(#6876)
kingsorder's Avatar
kingsorder kingsorder is offline
Default way to good burger motor - 06-25-2013, 06:02 PM
just want to express how well done this company is
2 thumbs up for Jeff who guide me through pre buying and
after installation question
now I have Happy 135 engine , more good time will flow
fast and furious too lol
anyway burger motor all the way
may the force be with you
OldBooster's Avatar
Car: 2008 135i AT
Default 06-26-2013, 06:21 AM
It's nice to see another speed freak join the fray after only 1 post. Some of us have been praising Terry and his top notch crew for years -- I have, since 2008. You weren't around for the years of evolution of the JBs ( JB+, JB3, JB4, G5, ISO ... and a lot in between). You're jumping in at the best time ever. While we struggled at times to catch up with the improvements, you have the luxury of having it all with no sacrifice. Enjoy!
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
spencer123 spencer123 is offline
Car: 1M
Default 06-26-2013, 07:27 AM
Originally Posted by BEAR-AvHistory
Did you try map 6?
What settings are you running and why vs map 5? I am a 1M and previously(a while back) ran map 6 until some adjustments were made to map 5 for the n54tu. It was great on map 6 with the settings I had been provided but once the updates were made I've been only on map5, so curious what your setup is and what your reasoning/experiences are.
I do feel that we should probably break out a page for those with 1M's/335is as its all close but all a little different what works what doesn't etc and its hard to decipher what is applicable and normal for our tuning+jb4.
BSM 1M, BMS MHD w JB4, Pure Stg 2 DD, FBO, Motion Control Suspension, Stoptechs, big sticky tires, lost control at some point.. M6GC 6MT w JB
kingsorder's Avatar
Default 06-26-2013, 07:35 AM
yes , you are correct . thanks everyone for the hard work.
ashmostro's Avatar
ashmostro ashmostro is offline
Car: 2013 335is DCT
Default 06-26-2013, 08:10 AM
Seconded!
2013 335is DCT -- Quaife | JRZ RS1 - 450/800# | M3 + Hardrace arms | e93 M3 + Hotchkis f/r sways | BMS CP + OCC | ETS 5" IC | AFE DP's + DCI | RB PCV + Thermo Delete | Setrab + Improved Racing oil cooling | Stoptech f+r BBK | Cobb BQ Tune
BEAR-AvHistory's Avatar
BEAR-AvHistory BEAR-AvHistory is offline
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
Default 06-26-2013, 09:59 AM
I have been using map 5 with E85/93 mix which can vary with each fill-up. Typically would run map 2 on the way to the station to clear the settings then go to 5 after the tank was filled. Hit 3 runs at WOT in 3rd to acclimate it.
The E85 station closed & I am back to the 93/100 mix that I used to use. I have been using a fill at 1/8-1/4 tank with 8-9 gals of 100 ($70) the balance with 93 & using Map 6.
I found the boost is very close at peak about 17.5 or so with no timing pulls & trims within the OK range. I asked Terry about it & he said given the choice he would prefer Map 6 because its consistent.
I have been experimenting with the stock map 6 + 1.5psi or 2psi across all entries. All else on default except for a "5" for the DCT downshift setting. Additionally I have a small wood block to prevent hitting the auto downshift at WOT.
Over all the target & boost lines are just about a perfect overlay & the car is very smooth to drive. I still should see how much I can reduce the 100 by & still maintain the boost but have not gotten around to it.
My understanding which could be wrong is that the 335is factory timing curve is more tolerant of boost than the 335i & the 1M is another step more tolerant than the 335is. On a Dynojet my pure stock runs with 94 octane were 319/320whp. IIRC the 1M generates more power stock
To see how it works for you I would go up 1psi at a time & send the logs to Terry if you have any doubts about how they look. Thing with E85 is to watch the trims.
Would like to get chance to drive a 1M some time as my 135is is a lot of fun & much more agile then the 335. Only issue I have with the 135is itís a N55.
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
///ADMAN ///ADMAN is offline
Car: 2013 BMW 335is
Default 06-26-2013, 05:59 PM
I found 2 stations with E85 on my way to/from work. I park between the two pumps so I can mix with 91 easily. I have been running MAP6 with the fixed boost settings I posted before. The car seems to like it, even the heat. I max out at 16.5 psi, tough.
I don't mind. I always run SPORT-SPORT so everything is very consistent, even with the A/C on. D-AUTO drives like crap. I could get out and change my tire between shifts. At night, 1st and 2nd still hit pretty hard, but usually you can't even feel 3rd-7th. Just pure acceleration.
2013 BMW 335is Convertible
ashmostro's Avatar
Car: 2013 335is DCT
Default 06-26-2013, 06:16 PM
Adman, are you fbo?
mdyates mdyates is offline
Default 06-27-2013, 07:34 AM
I second this!
2013 335iS DCT, Alpine/Saddle
JB4, BMS Flash, DCI, BMS Dp's, Inline
*RECORD 1/4
11.5 @119 mph*
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 06-28-2013, 04:40 AM
Can someone please confirm that Menu 11 Open Loop/Fuel Pressure should be set @ 2,000rpm?
Just need to make sure that i haven't stuffed something up.
Cheers!
Car: 2013 BMW 335is
Default 06-28-2013, 10:50 AM
Originally Posted by ashmostro
Adman, are you fbo?
Yes. I found what worked for me. I am no longer "chasing the tune" anymore.
Car: 2013 BMW 335is
Default 06-28-2013, 10:43 PM
Terry, I am showing EXTREME intake temperatures. Any idea what it could be???
I'm pretty sure the outside case is melted by now. Just saying...
ashmostro's Avatar
Car: 2013 335is DCT
Default 06-29-2013, 07:42 AM
Silly man
Default 06-29-2013, 08:42 AM
Insane weather there!
zeel zeel is offline
Car: AW e92 335i
Default 06-29-2013, 11:11 AM
ok I can never complain about heatsoak again after looking at that...
11.76@124 (123.9) fbo + e60 mix + street tires + stock exhaust. no meth.
MrNeef MrNeef is offline
Car: E60 535i
Default 06-29-2013, 12:28 PM
Originally Posted by brendan
I think i have read on here before (not sure if its this thread) that menu 11 is 3500rpm (70). anyone second that. I've accidently touched it and car bogged heaps when i put menu 11 up accidently when playing with wastegates
Menu 11 is for Open Loop
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 06-29-2013, 03:29 PM
Got you beat..... mine showed 120 yesterday on I-17.
Suppose to be hotter today
XxWarderxX XxWarderxX is offline
Default 06-29-2013, 10:03 PM
Today was the 4th hottest day recorded.
Seavita Seavita is offline
Car: BMW 335 CSI
Default 06-30-2013, 05:23 AM
Hey everyone quick question, on my laptop f1 and f2 (start logging and stop and display) don't seem to work. The reason being is while f1 starts it when I hit f2 that also happens to be my display brightness control and that seems to take precedent. Anyone else have this issue?? Any solution?
Also, and maybe this is not needed as it logs for 8.5 minutes, but just thinking it would be interesting(and maybe safer) to have a steering wheel control start and stop logging.
Sleeper edition Cabrio 3 series
Performance: JB4/G5 ISO MHD Flash, RB's and HiFlow oil returns, BMS DCI, PLM ***, cp-e FMIC & OC, aFe scoops & Throttle body spacer, Alpina TCU Flash, Stage 2 LPFP bucketless and Platinum PI by SteveAz, Mspec LSD, Cp-e charge with tial BOV, RB inlets and VTT outlets (let them fight my car doesn't care)
aoschadlin's Avatar
Car: 535i
Default 06-30-2013, 07:55 AM
Do you happen to be running a virtual machine on a Mac?
If so you'll need to hold down the *fn* (function) key while pressing the F1 and F2 keys.
Actually this may be the case even for some regular Windows laptops. Some manufacturers just make these things hard.
Car: BMW 335 CSI
Default 06-30-2013, 08:37 AM
Yes windows HP laptop will try the Fn key but all the more reason then (well at least fro em) that integrating into steering wheel control would be awesome
NihonX NihonX is offline
Car: 1M
Default 06-30-2013, 10:40 AM
Yesterday it was 117 degrees here in Antioch, Ca. (52 miles east of San Francisco)
Car still runs well.. Except the heat tends to soften my vacuum/boost hose and gets blasted off the blow-off valve if I go WOT.
335is 7DCT/JB4
Default 06-30-2013, 10:41 AM
On G5/ISO Map 0 does the exhaust flap automatically revert to normal function?
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
Default 06-30-2013, 11:47 AM
Yes.
r45t4m4n r45t4m4n is offline
Default 06-30-2013, 12:26 PM
You need to find a higher temperature rated tube. That sounds annoying.
