(#2751)
ArsE92 ArsE92 is offline
Car: 2007 E92 335i AT
Default 07-25-2016, 08:04 AM
Originally Posted by Oryx
I wasn't personally attacking you, just referring to the situation.
JB4 and MHD are tools used to tune. The application of their capabilities to achieve a desired tune sure seems like a tool to me. An OTS tune doesn't always perform the same for every car and parameters may need to be adjusted. The same goes for both products. In many cases the use of both together can achieve the best results.
I would prefer to try and resolve without removing the JB4 if possible, but it seems I'm the only person having this issue. It's really quite bad. I can mitigate it a bit if I take my foot off the throttle completely when changing up, but that doesn't really work with an automatic.
I've never been able to get a reliable tune from this car. JB4 on map 5 just gives me 30FF/EML with WOT, and now the MHD back-end flash is doing this
khaledsaadeddine khaledsaadeddine is offline
kdean
Car: 2009 bmw e93 335i n54 (convertible)
Default 07-25-2016, 09:21 AM
will there be a map for us on stock turbos but have port injection and inlets ?
enrita's Avatar
enrita enrita is offline
Default 07-26-2016, 04:27 AM
Does the burble work on ST? I set medium 2.5 sec and nothing happens
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Sered's Avatar
Sered Sered is offline
Car: 10/06 E92 335i
Default 07-26-2016, 04:39 AM
It did for me, but I found it begins to foul the plugs after a while. Easy to clean them off with a full WOT pull; but it affected part-throttle drivability for me. So I turned it off.
2008 E90 6MT sports package, VM 6466g2, BMS PI, Fuel-It Stage 3+, JB4+MHD
2009 E89 Z4 DCT, JB4, MHD flash, DCI
enrita's Avatar
Default 07-26-2016, 07:02 AM
Ok thanks gonna turn it off
Default 07-26-2016, 11:18 AM
Ok. I've flashed back to stock through MHD and gear changes are ok now, running the JB4 on map 5. Weird one.
I would like to resolve as obviously I've paid for the MHD app etc.
So just to reiterate, using the MHD pump gas JB4 backend flash on a 2007 AT 335i. Any gear change upwards at anything like full throttle results in a horrible cut in power for a split second.
Any thoughts before I give up?!
Thanks in advance.
TwistedTuning TwistedTuning is offline
Car: 2007 335xi 6MT Sedan
Default 07-26-2016, 12:01 PM
Thanks in advance.
you 100% sure you're using an actual Back end flash? and not a regular flash only map?
"Increasing the Area Under The Curve"
Custom Performance ECU Calibration
www.twistedtuning.com
twistedtuned@gmail.com
Default 07-26-2016, 12:30 PM
I think so. I'm using JB4_MHD_I8A0S_PUMP.bin from the latest release
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-26-2016, 12:50 PM
When you use BEF do you set to menu 4/2?
Default 07-26-2016, 01:31 PM
Nope! I didn't even know that option existed. I'm assuming it has been added in a recent firmware?
I'll go and try it now. If it solves my problem I will give you a massive bear hug.
Default 07-26-2016, 03:23 PM
Turns out I should read a bit more before jumping in to these things!
Gear-changes are now much better. I wouldn't say perfect but I only had a quick spin around the block to test.
I'll test properly tomorrow and report back.
Thanks for your help.
Rushan's Avatar
Car: 335i E92 2009
Default 07-27-2016, 10:54 AM
you can also check your logs to see if that due to overboost on gear change oh may increase you shift reduction from 60 to 65 or 70 and see which reduce the overboost.
Anyhow make sure to have couple of 3rd gear 2500 rpm to WOT to make sure your car and JB4 auto learn your car
Good luck and be safe
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 07-28-2016, 01:46 PM
Originally Posted by BobVader
How I can change setting like"bug shift" etc... In bef. I have bef race for jb4 for now.
Thank
Adjust the flash options before confirming the actual flashing of your map.
Originally Posted by AdamHarbour
Anyway to make the exhaust burble work when stationary??
The day we know how to do it!
Josh1a1h Josh1a1h is offline
Car: 335i Pre LCI e92
Default 07-29-2016, 06:48 AM
Possible silly question.
I am running the MHD with just BEF and my JB4.
BUT... I cannot access the option area where exhaust burbles etc... may be.
I take it this is not a possibility on a BEF?
UK Based | JB4 32_2 | MHD Race BEF | VRSF DP | VRSF 7" IC | Tial Bov w/ VRSF CP | BMS DCI | BMS Meth |
BostonBeemah's Avatar
Car: AW 135i
Default 07-29-2016, 01:26 PM
Something like the sound of the PPK on the n55 would be awesome! Some burbles on revving at a standstill is all my car is missing now to really piss everyone off lol
https://www.youtube.com/embed/OSOETlBHs9A
RIP 2008 AW/BL 135i
Default 07-29-2016, 02:12 PM
Option button works, but you have to have the new versions of the MHD app. Reflashed my car today.
N54 | Build Thread
darkrom darkrom is offline
Car: 135i N54
Default 07-30-2016, 06:59 AM
I 100% get burbles while reving in neutral right now. You have to rev to like 3-4k and let off. I'm set to 5 seconds of aggressive, but that will be changing soon, just too much to keep daily driving it that way.
Is there consensus that burble mode does in fact foul the plugs? I'll probably be switching to 1 second or so of aggressive burble.
BobVader's Avatar
BobVader BobVader is offline
Car: 335xi 2008
Default 07-30-2016, 09:51 AM
+1
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB4 G5 iso|MHD bef Race|Hexon rr600|inlets|stage 2 fuel pump|N20 tmap 3.5|Chargepipe|Diverter valve|RB pcvalve|BMS Meth kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP|BMS DCI|AA Exhaust|HELIX fmic|CDV|H&R coilover|10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, before new turbo and inlets...new results soon...11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph 7.9,
LOANER's Avatar
LOANER LOANER is offline
Car: 2007 E90 335i MSport
Default 07-30-2016, 07:21 PM
I set base to 0 and sports to aggressive. Pull up next to Mr Officer and switch to base, no more burble lol.
Default 07-31-2016, 02:43 PM
That is odd.
I have the latest MHD app and flashed it with the latest JB4 BEF. But still no options...
Default 07-31-2016, 03:10 PM
Just email MHD they should be there.
BobVader's Avatar
Car: 335xi 2008
Default 08-01-2016, 11:53 AM
I have mhd jb4 bef race on my car. Dyno next monday. Test with ms109 and e30+ meth...after I want test e50+....I will need jb4 bef e85.
My question... For reflash I must flash stock before or I can flash directly with e85 flash. And take 38 minutes again?
And I will post all my result with my hexon rr600
OldBooster's Avatar
Car: 2008 135i AT
Default 08-01-2016, 01:47 PM
Hello all, my 135 has been down for a couple months now. I've done everything possible to cure a major misfire (drops cylinder totally) on Cyl.#1 (only). Runs fine, drops cylinder, back to running fine. No carbon problem, and compression 177-180 on all 6 cylinders. I just sent my DME off to RPM Autosports to program a used one.
My question is how will I install my existing MHD flash system into the new DME? Is it transferable? My VIN number will stay the same of course. Can I simply hook up my tablet and flash a selected map, or do I have to go through the initial longer flashing process again? Many thanks.
PS: I will be reinstalling my JB4 again for the features and benefits.
UPDATE: After I installed the replacement DME, I have No more codes, No more misfires, No more suicide thoughts. After all of the money, months of work, headaches, sleepless nights, research, down time ... it was the DME all the time. It's the best $600 I've ever spent. Thank you Chris at RPM Autosports.
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Rushan's Avatar
Car: 335i E92 2009
Default 08-01-2016, 03:36 PM
You just flash the new bin and it's 2 min, you don't need flash back to stock
BobVader's Avatar
Car: 335xi 2008
Default 08-01-2016, 05:12 PM
