MFactory MFactory is offline
Car: BMW E92 M3
Exclamation MFactory Solid Diff Bushings - 04-28-2015, 06:56 AM
we've just finished our new batch of Solid Diff Bushings:
- Made from Thermoplastic Vulcanizate, not cheap polyurethane
- Offers the hardness of plastic for a more solid mount
- Offers the elasticity of rubber for unsurpassed durability
- Self-Lubricating and resistant to oil and the elements
- Will not crack or deform like polyurethane or rubber
These replace all 3 of the Differential Carrier Bushings (2 x Front, 1 x Rear), effectively locking the Differential Carrier in place and removing any sloppiness associated with worn bushings.
The result is a much more stable rear-end, increasing traction and reducing wheel-hop.
Please Note: Due to the Differential Carrier having a more solid mount to the subframe, there may be a slight increase in NVH
MSRP: $149.95 + Shipping
Forum Special: FREE Worldwide Shipping
Please let me know if you have any questions
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 04-28-2015, 09:58 AM
this is WOW!
i bought them from ecs and havenot installed yet, if i knew you were making it i would wait
any plans for subframe bushings? maybe i would wait?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: BMW E92 M3
Default 04-28-2015, 10:00 AM
We have thought about it, but want to wait to see how well these Diff Bushings go down first
Levan-i's Avatar
Default 04-28-2015, 11:13 AM
ok
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: BMW E92 M3
Default 04-28-2015, 09:43 PM
Originally Posted by Levan-i
ok
Under development now
Levan-i's Avatar
Default 04-29-2015, 01:22 AM
Yoyyy perfect!
ill wait for it and then install all together!
thanks Stephen!
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
cmark8 cmark8 is offline
Car: BMW 135i N54 6MT
Default 04-30-2015, 12:02 PM
Put me down for the diff bushings!
Car: BMW E92 M3
Default 05-05-2015, 10:09 PM
Please send me a PM to order
Car: BMW E92 M3
Default 05-08-2015, 11:24 AM
Still a couple more left at the special introductory pricing
Whosdady Whosdady is offline
Car: 2007 335i Coupe
Default 05-22-2015, 06:57 PM
I'm interested but concerned about NVH. I currently have power flex purple... Which has no increased NVH over stock. Has anyone installed these and offered a review?
Car: BMW E92 M3
Default 05-23-2015, 03:57 PM
If you're not noticing any NVH with your current poly bushes, you won't notice any with these.
Default 05-24-2015, 08:03 AM
How tough is the install? Do they require a press or can they just be tapped in?
Are they as hard (material hardness) as the other options like solid aluminum/delrin offered by other companies? I was just about to install delrin but saw yours as another option...
Car: BMW E92 M3
Default 05-24-2015, 08:09 AM
They can be installed just like any other bushings, so not too difficult, no.
When we say "solid" bushings, we mean that they are solid in the literal sense, not in terms of hardness (i.e oem bushings are hollow).
When most refer to Aluminium/Delrin bushings as solid, they refer to their hardness (i.e solid instead of soft).
As our bushes are TPV (50/50 plastic/rubber), they still exhibit the same hardness/compression properties as hard rubber bushings, so are not as "hard" as Aluminium/Delrin.
Default 05-24-2015, 08:48 AM
Thank you for the clarification. I'm looking for a harder bushing...
gsxtasee gsxtasee is offline
Car: 2010 E61 535 awd
Default 06-14-2015, 07:27 AM
What do you got for my E61? Still N54 powered and modified and very in need of your support in this area.. Didn't see anything at all listed on your website for 535s...
Car: BMW E92 M3
Default 06-14-2015, 08:54 AM
I've never checked yet on the E60. Will need to do some research for you.
Levan-i's Avatar
Default 06-21-2015, 05:07 AM
Any news about subframe bushings?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: BMW E92 M3
Default 06-26-2015, 04:20 AM
Putting the measurements into the system just now, and will see if they are cost-effective enough for us to produce
Levan-i's Avatar
Default 06-26-2015, 11:09 AM
keep us updated about subframe bushings plz,
i'm still not installing diff ones i've got, waiting for subframe bushings to make all together
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 06-26-2015, 01:48 PM
Are these still available?
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
Car: BMW E92 M3
Default 06-26-2015, 09:52 PM
Yes, price is $149.95 inc free shipping
Levan-i's Avatar
Default 07-05-2015, 09:49 AM
any news?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Levan-i's Avatar
Default 07-14-2015, 08:35 AM
bump
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Levan-i's Avatar
Default 09-04-2015, 05:20 PM
subframe bushings
subframe bushings
subframe bushings
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: BMW E92 M3
Default 01-09-2016, 10:03 AM
All PM's replied
