(#101)
Default 02-03-2015, 05:08 PM
We only have the connectors with our kits. But, when time permits, I'll make a DIY showing you where everything connects.
BeGooD69 BeGooD69 is offline
Car: 2007 335i
Default 02-03-2015, 05:29 PM
Ok so count me in for one as soon as u have them released.
Any ETA?
Turbo_chris Turbo_chris is offline
Car: E90 335i/6 Msport
Default 02-03-2015, 08:05 PM
Is there any benefit to running port injection on my E90 N55 if not using E85? They closed down 1 of our 2 stations in Raleigh and it's just not readily available on the east coast.
I'm debating on picking up a meth kit or the port injection kit. But don't want to get PI if octane is what's holding me back.
2010 535i - 2012 X5D - 2010 GL550 - 2005 Porsche Cayenne S
Default 02-03-2015, 09:00 PM
We can use my car if you want
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 02-03-2015, 09:06 PM
Since making a custom in house solution is so far off schedule we're in the process of bringing in specially made Split Second AIC1-V6H/EV6 boxes for this kit and plan to add them to our site in few weeks. We expect to sell them for around $319 with PnP connectors for power, rpm, boost, and the injectors. We'll probably shelf the integrated solution for now given the low cost of this 3rd party PNP solution that I expect will work just as well. As well as a better combo price if you buy the entire setup from us.
Can't beat getting additional fueling from outside the OEM fueling system such as this (it has enough issues as is). Plus the PI will keep the intake valves clean, finally a great fix there! All with the added bonus of all being integrated into the JB4/SS via PnP hardware for simplicity and tuning features. This setup is the future of N54 fueling for sure!
Good work Terry!!
Rob
threethirtyfive threethirtyfive is offline
Car: 335i e90
Default 02-04-2015, 07:33 AM
Originally Posted by kenjermen
That still didn't answer the question why can't you run it with e85, if anything it would help the leave the stress from the fuel pump
Are you missing the dozens of posts? You can run it with Meth if you want but you are...
1. Wasting your money on the PI kit
2. Wasting your money on the Meth kit
3. Not getting a benefit
If you want to run redundant systems and burn extra meth, go for it. No one is saying you can't, they are saying you don't need to. It would be like adding an ATW intercooler on top of our ATA intercooler, no need.
'07 e90
Default 02-04-2015, 09:46 AM
Sounds like a plan.
N54FAST's Avatar
N54FAST N54FAST is offline
Car: 2010 bmw 335i
Default 02-04-2015, 07:34 PM
Why use 55# injectors? would it be safe to use 60#?
Default 02-04-2015, 07:46 PM
You can use whatever you'd like on injectors. I like the extra resolution from the 55 range injector and guesstimate they will flow for up to 800whp. If you are planning on going beyond that larger injectors might make sense.
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 02-05-2015, 09:28 AM
What type of injector needs to be used, and which connector style for your wiring harness?
Default 02-05-2015, 09:45 AM
We're using these: http://www.boschdealer.com/product/5...or-0280158117/
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 02-05-2015, 10:12 AM
11 or 14mm upper O-ring?
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
Default 02-05-2015, 10:15 AM
14mm
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 02-05-2015, 12:22 PM
Terry nobody looks at the support section
Do more with less !
Default 02-05-2015, 12:23 PM
Russell @ BMS does. But if you post doesn't meet the support section criteria it might be ignored: http://www.n54tech.com/forums/showthread.php?t=24991
n54 power's Avatar
n54 power n54 power is offline
Default 02-05-2015, 03:01 PM
Hi Terry.. i wait secondary fuel kit with all part all controller
4doorbmwpower's Avatar
4doorbmwpower 4doorbmwpower is offline
Default 02-08-2015, 09:56 AM
well terry, im saving up. I saw how you stated it requires a separate controller for now but will soon be integrate with the JB4. I will see where my power levels are after this stage of my cars build and ill be putting a Stage 3 LPFP in from Steve. Ill be all ready for one of the Port injection kits, but seeing how your the only one tapping into the N20 TMAP sensors capabilities and you will be able to run this PI system from JB4 in the future I may have to buy one from you if not for anything else to run 28psi on my VTTs and not worry about fuel.
Blaster400's Avatar
Blaster400 Blaster400 is offline
Car: 2007 BMW 335 E92
Default 02-09-2015, 09:47 AM
How difficult is it to dial in the Split Second controller settings after installation?
JB4 G5 w/BMS MHD backend flash | MOTIV 750 | 100% E85 | MOTIV port injection | Fuel-It Stage 3+ LPFP | Akrapovic Exhaust | DSS Axles | DEFIV lockdown kit | Quaife LSD
1///M's Avatar
1///M 1///M is offline
Car: BMW 1M
Default 02-09-2015, 11:43 AM
Terry, how far are you with a bundle deal?
RHD Top Mount ST
n54 power's Avatar
Default 02-10-2015, 03:05 PM
when is this kit ready
Default 02-10-2015, 03:08 PM
The maps we provide basically handle it out of the box. So not much adjustment is needed. But if you do want to custom tune it, it's fairly easy to do.
Blaster400's Avatar
Default 02-10-2015, 03:23 PM
Perfect!
n54 power's Avatar
Default 02-10-2015, 03:31 PM
I'm New Here ,, I apologize
Car: 2007 335i
Default 02-12-2015, 10:15 PM
Hey Terry, Wut s the status on the AIC1 controler? ETA? Need one as soon as u get them in...
Default 02-12-2015, 10:20 PM
Don't worry -- when they show up, we're not going to forget to sell them to you guys.
