(#10976)
totti totti is offline
Car: E82 135i N54
Default 06-27-2017, 03:16 PM
Yes 2A18 should be disabled in the BEF. If not email me the file and we can check it out, AU cars do not have DTML.
For misfire that is a real problem you must fix, like plug, coil, or injector.
Thanks mate, email sent
yellowfin's Avatar
yellowfin yellowfin is offline
Car: 335xi - jb4 - DCI
Default Avg Ign - 06-28-2017, 10:29 PM
A question on how Avg Ign is calculated:
Russell's excellent sticky post says "timing below the maximum possible curve". How is the "maximum" defined, is it the respective values in the timing table, and the reduction from that due to knock sensors? With E50 and E85 bef, my avg ign is smack at 0 across all rpm/load. Does this mean I have headroom for timing adjustments?
2007 335xi (I8A0S kline) -- VTT GC lites + inlets + outlets -- Fuel-it stg 2 lpfp -- CPE catted **, FMIC, CP -- Tial BOV -- BMS DCI + OCC
JB4 + BMS/custom bef (E50)
dh58 dh58 is offline
Default 06-29-2017, 01:15 AM
Terry, I also have the same issue with the DTML.
http://www.n54tech.com/flash_files/JB4_BEF_061517.zip
JB4_BB2_IJE0S_E85.bin file.
Default 06-29-2017, 07:36 AM
The BEF files should be good to go for EU cars now. Download and try again.
Default 06-29-2017, 11:51 AM
Working on adding transmission code delete to menu 1/3, moving lambda and fuel quality adaptions to 1/4, and leaving only battery adaption on 1/7.
Are there any specific adaption resets you guys perform often that we don't have on the JB4 yet?
Default 06-29-2017, 01:20 PM
Thank you!
Confirmed it works!
Maximum996's Avatar
Car: 08 535xi
Default 07-01-2017, 12:34 PM
Terry, can we get an updated steering wheel controls list? I want to make sure all my settings are correct after all these firmware updates...after race bef and latest firmware, i intermittently upon startup get fault 2abc accompanied by 30ff...
08 535Xi - jb4 iso w/mhd flash, Bms dci, AR ********* DP, er cp with forge dv, second *** delete, muffler delete, xhp trans flash, ets fmic, bms oil tstat bypass.
Blackarrow335i's Avatar
Blackarrow335i Blackarrow335i is offline
Default 07-02-2017, 03:09 PM
+1
E92 09' 335i MHD BY V8BAIT
MMP STAGE 3 / MMP PI
XHP s3 / MR.5 AIRINTAKE
VRSF **'s VRSF 7" IC / RB PCV VALVE
VTT 2" INLETS / STETT CP TIAL BOV
M3 F/R CONTROL ARMS / M3 STEERING RACK
MEGAN TOE ARMS / KW V2 SUSPENSION
ST DRILLED/SLOTTED ROTORS
BODY/INTERIOR MODS
N20TMAP NGK 5992s Gapped To 0.018"
PR IGINITION UPGRADE
FUEL-IT STAGE 3 LPFP / MISHMOTO + BMS OCC
SETRAB AT COOLER / PERFORMANCE EXHAUST MOD
Default 07-02-2017, 04:12 PM
The listing in the first post is accurate, as far as I know. What is incorrect on it?
cya cya is offline
Default 07-02-2017, 04:57 PM
Terry, setting for 1/3 is not saving for me after the new update. Thanks.
n54Jones n54Jones is offline
Car: 07 bmw 335i
Default 07-02-2017, 10:53 PM
My jb4 isn't letting me update for some reason need some help!
SamJ SamJ is offline
Car: BMW 335i
Default 07-05-2017, 02:50 AM
if i have the JB4 with BMS cable in dash will I be able to connect it to an android device using an OTG cable assuming the device is OTG compatible?
brainsurgery brainsurgery is offline
Car: BMW E91 LCI 335xi
Default 07-05-2017, 02:52 AM
Yes
335i LCI xDrive AT, JB4, ***, Stage1 LPFP, MHD E85 flash.
Car: BMW 335i
Default 07-05-2017, 03:03 AM
Sweet
Thanks for that
One last question can I switch between my laptop (what I've been using) to log and update and the android device app for using the JB4 or is it locked to one type i.e. windows program or app
Default 07-05-2017, 03:07 AM
Sweet
Thanks for that
It's not locked. You can use whatever compatible device you want and change it on the fly.
Car: BMW 335i
Default 07-05-2017, 03:17 AM
thanks
Domino_86's Avatar
Domino_86 Domino_86 is offline
Car: 335i sedan
Default 07-05-2017, 07:07 PM
+1 My SES light stays on with the c*t less down p*pes detected.
harrychiu012 harrychiu012 is offline
Car: BMW E92 335i
Default 07-05-2017, 07:58 PM
The chart posted on the 3rd post doesn't reflect the new changes like the battery adaptation.
Default 07-05-2017, 08:06 PM
The adaption reset on 1/7 is accurate. The note is missing battery adaption reset. Since we are moving that specific one next version, no reason to update that right now anyway.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 07-08-2017, 07:06 AM
Have you made progress on DCT. Temps?
Domino_86's Avatar
Car: 335i sedan
Cool 07-08-2017, 04:52 PM
Terry. Just wanted to let you know that the waste gate algorithm is the truth! Thank god no more rattle, and it seems like it gives the car a deeper exhaust note. I would think that algorithm would render menu 10 useless now.
yellowfin's Avatar
Default FUD bit 7 alternative wastegate rattle algorithm - 07-09-2017, 01:23 PM
I tried on my 10 yo stockers and also found that it reduced rattle a lot, but maybe also a bit more delay when hitting the pedal. Anyways, getting new turbos now.
What's the difference in the "alternative" WG mode? Any directions in which situation to use? Sorry, but the FAQs don't tell.
SINasTER's Avatar
SINasTER SINasTER is offline
Car: BMW 335xi E90
Question 07-10-2017, 05:26 PM
Is it just me
BMW 550 M-Sport xDrive 2011
JB4 stage 2
Custom exhaust with 3" quad tips
Custom 3" D.P.s
ESR RF2 19" wheels
Front: Michelin Pilot Sport 4S 235/40R19
Front: Michelin Pilot Sport 4S 275/35R19
Default 07-10-2017, 05:54 PM
Originally Posted by SINasTER
Is it just me
http://www.n54tech.com/forums/showpo...ostcount=10971
Car: BMW 335i
Default 07-12-2017, 07:04 AM
have always run the car on Map 5 but am about to give Map 7 a go after I get the car back from a full service and check
"Using map 7 requires 50-60% E85, the back end flash, AND the fuel pump upgrade"
I meet the above requirements but just wanted to check the MAP 7 still has the same safeties and fail safes as other maps like map 5?
