BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 07-09-2019, 08:10 AM
How does that work with fuel bias. Not thread jacking, just asking for further information on the fuel bias and what it should be set at to fix the below 1k psi dips
2009 E92 335i AT
Engine
Janforthewin Janforthewin is offline
Car: 2007 BMW 335i e92
Default 07-09-2019, 10:04 AM
Hey dave, yeah LPFP seems maxed.. what do you recommend? Lower boost or lower E content?
Hpfp is fine- no need to upgrade that- just need to bump up your fuel bias a bit towards redline...
Your LPFP looks maxed up top however..
2007 AT e92, VTT Stage 2+, Fuel it Port Injection kit, BMS PI Controller, Eurotuninggroup stg 2 LPFP, ER Charge Pipe w/ HKS BOV, Alpina Trans flash, VRSF **, MMP Relocated Inlets, RB PCV, n20 tmap, FMIC, BMW PE, MHD PI hybrid Backened flash
Default 07-09-2019, 10:05 AM
I'm not sure how it works for the single barrel but with port injection from my understand where your hpfp dips you adjust Fuel Bias by rpm to spray more fuel to help hpfp numbers.
THE BEAST's Avatar
Car: 2008 E93
Default 07-09-2019, 10:12 AM
Correct. Your LPFP has to be able to supply enough fuel for HPFP AND P.I.
Once you have the capability, you adjust your pi to spray an adequate amount of fuel where needed.
THE BEAST's Avatar
Car: 2008 E93
Default 07-09-2019, 10:13 AM
As I said, correct. Keep in mind trims also play a factor.
Car: 2009 335i AT
Default 07-09-2019, 10:17 AM
That makes sense now. Thank you!
2009 E92 335i AT
Engine
Default 07-09-2019, 10:31 AM
Thanks beast. So if my lpfp is maxed out no matter how much I adjust the FB my hpfp wont raise?
THE BEAST's Avatar
Car: 2008 E93
Default 07-09-2019, 08:34 PM
Correct. If not enough fuel is supplied from tank to engine, it doesnt matter how its distributed. It still not enough fuel.
Default 07-09-2019, 09:01 PM
Up to you...
Lower ethanol content is the quick fix for now.
But if you want to turn up a bit more / more ethanol- id upgrade your s2 to an s3
