(#401)
naschine naschine is offline
Car: 135i N55 DCT
Default 08-16-2016, 11:01 AM
My car was/is I-level E89X-15-03-501 before flashing 98D0B PPK and everything is fine as far as I can tell.
I have the ISTA service log from my dealer right in front of me.
Supermand333 Supermand333 is offline
Car: 335xi e90
Default 08-16-2016, 08:55 PM
Can this be done using ncs dummy? ive coded my car with few hacks easy. Now want to move up to this. 2011 335xi lci
kingjulian kingjulian is offline
Car: 2010 135i DCT Lemans Blue / Lemon
Default 08-18-2016, 04:46 AM
No... WinKFP
2010 135i DCT (Le-Mans Blue/Lemon)
2003 E46 M3 SMG (Estoril Blue/Black)
2003 E46 330d Saloon (Silver Grey/Grey)
Car: 335xi e90
Default 08-18-2016, 05:48 AM
Ok. I'm having issues finding my file. I can't find my ecu. When I do the zusb it gives me error message I'll post it after work
Car: 335xi e90
Default 08-18-2016, 11:17 AM
On ncsexpert my ecu read on 63bmo. Mevd172.c03 and mevd176k is this usable? 2011 335xi lci
Car: 335xi e90
Default 08-18-2016, 11:20 AM
And on winkfp I cannot find my ecu.
Car: 335xi e90
Default 08-18-2016, 11:56 AM
I see where I ****ed up. I need sp daten v55. I'm on 53. Not going to work. Any help?
Default 08-18-2016, 01:43 PM
I've got a link somewhere, let me see if i can dig it out.
If not have a look on E90post
Car: 335xi e90
Default 08-18-2016, 02:04 PM
I got it. Found it on torrent. Now on winkfp what number do I put on it initially? And then flash it with which other? For 335xi 2011 sedan
Car: 335xi e90
Default 08-18-2016, 03:35 PM
I give up lol. It's saying the assembly line numbers are error idk some on help lol
Default 08-18-2016, 10:16 PM
You have a pm.
AtlasM's Avatar
AtlasM AtlasM is offline
Car: 2011 E92 335xi M Sport 6MT
Default 08-27-2016, 09:54 AM
I'm having a local coding guy do the PPK flash on my car as this is really outside my expertise. Using Zusub 8615936 for an E92 335xi with MEVD1726, he immediately got an error 201. Here are the screen shots he gave me. My car is a 2011 335xi MT. We went with the Zusub for MEVD 1726 because the description on the third line of the last screen shot says Motorelektronik ME VD17.2.6. This means my car is MEVD1726, and not MEVD17, right? Anyone have some suggestions?
Car: 335xi e90
Default 08-27-2016, 01:59 PM
Used mved12
Car: 335xi e90
Default 08-27-2016, 02:00 PM
Mevd 17 I meant
AtlasM's Avatar
Default 08-28-2016, 08:49 AM
Thanks, we tried again with ZB 8639128 for MEVD17 and everything worked fine, car now has the PPK burble and no errors.
The confusion was, we looked at the information in the third screen in my original post, that third line with the DME information says MEVD176K and in the description, ME VD17.2.6. The thought process was "MEVD176K is neither MEVD17 or MEVD1726, but it sure looks like 1726 in the second place, so I guess it's MEVD1726?" That of course turned out to be an incorrect assumption.
Car: 335xi e90
Default 08-28-2016, 10:20 AM
Make sure you send a fresh man file.
AtlasM's Avatar
Default 08-28-2016, 10:35 AM
Yup, he did, everything appears to be working fine.
itsboosted itsboosted is offline
Car: BMW X5 35i
Default 08-30-2016, 10:54 AM
Does this work for E70 N55? My VIN is L767855 and my control unit on realoem says MEVD172.
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 08-31-2016, 07:37 AM
Not officially...the PPK was only offered for the E71 (X6) with either a N54 or N63 engine.
What is your current DME ZB number?
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
Car: BMW X5 35i
Default 08-31-2016, 09:11 AM
Ok thanks, I tried searching for the X5 ppk and didn't see anything. According to the Cobb rom I exported my from car, I think the Zb number is 8666608. So jealous of you 1 and 3 series guys getting all the goodies like the Alpina transmission flash too. Other prioritis in life called for a SUV :-/
Car: 2009 BMW 335i
Default 08-31-2016, 10:06 AM
Your current ZB number (8666608) is a 98G1B ROM. You could try flashing ZB 8666660 which is a 98G1B PPK ROM intended for the E90/E92 LCI 335i xDrive using WinKFP expert mode.
They are intended for the same physical DME, the only thing that differs is the data set (calibration) version.
If it doesn't work, you can always flash back to stock. Both ZB numbers are available in the latest SP daten.
I posted a link to a WinKFP expert mode primer in this post:
http://www.n54tech.com/forums/showpo...&postcount=345
Pocari Pocari is offline
Car: 335
Default 09-05-2016, 12:45 AM
Is there a guide for flashing PPK? I was able successfully flash Alpina on my car following a guide but am a bit hesitant with the PPK. Step by step info would be awesome if someone can provide one.
cjdzombie's Avatar
cjdzombie cjdzombie is offline
Car: 2011 335i X-Drive, M-Sport
Default 09-06-2016, 10:24 AM
Looking for this myself. Just want to make sure I know everything before attempting.
Car: 335xi e90
Default 09-07-2016, 07:59 AM
No guide known of. Bmw charges for this. If know can code or program with Bmw tools and know how to use ncs you should be ok.
N55 Tech N55 Tech is offline
Car: '11 335i M-Sport
Default 09-07-2016, 11:45 AM
+1 for a guide
