gzim89's Avatar
gzim89 gzim89 is offline
Car: bmw e90 335i
Default laptop suggestions for under $400 for jb4 - 11-22-2014, 08:44 AM
Hey guys im looking for a laptop for logging and flashing the car,what do you guys use and what would be a cheap option?
Thank you
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 11-22-2014, 11:19 AM
Whats your budget? If that's all you will use it for just about anything that will run Windows 7 x64 should do. You can find a lot of refurbs under $200, and bare bones new ones for under $250. If you plan to do coding you might need something that can run XP or at least XP mode under 7.
natedog7700's Avatar
natedog7700 natedog7700 is offline
Car: 2007 bmw 335i e90 auto
Default 11-27-2014, 07:51 PM
I got a Microsoft surface pro 1 for 450$ new. Works great.
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
Koenigsegg Agera R - SOLD
Lamborghini Huracan - SOLD
2014 Bugatti Veyron - SOLD
2012 Ferrari 458 Italia - SOLD
gzim89's Avatar
Car: bmw e90 335i
Default 11-27-2014, 08:08 PM
Surface pro has a usb port to plug jb4?
Default 12-03-2014, 09:19 PM
Sure does. Only one tho lol.
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
WhoLV's Avatar
WhoLV WhoLV is offline
Car: 08 335i coupe
Default 03-25-2015, 08:42 PM
Get a Mac lol
FBO, PR inlets, Custom MHD E60 tune
Car: 2010 535i
Default 03-26-2015, 10:00 PM
This TW700 tablet. It runs windows 8.1 and has a full size usb port. I plug a USB hub into it to connect the JB4, a mouse, a thumb drive, and this roll-up keyboard. All this for under $100 and I simply keep it in the glove box. You can get the tablet cheaper from other retailers.
Default 03-28-2015, 10:04 AM
a device that runs windows 8 for under $100... How is that possible? Lol
BMW 335i
RB's 550whp
2000 Camry
2000 LS1 T56 Camaro
samstryker's Avatar
samstryker samstryker is offline
Car: 2008 535xiT e61
Default 04-23-2015, 01:28 PM
i like the idea of this setup!
2008 e61 535xit: VTT GCs, Fuel-it PI, fuelab FPR w/ return line, stage 2 lpfp, fuelab "700" inline pump, RB external PCV, VRSF 7.5" race FMIC, Inlets, outlet, AR ***, 3" chargepiping, 3" exhaust, JB4, BMS PI controller
Car: 2010 535i
Thumbs up 04-23-2015, 02:04 PM
It's awesome. I also permanently hooked up an rs232 to usb cable to my AIC for port injection and ran it into the glove box. I mount the tablet with a cupholder mount. It's pretty clean and easy to put in and take out.
To charge, I used a 12v cig lighter to usb and plugged it into the 12v port by the passenger footwell that I had just discovered was there during this install.
sadeem28 sadeem28 is offline
Car: F80
Default 04-23-2015, 04:00 PM
just placed an order for the same exact stuff!.. thanks!!
FatF56S's Avatar
FatF56S FatF56S is offline
Car: 2014 Mini Cooper S
Thumbs up 04-23-2015, 04:26 PM
An old acer aspire one from eBay for $150 came with all original packaging like new.
2014 Mini Cooper S F56, Burger Tuning, 30mm lower Eibach and always remembering to KCCO
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Default 04-25-2015, 06:21 AM
That tablet is an awesome idea! There is an Acer (295) and then a Dell (339$) that are good buys on amazon. ordered the Dell a few days ago. if you can avoid the Celeron processor, do so.
500hp500tq 500hp500tq is offline
Default 04-27-2015, 01:03 PM
i'm selling both these lmk i5's are stil lbest bang for buck
http://atlanta.craigslist.org/nat/sys/4998396532.html
http://atlanta.craigslist.org/nat/sys/4993827348.html
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
DirtyDaver335 DirtyDaver335 is offline
Default 05-10-2015, 12:18 PM
Can you code with this?
07' 335i JB4, BMS OCC, RB PCV, ER CP, AR no meows, Forge DV
Car: 2010 535i
Default 05-10-2015, 12:41 PM
I haven't tried it yet. I've installed inpa and edibias but haven't assigned an SP Daten file yet. There isn't much space natively on this tablet so you would probably need to have the SPDaten files on a microSD card. It should work though.
Foacad Foacad is offline
Car: 2012 BMW 135i
Default 05-10-2015, 02:12 PM
Asus T100 is honestly great.
Full windows 8.1 and can either be tablet or keyboarded. 32gb internal space and has USB 3.0.
Only $299.
krukedking krukedking is offline
Car: 2007 335xi
Default 07-15-2015, 09:11 PM
I just purchased the tw700 tablet. Downloaded jb4 interface. I made sure the ports matched. It will not connect!!fail every time!!! Any ideas?!?!?
wespan's Avatar
wespan wespan is offline
Car: Bmw
Default 07-15-2015, 09:44 PM
Is running a win 8 on JB 4 with surf pro over rated?
Car: 2007 335xi
Default 07-15-2015, 09:56 PM
Windows 8.1. And for the record, I had to update the use driver and it connects fine now.
