(#26)
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 03-16-2016, 04:35 AM
Originally Posted by CS@MFactory
All PMs replied to
Not mine....
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
CS@MFactory CS@MFactory is offline
Car: E92
Default 03-20-2016, 04:40 PM
Originally Posted by frmtl2_335i
Not mine....
Please send me your PM if it hasn't been answered. I don't show any PMs from you. It may have been sent to MFactory. Or you can also email me if that is more convenient: cs@teammfactory.com I will be happy to help you out! my apologies to you!
Got Questions? Read our Limited-Slip Differential FAQ: http://www.n54tech.com/forums/showthread.php?t=29755
WethVento WethVento is offline
Car: 2010 BMW 535xi 6MT
Default Would these work on the e60? - 03-24-2016, 10:28 AM
More specifically - 2010 535i xdrive 6MT ??
If not, do you know if there anyone that makes upgraded bushings for subframe, differential or motor/tranny mounts ?
Thank you
Car: E92
Default 03-28-2016, 12:48 AM
Thank you
It uses the same style pumpkin unit but, cannot say for sure that they would all fit unfortunately
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 04-23-2016, 12:52 PM
I searched but didn't find any info but what is the recommended grease/lube for install?
Thanks,
Evan
N54 Powered M5 Wagon:
Car: E92
Default 04-23-2016, 02:40 PM
Thanks,
Evan
I would use a thin spray lube if needed.
Car: E92
Default 04-25-2016, 12:26 AM
All PMs replied to
omarmarji's Avatar
omarmarji omarmarji is offline
Car: n54 335
Default 04-25-2016, 12:38 AM
arent these oem m3 style bushings?
subframe busing updates? lol
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
CURRENT: E82 135i (under construction)
Visit my website VaderSolution.com !
Car: E92
Default 04-27-2016, 02:32 AM
They are made from Thermoplastic Vulcanizate and not rubber like OEM
We are still working with the factory regarding subframe bushings and whether they will be considered for production. If there is a go on them we will make an announcement or post any updates at that time.
Car: E92
Default 05-17-2016, 12:29 AM
All PMs replied to
moss's Avatar
moss moss is offline
Car: 2012 335iS
Default 05-21-2016, 12:11 AM
Subframe bushing update??
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Car: 2011 335d
Default 03-14-2018, 08:23 AM
waking this thread up from the dead.
Does Mfactory still sell this diff bushing set here on N54tech.com? I PM'd him but hadn't heard back. I suppose i could PM CS@Mfactory
moss's Avatar
Car: 2012 335iS
Default 01-03-2019, 07:20 PM
When will these be in stock again?
MFactory MFactory is offline
Car: BMW E92 M3
Default 01-11-2019, 05:27 PM
We are looking into making a new batch, but don't currently have an ETA unfortunately
MFactory / YCW Engineering (LSD's, Gears, Flywheels, Clutches, Driveshafts, Axles) - www.teammfactory.com
YCW Suspension (Mid-Range Coilovers) - www.ycwsuspension.com
SWIFT Springs Europe (Exclusive Distributor) - www.swiftspringseurope.com
SWIFT Springs Asia (Exclusive Distributor) - www.swiftspringsasia.com
