(#951)
Default 04-24-2018, 11:41 AM
On the low throttle false alarm boost too low code, try to capture similar driving conditions in a log and we can check that to see why it's triggering.
Nicoo70 Nicoo70 is offline
Car: M135i
Default 04-24-2018, 11:46 AM
Originally Posted by zole2112
I've been getting this code lately on ISO T12 along with a CEL and Drivetrain Malfunction, no limp mode or noticeable difference in power. The last 2 times I got it I was driving on the highway at about 75 mph in 7th and 8th gear. No limp mode, just a CEL and the 108F01 code.
Annoys the hell out of me lol
Similar for me! How do you to correct this problem?
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 04-24-2018, 11:48 AM
I don't know how to correct it at this point, it doesn't seem to affect performance at least that I can notice. I've been hoping to log it like Terry asked above. I'll keep trying to catch it in a log then I'll post it.
2013 BMW 335xi F30 N55 PWG
Summer '20 install: Speedtech BW 8374/PI & Tune by Trebila
Car: M135i
Default 04-24-2018, 11:56 AM
It’s very dificult to catch it on a log because he come randomly..
Car: M135i
Default 04-24-2018, 11:57 AM
Itís very dificult to catch it on a log because he come randomly..
Car: M135i
Default 04-24-2018, 11:59 AM
Similar driving condition Even if I have no error code ?
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 04-24-2018, 12:19 PM
I have that for a while now and I posted a log, video and picture on post #979 and nothing. Its is for sure that boost is way under target at certain pedal throttle %.
http://www.n54tech.com/forums/showpo...&postcount=979
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
siim138's Avatar
siim138 siim138 is offline
Car: F10 535i
Default Looks like some PWG problem - 04-24-2018, 12:24 PM
Hi, my same problem and a log on this condition when low boost (drive train error) lights up, is posted on 21-th April to support forum here:
http://www.n54tech.com/forums/showpo...83&postcount=4
Only difference is that I run BEF and I need to press with light force to the pedal and car should accelerate a bit to get this error. It is very feelable also when there is like no boost (especially when you think it should be there when pedal position is almost to the 50-70%) and then it hits hard from 2500-3000rpm and mostly it is not feelable in whole gear. Sometimes also when making a soft kick down, the speed and RPM-s builds up like on NA engine. Boost builds up not like before without ISO
I am in situation where I think I should try/ buy Stage 2 OTS map from MHD and look how it acts then...
2011 F10 535i M-Sport PWG // Deep sea blue //
//JB4 PWG_INT_13 + BMS BEF PWG1_RACE_3 // M Performance mufflers// 3,5" cless dowpipe
Default 04-24-2018, 12:24 PM
So I take it the BEF flash didn't take care of it, I was kind of hoping it would even though I will still have the JB4 handling boost.
Car: M135i
Default 04-24-2018, 12:25 PM
Not very reassuring if any solution was not found ..you still have this problem today?
Car: M135i
Default 04-24-2018, 12:38 PM
So you get error every Time no? I think i should try Stage 2+ OTS TOO..
Car: 13 f30 335i
Pretty much what it is. I didn't have this issue with just regular jb4. Iso is doing something wrong.
Nope, it didn't.
Yes, is still happening. I just delete the cel when pop up and I know it wont happen again till you restart the car.
Hopefully Terry can come up with a solution on this. We need more aggressive pedal throttle to build up more boost on normal driving. Its technically boosting 1.2 to 2psi around 50% pedal, not good of course.
Car: M135i
Default 04-24-2018, 12:45 PM
Nope, it didn't.
If its not good , we dont have solution ... :/
siim138's Avatar
Car: F10 535i
Default 04-24-2018, 01:25 PM
Hi Nicoo70 and Yoandry, at least we are in the same boat with this problem
But yes, when I want this error to be appeared then I can aprox 1 time of 5 to get this on screen. But only in specific gear, RPM and throttel response and position.
When driving in Sport on Sport + or even in Comfort BUT making some pulls and harder driving (gears in higher RPM range and changing quickly) then it is harder to get this drive train error.
IN FACT: While I didn't know that for BEF the ISO upgrade is needed, I was able to drive some days without ISO and I made Stage 0 MHD and after that added BEF and ist felt just amazing! Only on higher speeds (over 160km/h) I got some times low boost error and so I asked for help and so I get my way to ISO. That didn't disturbed me so much as now the more bad symptoms with ISO.
Car: M135i
Default 04-24-2018, 01:38 PM
So you advise us to use the BEF?
siim138's Avatar
Car: F10 535i
Default 04-24-2018, 01:51 PM
In my case car felt very good in regular JB4 ( N55_FSERIES_OBDII_PWG_11_T1.hex) + BEF (PWG1_RACE_1c) than now with JB4 ISO (N55_FSERIES_OBDII_ISO_10_T13.hex ) + BEF (PWG1_RACE_1c)
Car: M135i
Default 04-24-2018, 02:01 PM
But always this problem of boost error with the BEF?
Default 04-24-2018, 03:37 PM
Boost under target is a general problem that will be best resolved by deleting it from the BEF as soon as MHD makes that option available to us.
Default 04-25-2018, 10:44 AM
that will eliminate my current cause of the Drivetrain Malfunctions, that would be nice.
Car: 13 f30 335i
Default 04-25-2018, 04:48 PM
Hopefully, but we didn't have this issue before ISO on just jb4.
tcabill tcabill is offline
Car: 2012 535 M Sport
Default 04-26-2018, 11:08 AM
Originally Posted by WaqasRiyami
Terry I remember you told me that if you were
EWG you can use ( JB4 in Map4 ) + MHD OTS
But in PWG it's a different storey. And its better not to do it.
Am i Right ?? Or you can use JB4 + MHD OTS in any Car ??
Last nite I tried to run an MHD map with JB4 in map 0 and forget it, AFR going erratic and 3 psi boost max. Maybe because the boost control diode is cut it's no longer possible to run sans JB4 unless it's completely removed. It would be nice to get a straight answer on this.
2012 535i M-Sport, VRSF Chargepipe, BAVAUTO Hi Perf Coils, NGK 95770 plugs (colder),GFB DV+, VRSF 3.5" **, Wagner FMIC, MHD Map E30 2+, Walbro 450 with 3/8" fuel lines from tank to HPFP with inline Ethanol sensor (all self fabricated).
Default 04-26-2018, 11:12 AM
Can we just connect the boost solenoid back to the OEM harness and call it good? Would like to keep code delete on the fly as well as monitoring and logging with the JB4 as well as future PMI.
neejay's Avatar
neejay neejay is offline
Car: 2011 535i M-Sport
Default 04-26-2018, 07:01 PM
I've been contemplating the MHD BEF, but I'd feel better buying a fmic first. I just can't afford the $900 Wagner with a kid due in a few months, and there's still no other options for the F10 for some reason...smh.
2 logs attached, I appreciate the feedback!
2011 535i M-Sport - MHD Stage 2+ BEF w/ JB4 (logging), xHP Stage 3, BMS Intake, FMIC, ER Chargepipe, RM Motors catted d/p, Megan Racing Supremo Exhaust
siim138's Avatar
Car: F10 535i
Default FUD number for PWG F10 535i - 04-27-2018, 12:13 AM
Please could somebody confirm:
(F10 2011 535i )What is the correct FUD when BC button enabled, WG adaption disabled and BEF option in ON position? Mine shows nr 66 at the moment there on FUD row.
I just want to be sure if all are set perfectly for BEF?
Low boost error still kicking in and boost build up is still not smooth, its usually hardly kicks in at ~3K rpm and sometimes still nothing to feel till do the end of RPM range. Hopefully those repaired BEF or ISO changes come in near weeks!
Thanks,
Siim
listed5 listed5 is offline
Car: f30 ps2 335i
Default 05-01-2018, 06:44 AM
If you have ISO, you cannot use map zero without switching the wastegate wires back to factory; as nothing will be regulating waste gate control. You CAN however, use map 4 which is just a pass-through map.
