar
TN54 TN54 is offline
Car: N54
Default 07-24-2015, 04:18 PM
Pretty impressive stuff. Good work.
Will the sensors only be able to read the ethanol context when the car is on?
Certified Australian 335i N54 2009 DCT | JB4 | FBO | E85
Car: N54 135i
Default 07-24-2015, 04:23 PM
The sensor is directly powered by the analyzer, so that would depend on how you hook up the USB power supply for the analyzer. I have it powered off the DME relay in the DME box, so it shuts off ~10-15 seconds after you turn off the ignition.
If you connected it constant 12v, it would continuously read the sensor and broadcast the content.
spain4065 spain4065 is offline
Car: e82
Default 07-24-2015, 06:47 PM
Bump. This is awesome, gotta love the competition stepping out of bounds and giving us options!
feauto335xi feauto335xi is offline
Car: e90 335xi
Default 07-25-2015, 05:35 AM
Great Job!! I want! I've been Begging Fuel-it to take my money for like 6 months, I even ordered myself an arduino and lcd to program and install.. I was wondering when someone was going to grab the bull by the horns! Strong work!! PM Sent..
Car: N54 135i
Default 07-25-2015, 08:23 AM
Update - I'll be adding two additional leads that can be used for future use (JB4 integration, 0-5v out, etc). They'll be activated via updated code through the USB port.
You'd just need a windows PC to plug it into for a moment.
Nniftyfour's Avatar
Default 07-25-2015, 09:41 AM
LMK as soon as you have the E90 kit ready to go.
Car: e90 335xi
Default 07-25-2015, 01:39 PM
Love it!!!
4doorbmwpower's Avatar
4doorbmwpower 4doorbmwpower is offline
Default 07-26-2015, 07:04 AM
great stuff man.
Coming soon.
Spxxx's Avatar
Spxxx Spxxx is offline
Default 07-30-2015, 08:12 AM
Anyone have any good options for 0-5v custom LCD or LED gauge readouts that could be mounted in the glove box or elsewhere?
Car: N54 135i
Default 07-30-2015, 08:25 AM
Edit - pricing updated in first post.
Car: N54 135i
Default 07-30-2015, 08:27 AM
If this is something that garners a lot of interest, I'm sure I could come up with something for that as well...
Grip Grip's Avatar
Default 07-30-2015, 09:24 AM
One of these cheap $10 gauges would be great to just throw in the glove compartment.
http://www.amazon.com/DROK-Digital-V...ds=0-5v++gauge
Car: N54 135i
Default 07-30-2015, 11:33 AM
That would work for displaying the raw voltage, but you'd have to do the math yourself. Pretty simple though, just multiply the value by 20 and that'd give you your ethanol percentage.
Car: N54 135i
Default 07-31-2015, 11:47 AM
OK, I just looked at the gauge a little more.
It will do .xx precision under 10 volts, so what I could do is scale the ethanol content in .01 volts per 1 percent.
That would display .01 for 1%, .30 for 30%, .55 for 55%, etc. Great idea!
This could use one of the extra non-functional leads with a firmware upgrade. I'll get on this right away, seems like an excellent option!
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 08-04-2015, 01:05 PM
OK, I've got everything hooked up except for a display (fuel line, ethanol sensor, harness, wiring), which I currently have a frequency meter I keep in my glove compartment where I power up the sensor & read the frequency across a pull-up resistor (which I have been doing for about a year now).
What parts do I need from you to make this bluetooth or read into the JB4?
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4 ISO 5.5, Sport Oil Cooler Valve, FlexFuel (Fuel Rail Pressure) Wires, Wheel Lock Set, Ethanol Content Sensor - No problems up to E70 fuel mix
* Painted 7251 Cobalt Blue Metallic - Matches LeMans Blue
Car: N54 135i
Default 08-06-2015, 06:39 AM
You just need the analyzer and harness. I'm going to be revising pricing soon, so you may want to wait a day or two.
Car: N54 135i
Default 08-17-2015, 12:11 PM
Pricing has been updated - you'd just need an ECA. I could provide a few extra bullet connectors to connect to your harness.
wreckz's Avatar
wreckz wreckz is offline
Car: n54 TOOPL3SS
Default 08-17-2015, 08:57 PM
Great work will definitely hit you u when I get back from vacation
Car: N54 135i
Default 09-03-2015, 06:25 AM
Added a screen shot of the Android app.
It's a work in progress, but reads ethanol and temp at the moment - everything you need.
Car: N54 135i
Default 09-25-2015, 06:27 AM
Sold a kit with the digital meter.
Came out nicely and will look good in the glove box.
Gauge in action:
The sun was shining directly on the gauge and washed it out a little- it's very bright and crisp when in the shade.
