Dr3K0 Dr3K0 is offline
Unhappy need some advise on an issue. - 01-07-2014, 06:18 PM
Hi guys, I have been away for a long time due to massive work schedules. I have been putting money away to do a pretty decent upgrade to my 135i and since is out of warranty I was about to pull the trigger into pretty much all can fit into it (with the money I saved) but a turbo upgrade. BUT my daily driver, a 2004 Volvo s60 2.5t broke down.
So a simple fan and radiator replacement ended into a lot of **** to get replaced. @ 195k there was a lot to go wrong. But the engine itself is pretty good shape. So I had to buy a turbo and several other parts to make it run again. After some research decided to buy a k24, exhaust manifold from a s60R. The turbo is bigger and will yield some more power. I'm not looking into making real power like the bimmer but you get the point. If I have to replace the turbo, why not get a bigger one.
Ok, what I need advise is that since the high millage of the car I bought an used turbo with 84k miles. Its not low but not a lot either. Remember, I'm trying to save $$ here to put it on the bimmer.
I received the turbo today and after inspection found some oil on the turbine section. The compressor side looks ok. The cartridge don't have in/out movement but has a little up/down movement. I know its used but to my understanding this is not good used turbo due to having oil on it, but I want some opinions to be sure.
Please look at the pic and give me your opinion.
https://m4vl1g.dm2304.livefilestore....Pro.jpg?psid=1
Thanks for the help
Dr3K0
Default 02-15-2014, 06:50 PM
At 84k most turbos for N54 are toast. I wouldn't install the ones in the picture. $1,200 with Tischer gets you a brand new pair.
Do it right or sell the car.
Pitch Black's Avatar
Pitch Black Pitch Black is offline
Prodigal Son
Car: 535xi
Default 02-19-2014, 03:19 PM
Rebuild if you are inclined to. I rebuilt a T3/T4 years ago its not tremendously hard but I'm not your average weekender.
As is those turbos are not worth installation.
Current Ride: Still picking one
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 02-25-2014, 09:54 AM
Can't go wrong with RB Turbos!!!
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
P90Puma P90Puma is offline
Car: 08 135i FBO
Default 02-25-2014, 04:30 PM
What thread are you guys responding to? He is talking about a volvo turbo?
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 02-25-2014, 11:01 PM
Lol RB's on a S60
