inline6xi inline6xi is offline
Car: 2008 bmw 535xi
Default JB4 recent smog experience - 07-06-2019, 09:41 PM
Wanted to share my recent CA smog experience with JB4 installed.
I decided to smog my vehicle with my jb4 in last week. I've been running the car in map 1 since I am all stock except for intake at the moment. I took it to smog place and literally changed to map 0 in the parking lot and shut the vehicle off to reset the system. they had the car plugged in for 20 minutes.
I was niave in thinking I could have my DCIs installed and they wouldnt do anything, but I ultimately failed visual due to having the DCIs. after doing a little research I realized that the BMS dcis which look absolutely identical to the VRSF that I have installed are carb approved I'm a little bummed that this is what n54tuning is selling since there is a very similar product that is carb legal, but I didnt know that when i was ordering so its my fault. The smog dude said to throw on the factory intake box and come back and he would pass me, so no big deal.
More importantly, the interesting news is that I passed all the readiness checks, and OBDII scans. contrary to almost everything I have read on forums about having to drive the car for 30 miles etc.. is this something that has been adressed in the JB4? I think it may be because i dont have auto code clearing enabled.. but honestly im not sure. I dont know how to check that parameter.
anyways I just wanted to share my experience.
Edit: I should have mentioned that this was only OBDII test. No sniffer!
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 07-07-2019, 04:49 PM
Are you running all stock running and just JB4? Id be surprised if your running ***.
Car: 2008 bmw 535xi
Default 07-07-2019, 05:12 PM
stock except for DCIs. not sure what you were trying to say in your second sentence...
Default 07-07-2019, 07:03 PM
The N54 JB4 is not CARB approved for sale or use in California, but it has passed the Federal 1A standards. So it doesn't effect emissions.
The BMS DCI is the only 50-state legal DCI. We charge a few more bucks for it but it's well worth it. Our filters are better also compared to the cheaper options out there.
Car: 2008 bmw 535xi
Default 07-07-2019, 07:16 PM
Thanks for reply Terry. I may just sell my vrsf intake and buy the carb legal one...
Hey do you know why so many people have had trouble getting 'readiness' even in map 0? I literally changed to map 0 in parking lot and apparently all my stuff was ready... If it is the fact that I don't have auto code clear turned on, is this something I can check? I've been through all the menus on the jb4 and I see nothing about auto clear. Running latest board and my menu says 'version 3.6 settings'.
Default 07-08-2019, 02:40 PM
If you clear fault codes then you restart readiness testing so make sure you're not doing that. But for the N54 1A testing we had no issues getting readiness on the JB4 maps, and of course map0.
Default 07-10-2019, 03:03 AM
Hey,,are you running OEM exhaust manifolds, but you already stated you were stock, so I see now how it passed, as its still stock.
codesx's Avatar
codesx codesx is offline
Default 07-10-2019, 10:23 AM
I pass in Ontario, Canada, as we have less of a visual test. (however as of this past spring we don't need to test anymore).
My emissions themselves were clean. Many here report passing even with kittenless deepees, so long as it's not visually observed.
I would think it will improve your odds (there is a scale, not an on/off) of passing if you run in Map 0 for a bit. This will let the DME, 02 sensors, etc, adapt to fuel and boost so your burn is optimal.
My BMS DCI have way more surface area then my previous intake (Ultimate Racing Cold Air Intake).
Further, it's nice to know they are well certified.
** EDIT ** I have not tried to pass since the BOVs. I suspect the noise will make them look closer. Lucky me, our smog-tests are behind us now.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Jaderok72 Jaderok72 is offline
Car: 2010 135i
Default 01-25-2020, 01:38 PM
I just dealt with this issue. If you have a back end flash your DME needs to be flashed back to Stock (your �� will not be show ready) JB4 must be at Map 0 must have auto clear off Menu 1/4. This is with OEM ��s.
Car: 2008 bmw 535xi
Default 01-25-2020, 01:43 PM
When you uninstalled your BEF did it affect readiness? I.e. did you drive it for 30 miles before smog?
GotPwned GotPwned is offline
Car: 2007 BMW 335i
Default 01-25-2020, 04:55 PM
Yeah I believe that the BMS DCIs are the only dual cone filters that are carb compliant. that's why I switched my filters on my Inlets to the BMS filters just to pass visuals
