keninger keninger is offline
Car: 335i E92
Default Uneven Cylinder Timing - 03-10-2019, 04:51 AM
In most logs cylinder one timing is a bit different from all the others.
I have new index 12 injectors
I have new NGK plugs gapped @ 0.022
I have swapped coils on cyl 1-2 to test, but still, ign 1 remains different from all the others
I have not done a walnut blast on the engine yet, it has 70k miles on it
What could cause different cylinder timing?
Default 03-10-2019, 01:39 PM
“Perfect” timing isn’t going to happen every log. In fact, small corrections occur even when stock.
What you don’t want is big drops / cylinder to cylinder variance
Based on your log, I think everything looks healthy.
What fuel are you using?
Car: 335i E92
Default 03-10-2019, 01:49 PM
I am using 100RON gas. I know that perfect timing won’t happen but what bugs me is that all the other cylinders are mostly working the same but ign 1 wanders off. I see sometimes dips in timings, it drops 3 on one cyl then it recovers, but I know that is normal. What I really don’t like that even on not full load all the cylinders can maintain the exact same timing but not cyl 1.
Car: 335i E92
Default 03-10-2019, 02:00 PM
In this log you can see how crazy cyl 1 timing goes with that spike and how other cylinders are still working the same after the pull
Default 03-10-2019, 09:06 PM
Couple things you can try...
Close your plug gap a bit more... .018-.020 maybe
Compression / leakdown test that cyl- see if it’s close to the others
Knock sensors - you can try running the desensitized setting to see if that cleans up timing on all- this is NOT a recommendation, but if u want to try it, you can- it’s up to you if you want to.
Car: 335i E92
Default 03-11-2019, 02:10 AM
I have tried gapping the plug down to 0.02 form 0.022 but no change.
Next up is a leak down test. If that comes out good, then I will try to desensitize the knock sensors and have a light cruise to monitor timing on cyl 1. I know the risk of desensitized knock sensors, that's why I just want to monitor regular driving not wot.
Default 03-11-2019, 11:31 AM
Sounds good- keep us posted
How many miles on the motor?
Car: 335i E92
Default 03-11-2019, 12:33 PM
Only 70k miles
Default 03-11-2019, 10:48 PM
Only 70k miles
Ok so all things considered fairly low. How many of the 70k tuned? Are you the Original owner?
Curious to see leakdown figures.
Car: 335i E92
Default 03-11-2019, 10:59 PM
I am the second owner, the car was bone stock and I have been tuned for 15k miles. I was mostly using it on map 1-2-5. only had a bef and map 6 for like 3 months. But in an oil change interval of 4k miles it only consumes like 4 onces of oil. Also catch can barelly catches anything, no smoke from the exhaust, no smoke from the oil fill up at idle, so we will have to see
Car: 335i E92
Default 03-14-2019, 02:23 AM
This is an answer I got from one of the groups.
“With a jb4, cylinder 1 is sampled at a quicker rate than 2-6 so sometimes it looks a bit different and spikes often won’t show up on the other cylinders. You’re good.”
