(#876)
Default 04-02-2018, 06:17 PM
Going to remove the avgtiming scaling from map3 and I don't thin its serving the purpose I wanted here with the BEF maps. Update to T11 and test.
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 04-03-2018, 06:26 AM
Morning Terry,
Here are some logs with T11. Wondering why yesterday psi was around 18 and today 20+
So, 60 adder will go up to what psi? because I have 22psi as safe boost. Trying to get a flat curve with 20 or 21psi max to not stress too much the hpfp.
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
Car: 13 f30 335i
Default 04-04-2018, 05:25 AM
Originally Posted by cnm135i
Map3 is map1 + adder. Do a log without wheel spin. Try 5th maybe.
Which will be the best option for Meth safety mode and Meth trigger mode? I have both on 0 by default. If I use map 6, adder has to be 0 right?
suchtragedy's Avatar
suchtragedy suchtragedy is offline
Car: 2013 335i
Default 04-04-2018, 06:52 AM
Remembered to finally try and log on my way to work yesterday. See map3 log attached from gears 4-5, mods in description.
2013 335i F30 N55 PWG | JB4 + MHD BEF + xHP Stg3 | Pure Stage 2 + FBO | BMS PI controller + Meth | Fuel-It! Stg2 LPFP
Car: 13 f30 335i
Default 04-04-2018, 08:49 AM
We got pretty much the same setup. Im just missing the stg2 lpfp. Are you using e85?
Car: 2013 335i
Default 04-04-2018, 09:35 AM
I've tried E85 blends but since I don't have ethanol sensor set up my experience has been inconsistent when compared to just running Meth. The nearest E85 station is 2 hours from me so meth is just easier for me to get from a local guy at the racetrack and is way more consistent with about the same result as E85. The LPFP upgrade was so I could try E85, but mainly because I wanted to run port injection but changed my mind and going port meth injection instead. Just due to E85 and sourcing issues vs. meth I am sticking with meth.
Car: 13 f30 335i
Default 04-04-2018, 10:34 AM
Sounds good. I was debating too with Meth vs PI and I end up with meth. Using boost juice 50/50 for now but I will like to try 100% at some point.
Car: 2013 335i
Default 04-04-2018, 10:53 AM
I run 90/10 blend. I used to run boost juice but when I got the PS2 my fuel trims were maxing out pretty bad. I swapped to 90/10 blend and after more logging I finally settled on dual CM10/CM10 nozzles in the CP. Car seems happy with it but can empty the 3 gal meth tank pretty quickly it seems. So that's why I decided to try the swap over to direct port meth injection (got Fuel-It kit on the shelf) just needing to schedule a day to install it all. From what I've read on here on various posts it performs better and consumes less fuel than the CP nozzles do.
Car: 13 f30 335i
Default 04-05-2018, 08:00 AM
Anyone knows where is the meth flow dash light options in T11?
Car: 2013 335i
Default 04-05-2018, 08:45 AM
Rebumping for log review plz :D
Car: 13 f30 335i
Default 04-05-2018, 05:49 PM
Does Terry forgot about this thread? 3 days now with not log review. lol Here is another log.
Also, I have my meth flow starting at 8psi but I have notice that the meth gauge doesn't read 100 if it is not at WOT. Normal pedal around 60-70% when pass 8psi dont know if it actually spraying meth.
Default 04-05-2018, 08:48 PM
I check in and review the posted data for our development purposes as time allows. Thanks for the data!
Default 04-05-2018, 08:49 PM
Looks good to me.
Car: 13 f30 335i
Default 04-06-2018, 04:13 AM
Looks good to me.
Terry,
How my logs look?
What about meth spraying or not after set psi but not at wot. Is not showing on gauge.
435MSPORT 435MSPORT is offline
Car: 435i Coupe
Default 04-06-2018, 04:42 AM
Yoandry,
I have a 2015 F32 currently on JB4 with Meth Spay. **, Straight Pipe, IC...Since the firmware updated caused the engine light came on and sometimes “Full driver train not available” warning has driving me nuts. I was thinking to do the MHD bef/JB4 like yours. Can you share with me?
Is the engine light warning go away?
How is the car runs compared to JB4 only?
Would turbo upgrade work well with the MHD FLASH?
There is a claim on YouTube stated his car running much better, smoother shift. I appreciated you sharing your experiences and any additional technical advice.
B
Marlinman's Avatar
Car: 335i coupe 2010
Default 04-06-2018, 10:19 AM
Originally Posted by 435MSPORT
Yoandry,
B
MUCHHHHHH Better. It is so much better with BEF.
Car: 13 f30 335i
Default 04-06-2018, 10:41 AM
Yoandry,
B
Yes, with MHD Bef is definitely better than just jb4. Drivertrain malfunction still showing on idrive.
Default 04-06-2018, 06:38 PM
Terry,
How my logs look?
Log looks OK to me. The meth signal comes on when meth is close to full flow, not when the pump is first fired up. It takes 1/2 - 3/4 second for the pump to get up to full flow during runs.
Marlinman's Avatar
Default 04-07-2018, 06:40 AM
Terry, does FOL autotune in the ISO? Secondly, does the BEF enable us to lower the FOL value at all?
T_H_O_M_A_S T_H_O_M_A_S is offline
Car: M135ix
Default 04-08-2018, 03:05 PM
i'm getting the drive train message too on idrive , indeed a bit weird , as all other error code tools i have dont show any faults ( jb4 , carly app and torque )
Default 04-08-2018, 03:41 PM
FOL does not adjust itself, not a big factor once a BEF is loaded. Use it to fine tune fuel trims between 0-50 if needed.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 04-08-2018, 04:02 PM
It’s definitely the JB4 iso. I never got it before iso, haven’t gotten it since I removed it and went back to Stage 1.
Mike Levy
2021 Tanzanite Blue II M550i - 8/20/20 build date.
2017 Carbon Black X3 xDrive35i
2018 Silver Equinox LT 2.0T
Default 04-08-2018, 04:11 PM
We tried to turn off a few codes in the back end flash but didn't work. Email over the BEF and we can ensure you have the latest one, so you can see what code you're getting, exactly.
Car: M135ix
Default 04-08-2018, 04:18 PM
ok ive mailed david about the issue
Car: 13 f30 335i
Default 04-08-2018, 06:14 PM
Arent all the bef from the thread the latest one. Also they are for big turbo too right? I just flash the race 4c to see if fix drivertrain error.
