(#10876)
Default 04-02-2017, 01:43 PM
First post is generally accurate, as far as I recall. We'll have an updated version with 32.7 since we added the 2 M3 clusters to menu5 and relocated startup sweep to 6/8
PitbullN54's Avatar
PitbullN54 PitbullN54 is offline
Meat Popsicle
Car: 08 BMW 335xi
Default 04-04-2017, 10:05 PM
So I read as much as I could but I couldn't find anything about hooking up a scan tool to the obd2 port. I have trouble reading live data with my scan tool. I don't remember having any issues reading codes but that was always with the engine off key on. So I can read data for a min or two and then I will get an error saying trouble reading data and kick me out of live data. I've tried with the jb4 setting at 0. At first it was in map 4 or 1 maybe even 5 not sure. Point is what am I doing wrong? Also I hope I didn't mess anything up with the jb4 having doing this. Everything seems to be working as intended though. I won't be reading live data anymore until I know how I should go about it.
08 BMW 335XI - CPE chargepipe - Tial BOV - Jb4 ISO - DCI - VRSF 3" Kittenless Dp's - VRSF 7" FMIC - VTT GC lite - 1 Precision driver
Default 04-05-2017, 08:24 AM
With the JB4 you would use the JB4 for datalogging and reading codes. You connect to the JB4 via a BMS data cable or JB4 mobile connect kit.
PitbullN54's Avatar
Meat Popsicle
Car: 08 BMW 335xi
Default 04-05-2017, 05:29 PM
I can do all that just fine. But I would like to also be able to use my scan tool of a problem arises so I can see more data. I'm a technician so I like to see more lol
Default 04-09-2017, 08:54 PM
You'd set the JB4 to map0 to use an external tool via the OBDII, but won't be able to log, etc. There is no data you'll need from logs that are not included in the JB4 log set. Which samples boost at 30hz and all other CANbus data at 10hz.
serhat06 serhat06 is offline
Car: 05 e55 amg/ 07 e92 35
Default 04-10-2017, 09:41 AM
does jb4 delete only for dp`s or does it delete all the codes?
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 04-10-2017, 03:33 PM
If you have auto clear I guess it delete all codes
Sixbanger Sixbanger is offline
Car: i
Default 04-10-2017, 08:05 PM
What option on the steering wheel controls keeps codes and doesn't automatically delete them? 08 N54 135i JB$ ISO5. The chart in regards to "codes" is confusing.
Boost'n e92's Avatar
Boost'n e92 Boost'n e92 is offline
Car: 2007 335i e92
Default 04-10-2017, 08:21 PM
1/4 will keep them, 1/3 is auto delete, and I think 1/2 will erase codes if 1/4 is on.
2007 335i e92 space grey, a/t, fbo, mfactory lsd and boost addictions diff lock down, bmw pe mod, xHP stage 3, mmp stage 3, inlets and outlets and eos pi, custom tuned by pure evil estimated 620whp on e50 23psi. Current 1/4 mi 11.9 @116 on stock turbos.
Suspension: Koni yellows eibach lowering springs
Wheels: iforged Daytona 19x9.5f 19x10r
Drop a gear and disappear.
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 04-12-2017, 12:58 PM
So aside from 2 additions to menu 5, this is still good?
Car: i
Default 04-12-2017, 02:08 PM
still not able to enable 1/4. WHen I go back and check it's not saving.
Default 04-12-2017, 03:10 PM
If the menu 1 defaults to 0 then auto clear is NOT enabled and your 1/4 selection worked. Only 1/3 enabled would default to 3.
Kebinuu Kebinuu is offline
Car: 07 e92 335i
Default 04-14-2017, 09:38 PM
Is there still a Map 8 NA/Economy mode? Or is it now a Meth dedicated map?
Default 04-15-2017, 02:15 PM
Map 8 is not assigned on twin turbo N54 firmware, currently.
martymil's Avatar
martymil martymil is offline
The Backyard Mechanic
Car: BMW 1 Series M
Default 04-15-2017, 02:38 PM
Is it possible to make a jb4 cable to charge an android pad as the batteries in these things don't last on long drives.
It would be good to have it logging in the background and not have to worry about the battery running out
Default 04-15-2017, 02:44 PM
Donnie can probably help you with that.
martymil's Avatar
Car: BMW 1 Series M
Default 04-15-2017, 03:08 PM
don't want a Bluetooth kit, but want a hardwired solution
I had the bluetooth kit before and my android devices always had issues with it but not with cable. A jb4 cable with a power circuit would be the way to go
Default 04-15-2017, 03:18 PM
He sells hardwired solutions, too.
martymil's Avatar
Car: BMW 1 Series M
Default 04-15-2017, 03:35 PM
Ah OK, didn't see it on his website
doc 335 doc 335 is offline
Car: bmw 335 e90 n54
Default 04-26-2017, 07:03 AM
hi guys i loaded the latest firmware and now my gauges still sweep but the problem is the rev counter sweeps completely and the speedometer only sweeps halfway
what could be the problem?
Default 04-26-2017, 08:03 AM
Reselect your menu5 option. If you still have the issue just email me a short video and I can send you a fix.
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 04-26-2017, 11:31 AM
Email me for help with M3 clusters.
Thank you! Is perfect now.
dh58 dh58 is offline
Default 04-28-2017, 04:00 PM
Terry,
I'm using a www.gofar.co in my car and I'm wondering if there is anyway this could be slowing down the JB4 or BEF because it's reading/saving data from the DME via OBD2.
I've been feeling the car isn't pulling as hard and i'm wondering if its got anything to do with this or replacing tyres (identical, just replaced with new).
I know you're probably going to ask for logs but I thought this might be one of those situations where its a definite, don't be doing so much on the canbus kinda situation.
This is my setup:
- MHD BEF (Running a few firmwares behind)
- JB4 (Latest flash)
- JB4 BT Kit + App
- 135i n54 Auto
Mods:
- TBI + stage2 lpfp + fuel sensor (FuelIT platinum)
- 100% e85
- Full bolton
Default 04-28-2017, 04:06 PM
If you need tuning help post a jb4 log and details in the support area and myself or Steve will check it out!
Default 04-28-2017, 10:34 PM
I'm more asking... would something on the OBD2 port reading/saving quite regularly in anyway affect JB4?
