Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default Anybody have a lift? - 01-16-2016, 04:36 PM
Talking to a builder about building a house and I need to know the ceiling height for the garage bay that I wanna put a lift in. The 3rd bay isn't under any of the house, so I'm assuming I can go as high as I need to (I hope, or no lift).
Thinking 13 or 14' should be enough, right? The lift posts of the 2 post I'm looking at are 9'3" tall and the highest lock is 68".
How high are your ceilings in the garages guys?
Mike Levy
2021 Tanzanite Blue II M550i - In Transit
2018 Silver Equinox LT 2.0T
Nugs Nugs is offline
Car: 2011 135i
Default 01-17-2016, 10:46 PM
I don't have a ton of garage space and low ceiling so I'm getting one of these
http://www.aaq.net.au/shop/detail/autolift-al-3000bg/
Mounts flush with the floor when installed.
This is where it's going.
Car: 335i, 2009
Default 01-19-2016, 01:22 PM
That is seriously cool. What is installation cost?
M3 F80 2017 Competition & Carbon Brakes
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Car: 2011 135i
Default 01-19-2016, 07:51 PM
Installation is easy as it just sits in the trenches.
Getting it off the truck and in the garage is the hard part as it weighs around 1000kgs.
Mike_L's Avatar
Anti-Social
Default 01-20-2016, 11:59 AM
I wish I could use something like that. Unfortunately, it doesn't seem to lift as high as I need. With my messed up back, I need the wheels almost at eye level, which for me is just under 6' (1.8m).
Mike Levy
Car: 2011 135i
Default 01-20-2016, 06:26 PM
If you have the ceiling space that particular model will lift to 2.1m.
I'm sure you could find an equivalent model for cheaper in the US, or import one from China.
Look on Garage Journal Forums.
natedog7700's Avatar
natedog7700 natedog7700 is offline
Car: 2007 bmw 335i e90 auto
Default 01-21-2016, 06:21 PM
I'm pretty sure the lowest ceiling height you can have is around 9-10 ft. 16+ for a bigger, full size lift. With that being said, yes 13-14' is enough no doubt.
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
2012 Ferrari 458 Italia - SOLD
Mrjrock85 Mrjrock85 is offline
Banned
Default 03-29-2017, 04:29 PM
I belive it's 10-12ft for most standard above ground 2 post lifts. Min. 6" of concrete to anchor
Mike_L's Avatar
Anti-Social
Default 03-29-2017, 07:27 PM
Yeah, I couldn't fit anything. 8' ceiling and the HoA won't let me go any higher. Portable is the only lift I can use.
Mike Levy
e90tiag335i e90tiag335i is offline
Car: 2010 335i
Default 03-31-2017, 05:37 PM
Some lifts can be cut down to fit. I have a Challenger 26000 9k lb lift I cut down to fit my 8' garage. Definitely makes life easier!
JB4, PT5858 ST, 3.5" exhaust, VMR V710, KW V3 coilovers, Wavetrac LSD, AKG subframe and diff bushings- Hybrid Ovations, Jehnert Doorboards, IDMax15 and 2 Arc Audio 1200.6 amps, white gauge cluster
N54_gasm N54_gasm is offline
Car: 335i m sport
Default 04-01-2017, 01:14 AM
I have a maxjax in my garage and love it. Made it permanent and mounted the motor on the wall as I never plan to make it "portable". Works great, and has a 5k load rating. Fit under it on a rolly stool just fone
Car: 2011 135i
Default 04-02-2017, 07:59 PM
Now looks like this
Mike_L's Avatar
Anti-Social
Default 04-02-2017, 08:45 PM
Wish I could do that. Don't think the Florida ground could support it though. Its prone to sinkholes due to past phosphate mining.
Mike Levy
mad1stgen mad1stgen is offline
Car: 2011 335IS
Default 04-03-2017, 05:39 AM
Maxjax rocks. Been using mine for 6-7 years now. Heavy V8s first, bunch of BMWs lately. Definitely recommend !
Car: 2011 135i
Default 04-04-2017, 10:19 PM
Then how do they build houses ?
Mike_L's Avatar
Anti-Social
Default 04-05-2017, 08:59 AM
They build on like a foot thick reinforced concrete pad so that if the ground under part of it gives way, the pad is strong enough to hold the house. It also spreads out the load so there's less pressure on any given area. Thats what I'm really worried about with an inground lift, that all the weight is concentrated in a smaller area where the concrete is thinner.
Mike Levy
Car: 2011 135i
Default 04-05-2017, 07:14 PM
Mine was formed as part of the slab.
I can see how that could be an issue if you are retrofitting.
Mike_L's Avatar
Anti-Social
Default 04-05-2017, 07:59 PM
Its definitely gotta be retrofit. They won't do it for me during the pouring. I asked about that before they put in for all the permits for the building.
Mike Levy
