luchocamp's Avatar
Default F30 335i xdrive Speedtech ST3 - 01-22-2018, 08:00 AM
I received my Speedtech stage 3 kit two weeks ago and started installation proccess last Saturday. I am very happy with this kit all parts great quality and attention to details. After reading all the information online and been in contact with Jeff almost a year since he was testing this kit in his F30 335i RWD with EFR7670 Borg Warner.
In Feb 2017 I sent an email explaining that I prefer to sacrifice spool for extra 50-60hp on top and that only could be achieve with EFR8374 as is same size frame, by that time my car runs 11.8@119mph with PS2.
I think a few cars are running this Speedtech kit on xdrive and F series ... next weekend we will finish installation and begin to make some test, logs and comparisons.
I only had to say great things about PURE TURBOS they stg 2 is amazing and great upgrade up to 495whp xdrive in hot weather but now for me I want more
Also one thing that always was around my head was why N54 produce 40hp more with almost same mods than N55 but after you check bmw turbofold on N55 you understand that you are running with 4.5cyl instead of 6cyl.
Speedtech is very professional and always ready to respond answers by email jeff@speedtech.com
'13 BMW 335ix Speedtech stg 3 !
10.64 @129mph, MHD Custom + #LUCHOJB4, E40 + meth ~ Drag Track online set up on instagram @luchocampusano ➡
Default 01-22-2018, 09:03 AM
Congrats! Excited to see how our logs work out. You might beat me to it! You might be upgrading xdrive components soon
ceedawg ceedawg is offline
Car: 2015 f30 335i Msport Xdrive
Default 01-22-2018, 09:11 AM
This is great news. Very anxious to read your feelings on how she drives especially compared to the PS2 and see your logs.
luchocamp's Avatar
Default 01-22-2018, 09:28 AM
xdrive on F series is same as X5 ( +800lbs ) We will see soon
Default 01-22-2018, 12:53 PM
Was it a pain in the arse to install and did they have to take the sub frame down to do it?
Marlinman's Avatar
Car: 335i coupe 2010
Default 01-22-2018, 02:14 PM
Probably a PIA and yes sub frame drop for sure
Default 01-22-2018, 03:45 PM
Have to drop the sub frame on the F or E series or both ?Was hoping not at least on the F series
peopleschoice1 peopleschoice1 is offline
Car: f30 335I
Default 01-22-2018, 04:54 PM
subscribed
Default 01-22-2018, 06:03 PM
I think you can do it dropping or not I’m either. If you don’t drop you have to do it in 2 pieces. I would drop it though
luchocamp's Avatar
Default 01-22-2018, 06:20 PM
No dropping subframe.
No disassembly front axle.
We are going to mount from top, first enter turbo to engine bay then install wg actuator/base, then install manifold, then fit turbo to manifold.
We will need to relocate water pump after that.
You could do it either way.
zipphreak zipphreak is offline
Car: 2015 BMW m235xi
Default 01-23-2018, 05:22 AM
I have an m235 xdrive. I would love to know more about the install once your done. Maybe a write-up or DIY on the forum?
2015 BMW m235xi (F22/N55/EWG) | JB4 + BEF | Wagner Evo2 Performance IC | ER Chargepipe | K&N Dropin | Ground-Control v2 Camber Plates | Dinan Springs | HPA Adjustable Sway Bar Links
VMR V710's | Front 18x8.5 ET45 (235/40/18) | Rear 18x9.5 (265/35/18) | Hankook RS4
https://www.youtube.com/watch?v=dUvs...ature=youtu.be
luchocamp's Avatar
Default 01-23-2018, 07:42 AM
BMW should use this manifold and turbo from factory :
luchocamp's Avatar
Default 01-23-2018, 07:57 AM
BMW N55 Turbofold vs Speedtech manifold
zole2112 zole2112 is offline
Car: 2013 BMW 335xi F30 N55
Default 01-23-2018, 11:40 AM
This is excellent! I have a '13 335 xDrive and am planning the same install in spring.
2013 BMW 335xi F30 N55 PWG
Summer '19 install: Speedtech BW 8374/PI & Tune by Trebila
Default 01-23-2018, 11:48 AM
picture is very poor example. The exterior of oem turbofold is a head shield. The internal clamshell is the actual manifold. Need to go look at cut aways
Default 01-23-2018, 01:07 PM
Are you still using the Fuel-it PI?
bcaz808 bcaz808 is offline
Car: 2011 E90 335i
Default 01-23-2018, 02:07 PM
Looks good, I'm definitely interested in seeing if anyone has boost creep issues with the internal waste gate like CES had on the N54.
luchocamp's Avatar
Default 01-23-2018, 02:45 PM
luchocamp's Avatar
Default 01-23-2018, 02:46 PM
I do not have Fuel It PI .
Default 01-24-2018, 10:19 AM
I think that if .BMW did it this way it would.be more.powerful than the B58 motored 340i without question and give the M3/M4 problems. They purposely underpowered the 335i with this mani and turbo in my opinion because of the M cars.
If you look at the B58 exh mani it almost looks a little similar to the speedtech mani even though it is a turbofold it is a much better designed one than it's BMW counterpart N55 garbage turbofold.
Your speedtech setup looks like a thing of beauty!
Default 01-24-2018, 10:27 AM
Yep straight garbage even though the PS2 seems to run descent with it.
Default 01-24-2018, 10:30 AM
I would be surprised if that was the case with the size of thatT4 borg warner turbine housing plus I think it has a 1.05 AR TS housing at that.
luchocamp's Avatar
Default 01-24-2018, 10:46 AM
0.92 A/R
Default 01-24-2018, 12:20 PM
Someone needs to flange up a B58 manifold and make a A2W!
luchocamp's Avatar
Default 01-24-2018, 12:54 PM
b58 manifold is very expensive
