(#126)
Default 05-31-2019, 06:20 PM
There is more we'd like to do but it's a small market so we're working on building out our customer base. Helping spread the word and get more units out there will help us with the future development.
No not me, you're probably referring to Son who works here doing system assembly. He's on the mend. Bad case of Pneumonia!
russelsfl russelsfl is offline
Car: 2016 Lexus is200t
Default 05-31-2019, 06:28 PM
Im sure I speak for the rest of us, hope Son gets 100% soon!
You can count me in as a tester or whatnot. Im repping the jb4 tuned license plate frame here in south Florida, and Im computer savy, just new to turbos and tuning but I have lots of questions and I learn fast. Only caveat is my car is my daily driver so as far as testing is concerned
Can you tell me, what is this boost safety feature?
Ben_is_lol Ben_is_lol is offline
Car: Lexus Is200t
Default 08-16-2019, 10:24 AM
Hi all,
finaly i have log my jb4.
Following tune i have, K&N drop in Air Filter, HPS Intake Tube, Remark Axle Back Exhaust.
I run Map 2 on "Shell VPOWER" GAS 100 ROZ.
@Terry
can you analyze my tune and optimize something?
Edit:
.csv is now attached
Default 08-16-2019, 01:46 PM
Attach the CSV to your post directly.
Car: Lexus Is200t
Default 08-16-2019, 01:50 PM
Sorry, now i have attched the file.
Default 08-16-2019, 02:29 PM
Originally Posted by Ben_is_lol
Hi all,
@Terry
Edit:
This looks fairly normal... The problem with the 200i is the small turbo so much of the power gain has to come from higher timing advance.
Run a log on map5 for comparison.
Car: Lexus Is200t
Default 08-17-2019, 01:14 AM
thank you.
I have attach you a log with map 5.
Default 08-17-2019, 06:46 PM
Map5 looks OK to me. If it's working better for you than map2 you can stick with it.
Car: Lexus Is200t
Default 08-17-2019, 10:22 PM
Okay, thank you.
In the past i Never use map 5, but now i find i run very well.
A Little Bit better than map 2..
PATCHEZ PATCHEZ is offline
Car: IS200t
Default 09-08-2019, 11:51 AM
is it worth upgrading to the jb4 from the stage 1??
what would i expect from the jb4? is there slight air fuel ratio stuff or is it still just psi boost but being able to select when the boost gets bumped up by gear logging and code reading?
Car: Lexus Is200t
Default 09-17-2019, 09:45 AM
Short Information: After running map 5 a few weeks i noticed that the boost is fluttering at ~50% throttle, not all time and not in all gears but me and other passangers can feel that the car does not accellerate constantly.
I switched back to map 2 all Fine.
Car: IS200t
Default 09-17-2019, 05:10 PM
keep in mind the vacuum regulator tends to fail around 30k.
i had this issue, had it replaced problem solved
Car: Lexus Is200t
Default 09-17-2019, 11:32 PM
Yes think the same but why okay with map 2? But thank you for the reply
Car: IS200t
Default 09-18-2019, 09:07 PM
idk tbh but i really would like to know if it's worth the upgrade from the stage 1 to jb4
what do we get with the upgrade? is there air fuel tuning also?
Car: IS200t
Default 09-25-2019, 03:30 PM
bump =]
Aerix Aerix is offline
Car: Lexus IS200T
Default 10-10-2019, 03:26 PM
Good afternoon,
I just received the Lexus JB4 Tuner and the JB4 Device Wireless connection kit from you guys. The installation seems fairly simple. However, the TMAP male pins wont plug into the factory female connector. It doesn't go all the way in and connect. See image:
Are you able to confirm that this is an issue and do you have any recommendations? I'm not sure if the pins may be crooked or the plastic piece inside are in the way. Again, any troubleshooting recommendations will be greatly appreciated.
Default 10-11-2019, 01:48 PM
Originally Posted by Aerix
Good afternoon,
Link is broken.
Email support@burgertuning.com
Car: Lexus IS200T
Default 10-11-2019, 02:37 PM
How about now?
Default 10-11-2019, 02:43 PM
That normally happens if the white insert on the factory plug is not seated properly. You could remove it all together as a test.
Car: Lexus IS200T
Default 10-11-2019, 04:14 PM
How does it get removed without damaging the components?
Default 10-12-2019, 09:13 AM
When you unplug the connectors you'll see the white insert slides in and out.
Schwag Schwag is offline
Car: IS200T F-Sport
Default 11-17-2019, 10:29 AM
I am having an odd issue with my JB4 currently. I run map5 or map2 currently, being FBO. I originally had the boost controller issue, that is fixed. It is intermittent, like the tuner goes into a limp mode, even on map0. The only thing that can fix the issue is power cycling the car or disconnecting it all together. Is there some new firmware or is there something wrong with the mainboard/IC? It's only about a year old.
Default 11-17-2019, 03:32 PM
If you need tech support email in, but first steps if you get faults on map0 are to try disconnecting the OBDII cable to see if it's related, and open JB4 enclosure and take photos so we can confirm no water intrusion or physical issues on the board.
Car: Lexus IS200T
Default 11-25-2019, 09:50 AM
Hey,
So, i have the jb4 tune with the bluetooth and I'm able to log in to the app however, the displays are not working at all. Is there anyway to fix this?
i'm able to see which map settings i have selected, but that's pretty much it.
this is the only info i have about firmware
Thanks,
phantomx47x phantomx47x is offline
Car: 2016 Lexus IS200t F-Sport
Default 12-31-2019, 04:31 PM
Hello,
Just installed the JB4 and bluetooth app for the IS 200T. Overall very happy with the results altogether. I'm also experiencing what Schwag mentions, where it's running fine then randomly won't push more than 4psi.
However, my main question is given the current modifications to my vehicle on 93 octane fuel, which map should I be running? I'm assuming the limp issue is because I've ran the wrong map.
I can go get some logs to upload, however wanted to wait until i have the catted d.p. installed to try and do a customized map (if possible?).
Thanks! Really a great product, best system for most IS owners needs.
2016 Lexus IS200t FSport
-BM JB4 w/ bluetooth
-FTP charge pipe
-TTI turbo muffler delete
-TTI diverter valve spacer
-HPS full intake kit
-pending install - Catted PPE d.p. (GESI)
